Текущее время: Пн ноя 09, 2026 03:22
 Заголовок сообщения: D-Link DI-524
СообщениеДобавлено: Чт окт 11, 2007 00:30
У меня проблема. :( Пытаюсь настроить подключение к провайдеру при помощи роутера D-Link 524, используя PPPoE соединение. Все подключил согласно инструкциям, но Интернета через роутер нет. Напрямую все ок.
- все файерволы отключены
- лог:
Tuesday January 30, 2007 00:11:32 DOD:triggered internally
Tuesday January 30, 2007 00:11:32 PPPoE start to dial-up
Tuesday January 30, 2007 00:11:32 PADT sent
Tuesday January 30, 2007 00:11:34 PADI sent
Tuesday January 30, 2007 00:11:34 PADO recv 0016 ADSLNET
Tuesday January 30, 2007 00:11:34 PADR sent
Tuesday January 30, 2007 00:11:34 PADS recv 0002 8800
Tuesday January 30, 2007 00:11:36 PPP3: TX LCP Request
Tuesday January 30, 2007 00:11:36 PPP3: Rx LCP ACK
Tuesday January 30, 2007 00:11:37 PPP3: Rx LCP Request
Tuesday January 30, 2007 00:11:37 PPP3: TX LCP ACK
Tuesday January 30, 2007 00:11:39 CHAP3: fail
Tuesday January 30, 2007 00:11:39 PPP3: closed
Tuesday January 30, 2007 00:11:39 LCP3: RX terminate request
Tuesday January 30, 2007 00:28:46 DOD:triggered internally
Tuesday January 30, 2007 00:28:46 PPPoE start to dial-up
Tuesday January 30, 2007 00:28:46 PADT sent
Tuesday January 30, 2007 00:28:47 PADI sent
Tuesday January 30, 2007 00:28:47 PADO recv 0016 ADSLNET
Tuesday January 30, 2007 00:28:47 PADR sent
Tuesday January 30, 2007 00:28:47 PADS recv 0002 6800
Tuesday January 30, 2007 00:28:50 PPP3: TX LCP Request
Tuesday January 30, 2007 00:28:50 PPP3: Rx LCP ACK
Tuesday January 30, 2007 00:28:50 PPP3: Rx LCP Request
Tuesday January 30, 2007 00:28:50 PPP3: TX LCP ACK
Tuesday January 30, 2007 00:28:54 CHAP3: fail
Tuesday January 30, 2007 00:28:54 PPP3: closed
Tuesday January 30, 2007 00:28:54 LCP3: RX terminate request
- скриншоты
В чем может быть проблема?
Спасибо
СообщениеДобавлено: Пт окт 12, 2007 13:49
Неправильный логин или пароль. Проверьте правильность ввода.
СообщениеДобавлено: Сб окт 13, 2007 04:02
Спасибо за помощь...
Последний раз редактировалось zetfavor Пн окт 15, 2007 13:35, всего редактировалось 2 раз(а).
СообщениеДобавлено: Сб окт 13, 2007 04:11
Еще один момент...
Последний раз редактировалось zetfavor Пн окт 15, 2007 13:36, всего редактировалось 1 раз.
СообщениеДобавлено: Сб окт 13, 2007 05:05
почитал на форуме....
Сейчас этот форум просматривают: Baidu [Spider] и гости: 23
