Текущее время: Вс ноя 08, 2026 02:16
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 5 ]
 Заголовок сообщения: Dl-604
СообщениеДобавлено: Чт сен 27, 2007 02:12
Проблема с Dl-604
Подключение через PPPoE. Подключается без проблем...А интернет неработает..Трафик не идёт. Прошивка Firmware: v3.21RU
Hardware: Bx、Dx and Fx for DI-604
August 10, 2007...
Вот логи
Thursday September 27, 2007 00:04:03 DOD:triggered internally
Thursday September 27, 2007 00:04:03 start to dial-up
Thursday September 27, 2007 00:04:03 PADI sent
Thursday September 27, 2007 00:04:03 PADO recv 0016 c7200-main.elss.ru
Thursday September 27, 2007 00:04:03 PADR sent
Thursday September 27, 2007 00:04:03 PADS recv 8002 E57E
Thursday September 27, 2007 00:04:05 PPP3: RX LCP Request
Thursday September 27, 2007 00:04:05 PPP3: TX LCP Reject
Thursday September 27, 2007 00:04:05 PPP3: TX LCP ACK
Thursday September 27, 2007 00:04:06 PPP3: TX LCP ACK
Thursday September 27, 2007 00:04:06 PPP3: TX LCP Request
Thursday September 27, 2007 00:04:06 PPP3: RX LCP ACK
Thursday September 27, 2007 00:04:06 Unrecognized attempt blocked from CHAP3: OK
Thursday September 27, 2007 00:04:06 PPP3: TX IPCP Reguest
Thursday September 27, 2007 00:04:06 PPP3: RX IPCP Request
Thursday September 27, 2007 00:04:06 PPP3: RX IPCP NACK/REJECT
Thursday September 27, 2007 00:04:06 IPCP3: IP is 10.65.0.52
Thursday September 27, 2007 00:04:06 IPCP3: DNS0 is 85.113.62.225
Thursday September 27, 2007 00:04:06 IPCP3: DNS1 is 85.113.63.225
Thursday September 27, 2007 00:04:06 PPP3: RX IPCP ACK
Помогите пожалуйста ...
СообщениеДобавлено: Чт сен 27, 2007 10:44
В статусе Connected?
С роутера, со странички Tools->Misc адреса Интернета пингуются?
СообщениеДобавлено: Чт сен 27, 2007 12:30
Ping RAMBLER.RU Successfully!
Firmware Version : V3.21RU , Mon, Aug 20 2007
LAN
MAC Address 00-17-9A-FA-C1-57
IP Address 192.168.0.1
Subnet Mask 255.255.255.0
DHCP Server Enabled
Wan
MAC Address 00-15-F2-7B-17-6B
Connection PPPoE Connected
IP Address 10.65.0.52
Connection Time 00:01:16
Subnet Mask 255.255.255.255
Gateway 10.65.0.52
Domain Name Server 85.113.62.225, 85.113.63.225
Device Time : Mon Aug 20 00:16:21 2007
СообщениеДобавлено: Чт сен 27, 2007 15:50
На сетевом адаптере выставлено "Получать ip-адрес автоматически"? DNS тоже надо получать автоматически. С компьютера пинги куда-нибудь проходят? Попробуйте пропинговать DNS-сервер провайдера. Если пинг пройдет, то попробуйте yandex.ru.
СообщениеДобавлено: Чт сен 27, 2007 16:24
Заработал... Проблема была как раз в этом...
Спасибо.
