Текущее время: Вт сен 08, 2026 07:04
 Заголовок сообщения: Теряем пакеты ICMP DIR 855
СообщениеДобавлено: Ср май 20, 2009 16:12
Коллеги по девайсу подскажите. Вот купил сей девайс подключил, настроил маршруты и т.п.
Подключил NAC, качает он у меня торренты. Только скорость отдачи тарентов мне не нравится. Посмотрел логи на роутере и увидел следующие:
INFO] Wed May 20 17:13:33 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 85.58.214.67
[INFO] Wed May 20 17:13:19 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 61.136.175.150
[INFO] Wed May 20 17:13:15 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:12:50 2009 Above message repeated 2 times
[INFO] Wed May 20 17:12:27 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 79.157.99.41
[INFO] Wed May 20 17:12:24 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:12:18 2009 Above message repeated 1 times
[INFO] Wed May 20 17:12:00 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 88.76.41.17
[INFO] Wed May 20 17:11:59 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:11:53 2009 2.4GHz Band: Wireless restart
[INFO] Wed May 20 17:11:53 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:11:52 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 221.127.4.175
[INFO] Wed May 20 17:11:38 2009 Blocked incoming UDP packet from 89.178.216.130:33263 to 93.90.41.93:33263
[INFO] Wed May 20 17:11:34 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:11:33 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 77.45.235.180
[INFO] Wed May 20 17:11:28 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 84.242.134.50
[INFO] Wed May 20 17:11:28 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 94.180.245.132
[INFO] Wed May 20 17:11:28 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:11:25 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 118.11.114.82
[INFO] Wed May 20 17:11:20 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 79.153.17.97
[INFO] Wed May 20 17:11:20 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 94.188.43.103
[INFO] Wed May 20 17:11:14 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 122.27.118.239
[INFO] Wed May 20 17:11:11 2009 Blocked incoming TCP connection request from 10.22.32.18:49975 to 10.22.32.9:50001
[INFO] Wed May 20 17:11:09 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:11:05 2009 Blocked incoming TCP connection request from 10.22.32.18:49975 to 10.22.32.9:50001
[INFO] Wed May 20 17:11:03 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:11:02 2009 Blocked incoming TCP connection request from 10.22.32.18:49975 to 10.22.32.9:50001
[INFO] Wed May 20 17:10:43 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
[INFO] Wed May 20 17:10:37 2009 Above message repeated 1 times
[INFO] Wed May 20 17:10:32 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 221.5.8.115
[INFO] Wed May 20 17:10:25 2009 Blocked incoming TCP connection request from 88.209.211.32:1105 to 93.90.41.93:445
[INFO] Wed May 20 17:10:25 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 213.80.239.105
[INFO] Wed May 20 17:10:24 2009 Blocked incoming TCP connection request from 93.90.38.119:1520 to 93.90.41.93:135
[INFO] Wed May 20 17:10:18 2009 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.120 to 114.244.74.235
Зачем роутер плокирует исходящие служеб. Пакеты? Подскажите как исправить данное безобразие.
DMZ зону помещал, ситуация таже.
СообщениеДобавлено: Пт май 22, 2009 08:03
Обыскал весь форум, ответов не нашел.
Может все таки подскажет кто, что делать?
СообщениеДобавлено: Пт май 22, 2009 11:17
Объясните зачем вам отправль исходящий ICMP пакет редирект? Смысла в этом всеравно никакого не будет, потому что вы за NAT
СообщениеДобавлено: Пт май 22, 2009 11:38
В сети у меня находиться NAS Synology 207+. На нем стоит torrent клиен. Вот он то и отправляет эти пакеты.
NAS помещен в зону DMZ как я понимаю со стороны интернета он должен быть “прозрачен”.
Скорость скачики с меня торрентов минимальна 1-2кб. Подключаю свой старый роутер (asus 500w), скорость возрастает до 50-100кб.
Посмотрел логи на роутере (d-link) увидел блокировки пакетов, вот и написал в форум. Может дело в них.
СообщениеДобавлено: Вт май 26, 2009 08:59
может кто чего подскажет
Сейчас этот форум просматривают: Google [Bot] и гости: 74
