Текущее время: Вс ноя 08, 2026 03:18
СообщениеДобавлено: Вт сен 04, 2007 21:06
Купил и поставил DI-524... но вот заметил, что инет стал жуто не стабильным (по скорости) ... работает только один компютер поэтому трафик ничто не должно отжирать, но качество интернета ухудшилось значительно!!! Инет работает на PPoE....
Вот логи:
WAN Type: PPP over Ethernet (V2.03)
Display time: Tuesday September 04, 2007 21:03:03
Sunday September 02, 2007 12:58:09 IPCP3: DNS0 is 84.47.161.254
Sunday September 02, 2007 12:58:09 PPP3: Tx IPCP Reguest
Sunday September 02, 2007 12:58:09 PPP3: Rx IPCP ACK
Sunday September 02, 2007 13:52:12 Unrecognized attempt blocked from 77.77.3.114:14159 to 10.10.36.150 UDP:41482
Sunday September 02, 2007 13:52:38 Unrecognized attempt blocked from 24.18.199.148:20320 to 10.10.36.150 UDP:41482
Sunday September 02, 2007 14:00:27 Unrecognized attempt blocked from 124.88.24.81:16573 to 10.10.36.150 UDP:41482
Sunday September 02, 2007 14:11:14 Associated: 00-19-D2-33-38-DE st=0
Sunday September 02, 2007 14:27:00 Disassociated: 00-19-D2-33-38-DE because idle 300 seconds
Sunday September 02, 2007 16:57:26 Syn time: Sun Sep 02 16:57:32 2007
Sunday September 02, 2007 23:17:11 Syn time: Sun Sep 02 23:17:15 2007
Display time: Tuesday September 04, 2007 21:03:27
Monday September 03, 2007 00:36:47 PPPoE start to hang-up
Monday September 03, 2007 00:36:52 PADT sent
Monday September 03, 2007 08:48:14 DOD:192.168.0.150 query DNS for
Monday September 03, 2007 08:48:14 PPPoE start to dial-up
Monday September 03, 2007 08:48:14 PADI sent
Monday September 03, 2007 08:48:14 PADO recv 0016 g1
Monday September 03, 2007 08:48:14 PADR sent
Monday September 03, 2007 08:48:14 PADS recv 8002 1C5D
Monday September 03, 2007 08:48:16 PPP3: Rx LCP Request
Display time: Tuesday September 04, 2007 21:03:36
Monday September 03, 2007 08:48:17 PPP3: TX LCP Reject
Monday September 03, 2007 08:48:17 PPP3: Rx LCP Request
Monday September 03, 2007 08:48:17 PPP3: TX LCP ACK
Monday September 03, 2007 08:48:17 PPP3: TX LCP Request
Monday September 03, 2007 08:48:17 PPP3: Rx LCP ACK
Monday September 03, 2007 08:48:17 CHAP3: OK
Monday September 03, 2007 08:48:17 PPP3: Tx IPCP Reguest
Monday September 03, 2007 08:48:17 PPP3: Rx IPCP Request
Monday September 03, 2007 08:48:17 PPP3: Rx IPCP NACK/REJECT
Monday September 03, 2007 08:48:17 IPCP3: DNS1 is unknown
Display time: Tuesday September 04, 2007 21:03:48
Monday September 03, 2007 08:48:17 IPCP3: IP is 10.10.36.150
Monday September 03, 2007 08:48:17 IPCP3: DNS0 is 84.47.161.254
Monday September 03, 2007 08:48:17 PPP3: Rx IPCP ACK
Monday September 03, 2007 08:48:21 Syn time: Mon Sep 03 08:48:25 2007
Monday September 03, 2007 08:53:17 PPPoE start to hang-up
Monday September 03, 2007 08:53:22 PADT sent
Monday September 03, 2007 08:58:50 DOD:192.168.0.150 query DNS for ctnews.creative.com
Display time: Tuesday September 04, 2007 21:04:02
Monday September 03, 2007 08:58:49 PPPoE start to dial-up
Monday September 03, 2007 08:58:49 PADI sent
Monday September 03, 2007 08:58:49 PADO recv 0016 g1
Monday September 03, 2007 08:58:49 PADR sent
Monday September 03, 2007 08:58:49 PADS recv 8002 5D5D
Monday September 03, 2007 08:58:51 PPP3: Rx LCP Request
Monday September 03, 2007 08:58:51 PPP3: TX LCP Reject
Monday September 03, 2007 08:58:51 PPP3: TX LCP ACK
Monday September 03, 2007 08:58:51 PPP3: TX LCP Request
ЭТО ПОСЛЕДНИИ 5 страниц дальше не стал копировать там 45 страниц!
НАСТРАИВАЛ роутер по инструкции через Визард!!!
ВОТ СТАТС(на всякий случай) :
Receive Transmit
WAN 3899 Packets 1458 Packets
LAN 2123 Packets 2035 Packets
LAN 0 Packets 28 Packets
ЗАРАНЕЕ спасибо!
СообщениеДобавлено: Ср сен 05, 2007 10:46
Обновите прошивку
ftp://ftp.dlink.ru/pub/Router/DI-524/Fi ... 206bRU.zip
СообщениеДобавлено: Ср сен 05, 2007 16:48
Хорошо, спасибо =) а это даст какие-то изменения в лучшую сторону? и где можно почитать про изменения внесённые в прошивку ??
СообщениеДобавлено: Чт сен 06, 2007 07:18
Вырубите логи. Он перестанет сообщать о всякой нечести в сети, но должен быстрее работать. И не грется :D
СообщениеДобавлено: Чт сен 06, 2007 21:50
Попробую.. Гдеже всё таки найти список нововведение с это прошивкой 20070130_524_V206bRU ??? Хочу посмотреть прежде чем ставить... т.к. скажем у меня работает интернет и локалка однавременно, не смотря на то, что люди жалуються!!!
Сейчас стоит: Firmware Version: V2.03, Fri, Dec 09 2005
СообщениеДобавлено: Пт сен 07, 2007 10:26
Поиском сможете найти тему с полным описанием нововедений, на память это официальный роутинг и поддержка Multicast...
В вашей прошивке есть роутинг, но он скрытый.
В 2.06 роутинг официальный.
Но оба роутинга не работают с PPPoE. Отсюда вывод - Ваш провайдер позаботился о Вас и заодно о себе - настроил роутинг сам на своем оборудовании и разгрузил свою службу поддержки.
СообщениеДобавлено: Пт сен 07, 2007 10:39
Список изменений:
ftp://ftp.dlink.ru/pub/Router/DI-524/Fi ... _206Ru.txt
