Текущее время: Сб сен 05, 2026 09:06
 Заголовок сообщения: DI-804HV и дегунино
СообщениеДобавлено: Пт окт 26, 2007 01:24
Отцы, помогайте, мозг мой рушится.
стоит роутер DI-804HV V1.44b11, Fri, Feb 09 2007, сеть Дегунино.
настройки провайдера:
vpn.degunino.net
login ***
password ***
ip 10.149.178.13
gw 10.149.178.253
dns1 192.168.0.1
dns2 192.168.0.253
на лан интерфейсе роутера
ip 10.149.178.151
mask 255.255.255.0
log с роутера
WAN Type: PPTP (V1.44b11)
Display time: Friday October 26, 2007 02:07:39
Friday October 26, 2007 02:05:56 PPTP start to dial-down
Friday October 26, 2007 02:05:57 Restarted by 10.149.178.155
Friday October 26, 2007 02:06:08 DOD:triggered internally
Friday October 26, 2007 02:06:08 PPTP start to dial-up
Friday October 26, 2007 02:07:00 Set Device Time to: Fri Oct 26 02:07:00 2007
Friday October 26, 2007 02:07:09 DOD:triggered internally
Friday October 26, 2007 02:07:09 PPTP start to dial-up
Friday October 26, 2007 02:07:31 Restarted by 10.149.178.155
Friday October 26, 2007 02:07:36 DOD:triggered internally
после этого меняю MTU на 1450 (в начале было 1460)
Friday October 26, 2007 02:07:36 PPTP start to dial-up
Friday October 26, 2007 02:07:36 PPTP server=10.150.18.14
Friday October 26, 2007 02:07:36 CHAP1: OK
Friday October 26, 2007 02:07:36 IPCP1: IP is 172.31.233.121
Friday October 26, 2007 02:07:36 IPCP1: DNS0 is 192.168.0.253
Friday October 26, 2007 02:07:36 IPCP1: DNS1 is 192.168.0.1
устройство подключается, с роутера пинг проходит, он говорит Ping www.ru Successfully!
с компьюетра ничего не отвечает
ping дает следующее
C:\Documents and Settings\HB>ping www.ru
Pinging www.ru [194.87.0.50] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 194.87.0.50:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
ipconfig /all получается следующим
C:\Documents and Settings\HB>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : celik
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter degunino:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : 3Com EtherLink XL 10/100 PCI For Com
plete PC Management NIC (3C905C-TX)
Physical Address. . . . . . . . . : 00-01-03-C3-BA-2E
Ethernet adapter inhome:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-0F-EA-60-E0-1B
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 10.149.178.155
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.148.178.151
DNS Servers . . . . . . . . . . . : 10.149.178.151
И интернета нету.
Пробывал менять значения MTU до 1000 с шагом в 50, не помогает.
когда все это настраивается с компьютера - все работает нормально
при подключении без роутера
C:\Documents and Settings\HB>tracert www.ru
Tracing route to www.ru [194.87.0.50]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 172.31.1.1
2 1 ms 1 ms 1 ms 79.120.55.253
3 2 ms 1 ms 1 ms 212.1.251.185
4 2 ms 2 ms 2 ms 212.1.251.237
5 2 ms 1 ms 2 ms RT502-001.retn.net [193.232.244.187]
6 3 ms 3 ms 2 ms GW-Demos.retn.net [81.222.8.46]
7 5 ms 3 ms 3 ms iki-1-vl10.demos.net [194.87.0.83]
8 4 ms 4 ms 4 ms www.ru [194.87.0.50]
IP Address. . . . . . . . . . . . : 10.149.178.13
Default Gateway . . . . . . . . . : 10.149.178.253
DNS Servers . . . . . . . . . . . : 192.168.0.1
192.168.0.253
PPP adapter INTERNET:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
IP Address. . . . . . . . . . . . : 172.31.233.121
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 172.31.233.121
DNS Servers . . . . . . . . . . . : 192.168.0.253
192.168.0.1
Trace complete.
Что делать?
Заранее спасибо.
 Заголовок сообщения: ????
СообщениеДобавлено: Сб окт 27, 2007 23:49
Народ, я такой глупый вопрос задал или его просто так решили все заигнорить?
СообщениеДобавлено: Вс окт 28, 2007 07:39
Дык, много буков. Читать долго.
(но это, если по-честному, хорошо. Иначе непонять откуда трабл).
LAN и WAN лежат в одной подсети. Чего быть не должно.
Вот маршрутизатор и охреневает потихоньку.
СообщениеДобавлено: Вт окт 30, 2007 18:17
LAN и WAN разнес в разные подсети, ничего не изменилось
народ, у меня к фирме dlink появляется некторое недоверие.
если уже сотрудникам данной фbрмы тяжко прочитать что я написал, то ответа я так понимаю ждать вообще не от кого...
СообщениеДобавлено: Вт окт 30, 2007 18:24
Настройки покажите после "разнесения" в разные подсети.
 Заголовок сообщения: Вынужден извиниться
СообщениеДобавлено: Сб ноя 03, 2007 15:36
после разнесения в разные подсети все начало нормально работать, никаких проблем нет.
Всем большое спасибо.
СообщениеДобавлено: Вс янв 20, 2008 22:19
у меня такая же проблема на роутере Dl-524
когда я меняю lan ip то он меняеться и в сети дегунино что там запрещенно.
как мне поступить чтобы эта вся система работала?
СообщениеДобавлено: Вт янв 22, 2008 16:16
В сети degunino он не меняется, он вообще не виден извне.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 51
