Текущее время: Пн ноя 09, 2026 13:43
 Заголовок сообщения: DSA-3110 - сдох ?
СообщениеДобавлено: Ср июл 09, 2008 12:49
Не реагирует на команду RESET и на нажатие с удержанием на кнопку RESET. :( Так же не могу на него зайти по SSH и по HTTP, только консолью по RS232.
+NPEB major[1] minor[0] build[0]
NPEC major[1] minor[0] build[0]
phyPresent[0] = 1
phyPresent[1] = 1
phyPresent[2] = 1
phyPresent[3] = 1
phyPresent[4] = 1
phyPresent[5] = 1
phyPresent[6] = 1
phyPresent[7] = 1
phyPresent[8] = 0
phyPresent[9] = 0
phyPresent[10] = 0
phyPresent[11] = 0
phyPresent[12] = 0
phyPresent[13] = 0
phyPresent[14] = 0
phyPresent[15] = 0
phyPresent[16] = 0
phyPresent[17] = 0
phyPresent[18] = 0
phyPresent[19] = 0
phyPresent[20] = 0
phyPresent[21] = 0
phyPresent[22] = 0
phyPresent[23] = 0
phyPresent[24] = 0
phyPresent[25] = 0
phyPresent[26] = 0
phyPresent[27] = 0
phyPresent[28] = 0
phyPresent[29] = 0
phyPresent[30] = 0
phyPresent[31] = 0
PHY 5 configuration:
PHY Status:
Link is Up
Auto Negotiation Completed
PHY Configuration:
Speed: 100Mb/s
Half Duplex
Auto Negotiation Disabled
npe_init: MAC Address = 00 00 83 38 50 02
Ethernet eth1: MAC address 00:00:83:38:50:02
IP: 192.168.1.254/255.255.255.0, Gateway: 192.168.1.1
Default server: 192.168.1.1, DNS server IP: 192.168.1.1
EM-434 Ver.T07 2004-09-24 (For Ver.AA)
RedBoot(tm) bootstrap and debug environment [ROM]
Non-certified release, version UNKNOWN - built 12:01:34, Sep 24 2004
Platform: CastleNet IXP425 Development Platform (XScale)
Copyright (C) 2000, 2001, 2002, Red Hat, Inc.
RAM: 0x00000000-0x04000000, 0x00067ef0-0x1ffd1000 available
FLASH: 0x50000000 - 0x51000000, 128 blocks of 0x00020000 bytes each.
Booting Menu: default loading linux
1. Linux booting
2. Redboot command line
Please select:2
== Executing boot script in 2.000 seconds - enter ^C to abort
RedBoot> fis load ramdisk
RedBoot> fis load zimage
RedBoot> exec
Using base address 0x11600000 and length 0x00200000
Uncompressing Linux.............................................................
......................... done, booting the kernel.
Linux version 2.6.20-dlink (builder@sanya) (gcc version 4.1.1 (Gentoo 4.1.1-r1))
#9 Mon Apr 2 18:36:37 MSD 2007
CPU: XScale-IXP42x Family [690541c1] revision 1 (ARMv5TE), cr=000039ff
Machine: Intel IXDP425 Development Platform
Memory policy: ECC disabled, Data cache writeback
CPU0: D VIVT undefined 5 cache
CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
Built 1 zonelists. Total pages: 16256
Kernel command line: console=ttyS0,115200 root=/dev/ram0 initrd=0x00800000,8M me
m=64M@0x00000000
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 53924KB available (2420K code, 195K data, 128K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
IXP4xx: Using 16MiB expansion bus window size
PCI: IXP4xx is host
PCI: IXP4xx Using direct access for memory space
PCI: bus0: Fast back to back transfers enabled
dmabounce: registered device 0000:00:01.0 on pci bus
dmabounce: registered device 0000:00:02.0 on pci bus
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 2048 bind 1024)
TCP reno registered
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 8192K
NetWinder Floating Point Emulator V0.97 (extended precision)
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
IXP4xx Watchdog Timer: heartbeat 60 sec
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale
RAMDISK driver initialized: 2 RAM disks of 32768K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0xfe0000
8 RedBoot partitions found on MTD device IXP4XX-Flash.0
Creating 8 MTD partitions on "IXP4XX-Flash.0":
0x00000000-0x00060000 : "RedBoot"
0x00060000-0x00080000 : "mac"
0x00080000-0x00180000 : "params"
0x00180000-0x00380000 : "zimage"
0x00380000-0x00b80000 : "ramdisk"
0x00b80000-0x00fc0000 : "unallocated"
0x00fc0000-0x00fc1000 : "RedBoot config"
0x00fe0000-0x01000000 : "FIS directory"
i2c /dev entries driver
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
NET: Registered protocol family 8
NET: Registered protocol family 20
XScale DSP coprocessor detected.
RAMDISK: Compressed image found at block 0
Time: OSTS clocksource has been installed.
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 128K
Loading kernel modules...
Using /lib/modules/2.6.20-dlink/kernel/drivers/dlink/ixp425_rtc.ko
Module rtc v0.2 init
Using /lib/modules/2.6.20-dlink/kernel/drivers/dlink/gpio-led.ko
Module gpio led v0.1 init
Using /lib/modules/2.6.20-dlink/kernel/drivers/dlink/checkont.ko
checkont: successfully!
checkont: check for 1 is incorrect!
insmod: cannot insert `/lib/modules/2.6.20-dlink/kernel/drivers/dlink/checkont.k
o': Invalid parameters (-1): Invalid argument
modprobe: failed to load module checkont
ERROR: cannot load hardware!!!
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/8139too.ko
8139too Fast Ethernet driver 0.9.28
PCI: enabling device 0000:00:01.0 (0140 -> 0143)
eth0: RealTek RTL8139 at 0x1000, 22:11:44:33:66:55, IRQ 28
PCI: enabling device 0000:00:02.0 (0140 -> 0143)
eth1: RealTek RTL8139 at 0x1400, 22:11:44:33:66:55, IRQ 27
Using /lib/modules/2.6.20-dlink/kernel/drivers/char/n_hdlc.ko
HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
N_HDLC line discipline registered.
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/slhc.ko
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/ppp_generic.ko
PPP generic driver version 2.4.2
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/pppox.ko
NET: Registered protocol family 24
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/pppoe.ko
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/ppp_synctty.ko
Using /lib/modules/2.6.20-dlink/kernel/lib/crc-ccitt.ko
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/ppp_async.ko
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/ppp_deflate.ko
PPP Deflate Compression module registered
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/bsd_comp.ko
PPP BSD Compression module registered
Using /lib/modules/2.6.20-dlink/kernel/crypto/arc4.ko
Using /lib/modules/2.6.20-dlink/kernel/crypto/sha1.ko
Using /lib/modules/2.6.20-dlink/kernel/drivers/net/ppp_mppe.ko
PPP MPPE Compression module registered
modprobe: module ppp_mppe_mppc not found.
modprobe: failed to load module ppp_mppe_mppc
Starting system logging: done.
System time...
timezone hour offset = "-3"
name=AAA-3BBB, exported "AAA-3BBB"
base address 0x64
rtcclock: ??? ??? 45 29:04:07 2065
Timezone:
minutes to west: 0
dst time : 0
RTC clock: ??? ??? 45 29:04:07 2065
date: Mon Jan 12 01:35:51 AAA 1931
done.
Initializing random number generator... done.
Preparing auto config from "/proc/mtd" into /tmp/eth-conf...
Getting MAC address...
dev: size erasesize name
mtd0: 00060000 00020000 "RedBoot"
mtd1: 00020000 00020000 "mac"
OK: MAC mtd partition founded on /dev/mtd1
sizeof struct macrecord=7
no string for eth0 found
/tmp/eth-conf: eth0 has mac 00:90:0B:08:0E:B7
Checking spelling for "00:90:0B:08:0E:B7"...OK
INTERFACE eth0 SUCCESSFULLY CONFIGURED WITH 00:90:0B:08:0E:B7..........OK
no string for eth1 found
/tmp/eth-conf: eth1 has mac 00:90:0B:08:0E:B8
Checking spelling for "00:90:0B:08:0E:B8"...OK
INTERFACE eth1 SUCCESSFULLY CONFIGURED WITH 00:90:0B:08:0E:B8..........OK
no string for eth2 found
/tmp/eth-conf: eth2 has mac 00:90:0B:08:0E:B9
Checking spelling for "00:90:0B:08:0E:B9"...OK
SIOCSIFHWADDR: No such device
INTERFACE eth2 CANNOT BE CONFIGURED WITH 00:90:0B:08:0E:B9........ERROR
no string for eth3 found
/tmp/eth-conf: eth3 has mac 00:90:0B:08:0E:BA
Checking spelling for "00:90:0B:08:0E:BA"...OK
INTERFACE eth3 CANNOT BE CONFIGURED WITH 00:90:0B:08:0E:BA........ERROR
Starting network...
RTNETLINK answers: File exists
eth0: link down
RTNETLINK answers: Network is unreachable
Cannot find device "eth2"
SIOCGIFFLAGS: No such device
Cannot find device "eth3"
net.ipv4.ip_forward = 1
Starting ntpdate:
Error : Temporary failure in name resolution
12 Jan 01:35:53 ntpdate[351]: can't find host pool.ntp.org
12 Jan 01:35:53 ntpdate[351]: no servers can be used, exiting
failed!
Starting...
Full cmd line is "/sbin/route -e add default gw 85.90.119.198 dev eth0", running
...route: SIOC[ADD|DEL]RT: Network is unreachable
[FAILED]
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.100.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
10.0.12.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 192.168.100.253 0.0.0.0 UG 0 0 0 eth0
Starting network address translation: Using /lib/modules/2.6.20-dlink/kernel/net
/netfilter/x_tables.ko
Using /lib/modules/2.6.20-dlink/kernel/net/ipv4/netfilter/ip_tables.ko
ip_tables: (C) 2000-2006 Netfilter Core Team
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (512 buckets, 4096 max)
done.
Starting dnsmasq: /etc/init.d/S47dns: 40: /usr/sbin/dnsmasq: not found
/etc/init.d/rcS: 28: /etc/init.d/S47netflow: Permission denied
Starting udhcpd (simple DHCP Server)...
* checking leases for backward compatibility...
* start server for eth0(192.168.100.253)...
udhcpd (v0.9.9-pre) started
OK
iptables: No chain/target/match by that name
/etc/init.d/rcS: 28: /etc/init.d/S50dns: Permission denied
/usr/sbin/mini_httpd: started as root without requesting chroot(), warning only
ok.
ok.
Starting pppoe-server: pppoe-server.
Starting pptpd: done.
Starting sshd: OK
/etc/init.d/rcS: 28: /etc/init.d/S50thttpd:
СообщениеДобавлено: Ср июл 09, 2008 13:16
можно выполнить команду по консоли reset_and_reboot ?
СообщениеДобавлено: Ср июл 09, 2008 13:25
Да можно, ребудится без проблем, ресет не выполняет :( точнее выполняет, но железка не реагирует :( Возвращается в командную строку.
СообщениеДобавлено: Ср июл 09, 2008 14:11
Тогда в сервис.
