Текущее время: Пн ноя 09, 2026 13:43
 Заголовок сообщения: DI-524 - ICMP: type 3
СообщениеДобавлено: Чт июл 10, 2008 15:28
Здравствуйте,
использую dlink di-524 в режиме WAN Dynamic IP Address
к нему через встроеный свитч подключено 2 компа.
Наблюдается такая ситуация: 1й комп работает без проблем, но на 2м через некоторое время пропадает инет:
сайты, хосты пингуются, но соединение не происходит.
Current Firmware Version: V2.06Patch08RU
В логе пишется:
Thursday July 10, 2008 14:12:16 ICMP: type 3 code 1 from 80.73.2.5
Thursday July 10, 2008 14:12:22 ICMP: type 3 code 1 from 80.73.2.5
Thursday July 10, 2008 14:12:54 DHCP:renew
Thursday July 10, 2008 14:12:54 DHCP:ack(DOL=600,T1=300,T2=525)
Thursday July 10, 2008 14:12:54 ICMP: type 3 code 1 from 80.73.2.4
Thursday July 10, 2008 14:13:00 ICMP: type 3 code 1 from 89.252.25.25
Thursday July 10, 2008 14:13:02 ICMP: type 3 code 13 from 80.78.42.226
Thursday July 10, 2008 14:00:02 ICMP: type 3 code 1 from 193.110.107.110
Thursday July 10, 2008 14:00:03 ICMP: type 3 code 1 from 193.138.144.194
Thursday July 10, 2008 14:00:04 ICMP: type 3 code 1 from 195.69.177.244
Thursday July 10, 2008 14:00:07 ICMP: type 3 code 1 from 195.69.177.244
Thursday July 10, 2008 14:00:10 ICMP: type 3 code 1 from 193.110.107.110
Thursday July 10, 2008 14:00:13 ICMP: type 3 code 1 from 195.69.177.244
Thursday July 10, 2008 14:00:33 ICMP: type 3 code 1 from 193.138.144.195
Thursday July 10, 2008 14:00:46 ICMP: type 3 code 1 from 193.138.144.194
или
Thursday July 10, 2008 14:42:31 Unrecognized attempt blocked from 93.102.4.175:20007 to 217.147.162.234 UDP:27719
Thursday July 10, 2008 14:42:32 Unrecognized attempt blocked from 222.118.158.213:61525 to 217.147.162.234 UDP:27719
Thursday July 10, 2008 14:42:32 Unrecognized attempt blocked from 76.110.182.201:27931 to 217.147.162.234 UDP:27719
Thursday July 10, 2008 14:42:32 Unrecognized attempt blocked from 121.97.249.253:38793 to 217.147.162.234 UDP:27719
Thursday July 10, 2008 14:42:32 Unrecognized attempt blocked from 58.245.204.71:21637 to 217.147.162.234 UDP:27719
Thursday July 10, 2008 14:42:33 Unrecognized attempt blocked from 200.116.138.191:25834 to 217.147.162.234 UDP:27719
Thursday July 10, 2008 14:42:33 Unrecognized attempt blocked from 76.114.187.147:51638 to 217.147.162.234 UDP:27719
СообщениеДобавлено: Чт июл 10, 2008 15:57
Причем пропадает связь даже с роутером на 30 сек в средем. После этого периода, пока я использую админку, соединение мгновенное.
А для того чтоб соеденится с dlink.ru мне надо 90 секунд. Потом я могу по нему лазить с мновенной загрузкой (почти), но как только я делаю паузу на минуту, то снова пропадает соединение.
Насколько я понимаю, то идет некое кэширование роутером. Я только не могу понять как сделать его работу быстрее??
PS: 1й комп - Вин сервер 2003
2й - Виста
