Текущее время: Пн ноя 02, 2026 23:31
 Заголовок сообщения: VPN dfl-1500 and di-808hv
СообщениеДобавлено: Вт сен 05, 2006 12:28
Прописал туннели на обоих устройствах, привожу пример логов ... не могу понять в чём проблема
на dfl-1500 ip 195.5.....
di - 808hv ip 83.249...
2006-09-05 12:10:56 INFO IPsec-SA request for 83.243.... queued due to no phase1 found.
2006-09-05 12:10:56 INFO responde new phase 2 negotiation
2006-09-05 12:10:56 INFO Begin Identity Protection mode.
2006-09-05 12:11:00 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:11:11 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:11:21 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:11:28 INFO Delete phase 2 handler.
2006-09-05 12:11:31 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:11:39 INFO Request for establishing IPsec-SA was queued due to no phase1 found.
2006-09-05 12:11:41 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:11:51 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:11:56 ERROR phase1 negotiation failed due to time up. ca90f8e229de2c27:0000000000000000
2006-09-05 12:12:10 INFO Delete phase 2 handler.
2006-09-05 12:12:23 INFO IPsec-SA request for 83.243.... queued due to no phase1 found.
2006-09-05 12:12:23 INFO responde new phase 2 negotiation
2006-09-05 12:12:23 INFO Begin Identity Protection mode.
2006-09-05 12:12:28 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:12:38 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:12:48 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:12:54 INFO Delete phase 2 handler.
2006-09-05 12:12:58 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:13:07 INFO Request for establishing IPsec-SA was queued due to no phase1 found.
2006-09-05 12:13:08 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:13:18 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:13:23 ERROR phase1 negotiation failed due to time up. 9d8eacde6ce777ca:0000000000000000
2006-09-05 12:13:38 INFO Delete phase 2 handler.
2006-09-05 12:13:51 INFO IPsec-SA request for 83.243.... queued due to no phase1 found.
2006-09-05 12:13:51 INFO responde new phase 2 negotiation
2006-09-05 12:13:51 INFO Begin Identity Protection mode.
2006-09-05 12:13:56 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:14:06 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:14:16 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:14:22 INFO Delete phase 2 handler.
2006-09-05 12:14:26 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:14:35 INFO Request for establishing IPsec-SA was queued due to no phase1 found.
2006-09-05 12:14:36 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:14:46 ERROR Ignore information because the message has no hash payload.
2006-09-05 12:14:51 ERROR phase1 negotiation failed due to time up. 9842f91f6a91e414:0000000000000000
2006-09-05 12:15:06 INFO Delete phase 2 handler.
2006-09-05 12:15:19 INFO IPsec-SA request for 83.243... queued due to no phase1 found.
2006-09-05 12:15:19 INFO responde new phase 2 negotiation
2006-09-05 12:15:19 INFO Begin Identity Protection mode.
2006-09-05 12:15:24 ERROR Ignore information because the message has no hash payload. ----- это лог dfl-1500
uesday September 05, 2006 13:09:53 Receive IKE M1(INIT) : 195.5... --> 83.243...
Tuesday September 05, 2006 13:09:53 Try to match with ENC:DES AUTH:PSK HASH:MD5 Group:Group2
Tuesday September 05, 2006 13:09:58 Send IKE (INFO) : delete 83.243.... -> 195.5... phase 1
Tuesday September 05, 2006 13:09:58 IKE phase1 (ISAKMP SA) remove : 83.243.... <-> 195.5....
Tuesday September 05, 2006 13:10:04 Receive IKE M1(INIT) : 195.5... --> 83.243....
Tuesday September 05, 2006 13:10:04 Try to match with ENC:DES AUTH:PSK HASH:MD5 Group:Group2
Tuesday September 05, 2006 13:10:09 Send IKE (INFO) : delete 83.243... -> 195.5.... phase 1
Tuesday September 05, 2006 13:10:09 IKE phase1 (ISAKMP SA) remove : 83.243.... <-> 195.5....
Tuesday September 05, 2006 13:10:14 Receive IKE M1(INIT) : 195.5.... --> 83.243....
Tuesday September 05, 2006 13:10:14 Try to match with ENC:DES AUTH:PSK HASH:MD5 Group:Group2
а вот и Di-808
подскажите в чем проблема ... заранее спасибо
СообщениеДобавлено: Вт сен 05, 2006 12:42
какая версия прошивки устройств?
СообщениеДобавлено: Вт сен 05, 2006 12:46
dfl-1500 - 2.105
di-808hv - 1.41
СообщениеДобавлено: Вт сен 05, 2006 12:57
808-й обновите до последней -- 1.43
СообщениеДобавлено: Вт сен 05, 2006 13:00
на сайте только 1.140 для DI-808hv, где взять ?
СообщениеДобавлено: Вт сен 05, 2006 13:05
Извините...
Из папки di-804hv
СообщениеДобавлено: Вт сен 05, 2006 13:06
Извините...
Из папки di-804hv
Понял ...спасибо
СообщениеДобавлено: Вт сен 05, 2006 16:11
Извините...
Из папки di-804hv
Понял ...спасибо
Stanislav davaite kinu logi mail ... cituaziyz ne menyaetsay ((( spasibo
