Текущее время: Чт авг 27, 2026 06:44
 Заголовок сообщения: DI-804HV VPN problema
СообщениеДобавлено: Пт фев 18, 2005 10:06
VPN rabotal normal`no.....no teper` nekonektitsa......
LOG:
Monday April 04, 2005 11:09:23 Blocked access attempt from 82.135.189.178:3122 to TCP port 135
Monday April 04, 2005 11:09:26 Blocked access attempt from 82.135.189.178:3122 to TCP port 135
Monday April 04, 2005 11:12:00 Blocked access attempt from 82.135.136.2:2692 to TCP port 135
Monday April 04, 2005 11:12:03 Blocked access attempt from 82.135.136.2:2692 to TCP port 135
Monday April 04, 2005 11:12:56 Blocked access attempt from 82.135.189.80:1299 to TCP port 445
Monday April 04, 2005 11:13:56 Send IKE Q1(QINIT) : 192.168.0.0 --> 192.168.53.0
Monday April 04, 2005 11:14:02 IKED re-TX : QINIT (ETO CHTO TAKOE?????)
Monday April 04, 2005 11:14:07 IKED re-TX : QINIT
Monday April 04, 2005 11:14:17 IKED re-TX : QINIT
Monday April 04, 2005 11:14:27 IKED re-TX : QINIT
Monday April 04, 2005 11:14:47 IKED re-TX : QINIT
Monday April 04, 2005 11:14:48 Send IKE (INFO) : delete [192.168.0.0|82.135..****]-->[82.135..****|192.168.53.0] phase 2
Monday April 04, 2005 11:14:48 IKE phase2 (IPSec SA) remove : 192.168.0.0 <-> 192.168.53.0
Monday April 04, 2005 11:14:48 inbound SPI = 0xc000010, outbound SPI = 0x0
Monday April 04, 2005 11:16:47 Receive IKE INFO : 82.135..**** --> 82.135..****
Monday April 04, 2005 11:16:47 Receive IKE (INFO) : delete 82.135..**** -> 82.135..**** phase 1
Monday April 04, 2005 11:16:47 Send IKE (INFO) : delete 82.135..**** -> 82.135..**** phase 1
Monday April 04, 2005 11:16:47 IKE phase1 (ISAKMP SA) remove : 82.135.0**** <-> 82.135.****
Monday April 04, 2005 11:16:51 Send IKE (INFO) : delete 82.135..**** -> 82.135..**** phase 1
Monday April 04, 2005 11:16:51 IKE phase1 (ISAKMP SA) remove : 82.135..**** <-> 82.135..****
Monday April 04, 2005 11:16:50 IKE phase1 (ISAKMP SA) remove : 82.135..**** <-> 82.135..****
Monday April 04, 2005 11:16:52 Restarted by 62.212.192.246
Monday April 04, 2005 11:18:33 Send IKE M1(INIT) : 82.135..**** --> 82.135..****
Monday April 04, 2005 11:18:33 Receive IKE M2(RESP) : 82.135..**** --> 82.135..****
Monday April 04, 2005 11:18:33 Try to match with ENC:3DES AUTH:PSK HASH:MD5 Group:Group2
Monday April 04, 2005 11:18:33 Send IKE M3(KEYINIT) : 82.135..**** --> 82.135..****
Monday April 04, 2005 11:18:33 Receive IKE M4(KEYRESP) : 82.135..**** --> 82.135..****
Monday April 04, 2005 11:18:33 Send IKE M5(IDINIT) : 82.135..**** --> 82.135..****
Monday April 04, 2005 11:18:34 Receive IKE M6(IDRESP) : 82.135..**** --> 82.135..****
Monday April 04, 2005 11:18:34 IKE Phase1 (ISAKMP SA) established : 82.135..**** <-> 82.135..****
Monday April 04, 2005 11:18:34 Send IKE Q1(QINIT) : 192.168.0.0 --> 192.168.53.0
Monday April 04, 2005 11:18:34 Receive IKE Q2(QRESP) : [192.168.53.0|82.135..****]-->[82.135..****|192.168.0.0]
Monday April 04, 2005 11:18:34 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):Group2
Monday April 04, 2005 11:18:34 Send IKE Q3(QHASH) : 192.168.0.0 --> 192.168.53.0
Monday April 04, 2005 11:18:34 IKE Phase2 (IPSEC SA) established : [192.168.53.0|82.135..****]<->[82.135..****|192.168.0.0]
Monday April 04, 2005 11:18:34 inbound SPI = 0xe000010, outbound SPI = 0x3e000010
Nu vot opiat` zarabotal.....pochemuto gliuchit vremia ot vremeni.
СообщениеДобавлено: Вс фев 20, 2005 20:58
UP......
Суть проблемы: через веб интерфейс тунелль запускается, пробую пинговать без туннеля прямо из веб интерфейса = туннель незапускается, тоже самое и из компа. Пробовал с обоих концов, 2 804 стоят. Кто что посоветует. Раньше работало, и ни с того ни с сего перестало.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 18
