Текущее время: Пн ноя 09, 2026 13:44
 Заголовок сообщения: DI-804HV ipsec Freebsd
СообщениеДобавлено: Пт июл 11, 2008 17:09
Создаю vpn туннель между freebsd 6.0 и DI-804HV прошивка 1.5
при соединении такой лог на маршрутизаторе
Friday July 11, 2008 16:14:00 Send IKE M1(INIT) : x.x.x.117 --> x.x.x.116
Friday July 11, 2008 16:14:00 Receive IKE M2(RESP) : x.x.x.116 --> x.x.x.117
Friday July 11, 2008 16:14:00 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Friday July 11, 2008 16:14:01 Send IKE M3(KEYINIT) : x.x.x.117 --> x.x.x.116
Friday July 11, 2008 16:14:01 Receive IKE M4(KEYRESP) : x.x.x.116 --> x.x.x.117
Friday July 11, 2008 16:14:01 Send IKE M5(IDINIT) : x.x.x.117 --> x.x.x.116
Friday July 11, 2008 16:14:06 IKED re-TX : IDINIT to x.x.x.116
Friday July 11, 2008 16:14:11 IKED re-TX : IDINIT to x.x.x.116
Friday July 11, 2008 16:14:11 receiving a re-Tx MM msg, response the last msg
Friday July 11, 2008 16:14:11 IKED re-TX : MM to x.x.x.116
Friday July 11, 2008 16:14:21 IKED re-TX : IDINIT to x.x.x.116
Friday July 11, 2008 16:14:21 receiving a re-Tx MM msg, response the last msg
Friday July 11, 2008 16:14:21 IKED re-TX : MM to x.x.x.116
Friday July 11, 2008 16:14:22 Send IKE (INFO) : delete x.x.x.117 -> x.x.x.116 phase 1
Friday July 11, 2008 16:14:22 IKE phase1 (ISAKMP SA) remove : x.x.x.117 <-> x.x.x.116
я так понимаю нет ответа на Send IKE M5(IDINIT)
нет ли предположений почему так происходит?
Если нужны конфиги - выложу.
Сейчас этот форум просматривают: Majestic-12 [Bot] и гости: 32
