Текущее время: Ср ноя 04, 2026 09:35
Начать новую тему Ответить на тему  [ Сообщений: 24 ]  На страницу Пред.  1, 2
 Заголовок сообщения: ответ
СообщениеДобавлено: Сб ноя 11, 2006 14:20
Beliar
Спасибо за ответ. Мне сказали,что провайдер меняет DNS. Может из-за этого проблемы.
вот Log
WAN Type: PPTP (v1.06b04)
Display time: Saturday November 11, 2006 12:47:31
Saturday November 11, 2006 12:42:45 DOD:triggered internally
Saturday November 11, 2006 12:42:45 PPTP start to dial-up
Saturday November 11, 2006 12:42:45 DHCP:discover(My Host)
Saturday November 11, 2006 12:42:49 DHCP:discover(My Host)
Saturday November 11, 2006 12:42:49 DHCP:offer(10.14.1.208)
Saturday November 11, 2006 12:42:49 DHCP:request(10.14.1.90)
Saturday November 11, 2006 12:42:49 DHCP:ack(DOL=345600,T1=172800,T2=302400)
Saturday November 11, 2006 12:42:49 PPTP server=213.33.170.11 ppp.ultranet.ru
Saturday November 11, 2006 12:43:19 DHCP:release
Saturday November 11, 2006 12:43:43 Set Device Time to: Sat Nov 11 12:43:43 2006
Saturday November 11, 2006 12:43:54 PPTP:error=-112
Saturday November 11, 2006 12:43:55 DOD:UDP trigger from 192.168.0.151:2048 to 192.168.1.2:514
Saturday November 11, 2006 12:43:55 PPTP start to dial-up
Saturday November 11, 2006 12:43:55 DHCP:discover(My Host)
Saturday November 11, 2006 12:43:55 DHCP:offer(10.14.1.208)
Saturday November 11, 2006 12:43:55 DHCP:request(10.14.1.92)
Saturday November 11, 2006 12:43:55 DHCP:ack(DOL=345600,T1=172800,T2=302400)
Saturday November 11, 2006 12:44:02 PPTP server=213.33.170.11 ppp.ultranet.ru
Saturday November 11, 2006 12:44:32 DHCP:release
Saturday November 11, 2006 12:45:06 PPTP:error=-112
Display time: Saturday November 11, 2006 12:48:13
Saturday November 11, 2006 12:45:14 DOD:UDP trigger from 192.168.0.151:2048 to 192.168.1.2:514
Saturday November 11, 2006 12:45:14 PPTP start to dial-up
Saturday November 11, 2006 12:45:14 DHCP:discover(My Host)
Saturday November 11, 2006 12:45:15 DHCP:offer(10.14.1.208)
Saturday November 11, 2006 12:45:15 DHCP:request(10.14.1.94)
Saturday November 11, 2006 12:45:15 DHCP:ack(DOL=345600,T1=172800,T2=302400)
Saturday November 11, 2006 12:45:21 PPTP server=213.33.170.11 ppp.ultranet.ru
Saturday November 11, 2006 12:45:51 DHCP:release
Saturday November 11, 2006 12:46:25 PPTP:error=-112
Saturday November 11, 2006 12:46:25 DOD:triggered internally
Saturday November 11, 2006 12:46:25 PPTP start to dial-up
Saturday November 11, 2006 12:46:25 DHCP:discover(My Host)
Saturday November 11, 2006 12:46:26 DHCP:offer(10.14.1.208)
Saturday November 11, 2006 12:46:26 DHCP:request(10.14.1.99)
Saturday November 11, 2006 12:46:26 DHCP:ack(DOL=345600,T1=172800,T2=302400)
Saturday November 11, 2006 12:46:32 PPTP server=213.33.170.11 ppp.ultranet.ru
Saturday November 11, 2006 12:47:02 DHCP:release
Saturday November 11, 2006 12:47:36 PPTP:error=-112
Saturday November 11, 2006 12:47:36 DOD:UDP trigger from 192.168.0.151:2048 to 192.168.1.2:514
Display time: Saturday November 11, 2006 12:48:27
Saturday November 11, 2006 12:47:36 PPTP start to dial-up
Saturday November 11, 2006 12:47:36 DHCP:discover(My Host)
Saturday November 11, 2006 12:47:36 DHCP:offer(10.14.1.208)
Saturday November 11, 2006 12:47:36 DHCP:request(10.14.1.103)
Saturday November 11, 2006 12:47:36 DHCP:ack(DOL=345600,T1=172800,T2=302400)
Saturday November 11, 2006 12:47:43 PPTP server=213.33.170.11 ppp.ultranet.ru
Saturday November 11, 2006 12:48:13 DHCP:release
СообщениеДобавлено: Сб ноя 11, 2006 14:23
А если прописать IP адрес PPTP сервера вместо имени?
СообщениеДобавлено: Сб ноя 11, 2006 14:40
Beliar
Так я и сделал сейчас.....теперь остается ждать.Самое неприятное не поймешь, проблема исчерпана или нет.Так что буду ждать, когда начнет дисконект (надеюсь, что никогда).Спасибо огромное.[/url]
Как в DI-824VUP+. ( Firmware Version: v1.06b04, Fri, Sep 08 2006). Вписать свой DNS. Не могу найти в настройках роутера. Где PPTP настраиваю, там не вижу. Это наверняка исправит проблемы, потому что по log видно, что роутер пытается соединится к старому DNS, который уже убрали.
СообщениеДобавлено: Сб ноя 11, 2006 14:58
Возможно стоит прописать DNS в режиме Static IP и он его запомнит. Отдельной настройки в режиме PPTP нет.
СообщениеДобавлено: Сб ноя 11, 2006 15:02
Я все прописал в режиме Stat,но там не могу найти DNS
Вот какой выбор в настройках.
PPTP
Dynamic IP Static IP
My IP Address
My Subnet Mask
My Gateway
Server IP/Name
PPTP Account
PPTP Password
Retype Password
Connection ID (Optional)
Maximum Idle Time Minutes
MTU
Connect mode select Always-on Manual Connect-on-demand
Change the TTL value Enabled Disabled
Auto-backup Enabled Disabled
СообщениеДобавлено: Сб ноя 11, 2006 15:31
Я имел ввиду режим роутера "Static IP" в закладке WAN.
В режиме "PPTP" нет настроек DNS.
СообщениеДобавлено: Сб ноя 11, 2006 15:53
Мы об одном говорим.
У меня все также,негде внести DNS.
а админи тут не известно,чем занимаются....подсказки они наверное за отдельную плату делают.
СообщениеДобавлено: Сб ноя 11, 2006 16:07
Роутер запоминает MAC адрес введеный в режиме Dynamic IP и использует его и в других режимах.
Так он может запоминать DNS введенный в режиме Static IP и использовать его поумолчанию в других режимах, даже если там нельзя напрямую задать DNS.[/img]
СообщениеДобавлено: Сб ноя 11, 2006 16:08
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 54
