Текущее время: Вт ноя 10, 2026 14:30
 Заголовок сообщения: ВОПРОС ПО VPN КАНАЛУ DI804H
СообщениеДобавлено: Чт май 29, 2008 11:18
У нас организован VPN Канал между двумя офисами. На одной стороне маршрутизатор di804HV а на другой D-Link DI-824VUP+.
Di304HV. По каким то не ясным мне причинам VPN канал падает. жмем перезагрузить канал опять подымается. И так происходит по 100 раз на дню(.
Вот лог
hu May 29 14:43:06 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:43:06 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:43:22 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:43:22 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:43:38 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:43:38 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:44:08 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:44:08 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:44:44 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:44:44 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:45:06 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:45:06 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:45:22 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:45:22 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:45:38 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:45:38 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:46:08 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:46:08 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:46:24 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:46:24 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:46:40 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:46:40 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:46:59 2008 Blocked access attempt from 89.222.153.113:3114 to UDP port 1434
Thu May 29 14:47:22 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:47:22 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:47:51 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:47:51 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:48:09 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:48:09 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:48:25 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:48:25 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:48:41 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:48:41 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:48:57 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:48:57 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:49:21 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:49:21 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:49:51 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:49:51 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:50:09 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:50:09 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:53:23 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:53:23 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:54:10 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:54:10 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:54:26 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:54:26 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:54:42 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:54:42 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:54:58 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:54:58 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:55:14 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:55:14 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:55:25 2008 Warming : delete IPSec tunnel because remote subnet no response
Thu May 29 14:55:25 2008 Send IKE (INFO) : delete [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6] phase 2
Thu May 29 14:55:25 2008 IKE phase2 (IPSec SA) remove : 192.168.5.1 <-> 192.168.1.6
Thu May 29 14:55:25 2008 inbound SPI = 0x4000010, outbound SPI = 0x10a20110
Thu May 29 14:55:25 2008 Send IKE (INFO) : delete 89.189.187.177 -> 81.1.255.186 phase 1
Thu May 29 14:55:25 2008 IKE phase1 (ISAKMP SA) remove : 89.189.187.177 <-> 81.1.255.186
Thu May 29 14:55:45 2008 Send IKE M1(INIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 14:55:45 2008 Receive IKE M2(RESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 14:55:45 2008 Try to match with ENC:3DES AUTH:PSK HASH:MD5 Group:Group2
Thu May 29 14:55:45 2008 Send IKE M3(KEYINIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 14:55:45 2008 Receive IKE M4(KEYRESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 14:55:45 2008 Send IKE M5(IDINIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 14:55:45 2008 Receive IKE M6(IDRESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 14:55:45 2008 IKE Phase1 (ISAKMP SA) established : 81.1.255.186 <-> 89.189.187.177
Thu May 29 14:55:46 2008 Send IKE Q1(QINIT) : 192.168.5.1 --> 192.168.1.6
Thu May 29 14:55:46 2008 Receive IKE Q2(QRESP) : [192.168.1.6|81.1.255.186]-->[89.189.187.177|192.168.5.1]
Thu May 29 14:55:46 2008 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):Group2
Thu May 29 14:55:46 2008 Send IKE Q3(QHASH) : 192.168.5.1 --> 192.168.1.6
Thu May 29 14:55:46 2008 IKE Phase2 (IPSEC SA) established : [192.168.1.6|81.1.255.186]<->[89.189.187.177|192.168.5.1]
Thu May 29 14:55:46 2008 inbound SPI = 0x6000010, outbound SPI = 0x2ca20110
Thu May 29 14:59:23 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:59:23 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:59:39 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:59:39 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 14:59:55 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 14:59:55 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:00:11 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:00:11 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:00:41 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:00:41 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:00:57 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:00:57 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:01:13 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:01:13 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:01:29 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:01:29 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:01:45 2008 Blocked access attempt from 122.225.1.148:1036 to UDP port 1434
Thu May 29 15:01:50 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:01:50 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:02:06 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:02:06 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:02:22 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:02:22 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:02:41 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:02:41 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:03:18 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:03:18 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:03:34 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:03:34 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:03:50 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:03:50 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:04:06 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:04:06 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:04:22 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:04:22 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:04:50 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:04:50 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:05:04 2008 Blocked access attempt from 218.22.44.187:43696 to TCP port 22
Thu May 29 15:05:06 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:05:06 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:05:07 2008 Blocked access attempt from 218.22.44.187:43696 to TCP port 22
Thu May 29 15:05:22 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:05:22 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:05:38 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:05:38 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:05:54 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:05:54 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:06:05 2008 Warming : delete IPSec tunnel because remote subnet no response
Thu May 29 15:06:05 2008 Send IKE (INFO) : delete [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6] phase 2
Thu May 29 15:06:05 2008 IKE phase2 (IPSec SA) remove : 192.168.5.1 <-> 192.168.1.6
Thu May 29 15:06:05 2008 inbound SPI = 0x6000010, outbound SPI = 0x2ca20110
Thu May 29 15:06:05 2008 Send IKE (INFO) : delete 89.189.187.177 -> 81.1.255.186 phase 1
Thu May 29 15:06:05 2008 IKE phase1 (ISAKMP SA) remove : 89.189.187.177 <-> 81.1.255.186
Thu May 29 15:06:12 2008 Send IKE M1(INIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:06:12 2008 Receive IKE M2(RESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:06:12 2008 Try to match with ENC:3DES AUTH:PSK HASH:MD5 Group:Group2
Thu May 29 15:06:12 2008 Send IKE M3(KEYINIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:06:12 2008 Receive IKE M4(KEYRESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:06:13 2008 Send IKE M5(IDINIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:06:13 2008 Receive IKE M6(IDRESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:06:13 2008 IKE Phase1 (ISAKMP SA) established : 81.1.255.186 <-> 89.189.187.177
Thu May 29 15:06:13 2008 Send IKE Q1(QINIT) : 192.168.5.1 --> 192.168.1.6
Thu May 29 15:06:13 2008 Receive IKE Q2(QRESP) : [192.168.1.6|81.1.255.186]-->[89.189.187.177|192.168.5.1]
Thu May 29 15:06:13 2008 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):Group2
Thu May 29 15:06:13 2008 Send IKE Q3(QHASH) : 192.168.5.1 --> 192.168.1.6
Thu May 29 15:06:13 2008 IKE Phase2 (IPSEC SA) established : [192.168.1.6|81.1.255.186]<->[89.189.187.177|192.168.5.1]
Thu May 29 15:06:13 2008 inbound SPI = 0x8000010, outbound SPI = 0x34a20110
Thu May 29 15:06:41 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:06:41 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:06:57 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:06:57 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:07:13 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:07:13 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:07:29 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:07:29 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:07:50 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:07:50 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:08:06 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:08:06 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:09:03 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:09:03 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:09:19 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:09:19 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:09:35 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:09:35 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:09:51 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:09:51 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:10:07 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:10:07 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:10:18 2008 Warming : delete IPSec tunnel because remote subnet no response
Thu May 29 15:10:18 2008 Send IKE (INFO) : delete [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6] phase 2
Thu May 29 15:10:18 2008 IKE phase2 (IPSec SA) remove : 192.168.5.1 <-> 192.168.1.6
Thu May 29 15:10:18 2008 inbound SPI = 0x8000010, outbound SPI = 0x34a20110
Thu May 29 15:10:18 2008 Send IKE (INFO) : delete 89.189.187.177 -> 81.1.255.186 phase 1
Thu May 29 15:10:18 2008 IKE phase1 (ISAKMP SA) remove : 89.189.187.177 <-> 81.1.255.186
Thu May 29 15:10:22 2008 Send IKE M1(INIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:10:22 2008 Receive IKE M2(RESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:10:22 2008 Try to match with ENC:3DES AUTH:PSK HASH:MD5 Group:Group2
Thu May 29 15:10:22 2008 Send IKE M3(KEYINIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:10:22 2008 Receive IKE M4(KEYRESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:10:22 2008 Send IKE M5(IDINIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:10:22 2008 Receive IKE M6(IDRESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:10:22 2008 IKE Phase1 (ISAKMP SA) established : 81.1.255.186 <-> 89.189.187.177
Thu May 29 15:10:22 2008 Send IKE Q1(QINIT) : 192.168.5.1 --> 192.168.1.6
Thu May 29 15:10:23 2008 Receive IKE Q2(QRESP) : [192.168.1.6|81.1.255.186]-->[89.189.187.177|192.168.5.1]
Thu May 29 15:10:23 2008 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):Group2
Thu May 29 15:10:23 2008 Send IKE Q3(QHASH) : 192.168.5.1 --> 192.168.1.6
Thu May 29 15:10:23 2008 IKE Phase2 (IPSEC SA) established : [192.168.1.6|81.1.255.186]<->[89.189.187.177|192.168.5.1]
Thu May 29 15:10:23 2008 inbound SPI = 0xa000010, outbound SPI = 0x3aa20110
Thu May 29 15:10:25 2008 Blocked access attempt from 89.189.177.24:30488 to TCP port 139
Thu May 29 15:10:25 2008 Blocked access attempt from 89.189.177.24:30489 to TCP port 135
Thu May 29 15:10:28 2008 Blocked access attempt from 89.189.177.24:30488 to TCP port 139
Thu May 29 15:10:28 2008 Blocked access attempt from 89.189.177.24:30489 to TCP port 135
Thu May 29 15:10:38 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:10:38 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:10:59 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:10:59 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:11:15 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:11:15 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:11:31 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:11:31 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:11:47 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:11:47 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:12:03 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:12:03 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:12:14 2008 Warming : delete IPSec tunnel because remote subnet no response
Thu May 29 15:12:14 2008 Send IKE (INFO) : delete [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6] phase 2
Thu May 29 15:12:14 2008 IKE phase2 (IPSec SA) remove : 192.168.5.1 <-> 192.168.1.6
Thu May 29 15:12:14 2008 inbound SPI = 0xa000010, outbound SPI = 0x3aa20110
Thu May 29 15:12:14 2008 Send IKE (INFO) : delete 89.189.187.177 -> 81.1.255.186 phase 1
Thu May 29 15:12:14 2008 IKE phase1 (ISAKMP SA) remove : 89.189.187.177 <-> 81.1.255.186
Thu May 29 15:14:46 2008 Send IKE M1(INIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:14:46 2008 Receive IKE M2(RESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:14:46 2008 Try to match with ENC:3DES AUTH:PSK HASH:MD5 Group:Group2
Thu May 29 15:14:46 2008 Send IKE M3(KEYINIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:14:46 2008 Receive IKE M4(KEYRESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:14:46 2008 Send IKE M5(IDINIT) : 89.189.187.177 --> 81.1.255.186
Thu May 29 15:14:46 2008 Receive IKE M6(IDRESP) : 81.1.255.186 --> 89.189.187.177
Thu May 29 15:14:46 2008 IKE Phase1 (ISAKMP SA) established : 81.1.255.186 <-> 89.189.187.177
Thu May 29 15:14:46 2008 Send IKE Q1(QINIT) : 192.168.5.1 --> 192.168.1.6
Thu May 29 15:14:47 2008 Receive IKE Q2(QRESP) : [192.168.1.6|81.1.255.186]-->[89.189.187.177|192.168.5.1]
Thu May 29 15:14:47 2008 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):Group2
Thu May 29 15:14:47 2008 Send IKE Q3(QHASH) : 192.168.5.1 --> 192.168.1.6
Thu May 29 15:14:47 2008 IKE Phase2 (IPSEC SA) established : [192.168.1.6|81.1.255.186]<->[89.189.187.177|192.168.5.1]
Thu May 29 15:14:47 2008 inbound SPI = 0xc000010, outbound SPI = 0x41a20110
Thu May 29 15:15:02 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:15:02 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:15:18 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:15:18 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:15:34 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:15:34 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:15:50 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:15:50 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
Thu May 29 15:16:06 2008 IPSec tunnel keep alive : peer IP 192.168.1.6
Thu May 29 15:16:06 2008 [192.168.5.1|89.189.187.177]-->[81.1.255.186|192.168.1.6]
подскажите . как устранить эти вечные обрывы Vpn?
