Текущее время: Пн ноя 02, 2026 13:29
СообщениеДобавлено: Пт июн 02, 2006 12:14
Вроде и ошибиться негде. Доку почитал и http://www.tayle.com/documents/27_10_03.php сделал, а туннель с обоих сторон в состоянии Establishing.
Могу дать вэб аксес к обоим только на почту (не хочу в открытом источнике публиковать Ip)
Лог c http://х.х.х.214:8080/:
WAN Type: Static IP Address (V1.42)
Display time: Friday June 02, 2006 18:13:17
Friday June 02, 2006 18:05:33 receiving a re-Tx MM msg, response the last msg
Friday June 02, 2006 18:05:33 IKED re-TX : MM to ххх.ххх.ххх.35
Friday June 02, 2006 18:05:37 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:05:38 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:05:38 receiving a re-Tx MM msg, response the last msg
Friday June 02, 2006 18:05:38 IKED re-TX : MM to ххх.ххх.ххх.35
Friday June 02, 2006 18:05:48 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:05:48 receiving a re-Tx MM msg, response the last msg
Friday June 02, 2006 18:05:48 IKED re-TX : MM to ххх.ххх.ххх.35
Friday June 02, 2006 18:05:49 Send IKE (INFO) : delete х.х.х.214 -> ххх.ххх.ххх.35 phase 1
Friday June 02, 2006 18:05:49 IKE phase1 (ISAKMP SA) remove : х.х.х.214 <-> ххх.ххх.ххх.35
Friday June 02, 2006 18:05:57 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:05:58 Send IKE (INFO) : delete х.х.х.214 -> ххх.ххх.ххх.35 phase 1
Friday June 02, 2006 18:05:58 IKE phase1 (ISAKMP SA) remove : х.х.х.214 <-> ххх.ххх.ххх.35
Friday June 02, 2006 18:05:58 Receive IKE M1(INIT) : ххх.ххх.ххх.35 --> х.х.х.214
Friday June 02, 2006 18:05:58 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group2
Friday June 02, 2006 18:05:58 Send IKE M2(RESP) : х.х.х.214 --> ххх.ххх.ххх.35
Friday June 02, 2006 18:06:04 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:06:09 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:06:18 receiving a re-Tx MM msg, response the last msg
Friday June 02, 2006 18:08:13 IKED re-TX : MM to ххх.ххх.ххх.35
Friday June 02, 2006 18:08:23 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:08:23 receiving a re-Tx MM msg, response the last msg
Friday June 02, 2006 18:08:23 IKED re-TX : MM to ххх.ххх.ххх.35
Friday June 02, 2006 18:08:24 Send IKE (INFO) : delete х.х.х.214 -> ххх.ххх.ххх.35 phase 1
Friday June 02, 2006 18:08:24 IKE phase1 (ISAKMP SA) remove : х.х.х.214 <-> ххх.ххх.ххх.35
Friday June 02, 2006 18:08:32 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:08:33 Send IKE (INFO) : delete х.х.х.214 -> ххх.ххх.ххх.35 phase 1
Friday June 02, 2006 18:08:33 IKE phase1 (ISAKMP SA) remove : х.х.х.214 <-> ххх.ххх.ххх.35
Friday June 02, 2006 18:08:33 Receive IKE M1(INIT) : ххх.ххх.ххх.35 --> х.х.х.214
Friday June 02, 2006 18:08:33 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group2
Friday June 02, 2006 18:08:34 Send IKE M2(RESP) : х.х.х.214 --> ххх.ххх.ххх.35
Friday June 02, 2006 18:08:39 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:08:40 Blocked access attempt from ххх.ххх.ххх.35:58147 to TCP port 8080
Friday June 02, 2006 18:08:43 Blocked access attempt from ххх.ххх.ххх.35:58147 to TCP port 8080
Friday June 02, 2006 18:08:44 IKED re-TX : RESP to ххх.ххх.ххх.35
Friday June 02, 2006 18:08:49 Blocked access attempt from ххх.ххх.ххх.35:58147 to TCP port 8080
Friday June 02, 2006 18:08:53 receiving a re-Tx MM msg, response the last msg
Friday June 02, 2006 18:08:53 IKED re-TX : MM to ххх.ххх.ххх.35
Friday June 02, 2006 18:08:54 Receive IKE INFO : ххх.ххх.ххх.35 --> х.х.х.214
Лог c http://ххх.ххх.ххх.35:8080/:
Display time: Friday June 02, 2006 18:16:03
Friday June 02, 2006 17:51:49 Send IKE M1(INIT) : ххх.ххх.ххх.35 --> х.х.х.214
Friday June 02, 2006 17:51:54 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:51:59 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:52:09 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:52:19 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:52:39 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:52:40 Send IKE (INFO) : delete ххх.ххх.ххх.35 -> х.х.х.214 phase 1
Friday June 02, 2006 17:52:40 IKE phase1 (ISAKMP SA) remove : ххх.ххх.ххх.35 <-> х.х.х.214
Friday June 02, 2006 17:52:40 Send IKE M1(INIT) : ххх.ххх.ххх.35 --> х.х.х.214
Friday June 02, 2006 17:52:45 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:52:50 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:53:00 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:53:10 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:53:30 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:53:31 Send IKE (INFO) : delete ххх.ххх.ххх.35 -> х.х.х.214 phase 1
Friday June 02, 2006 17:53:31 IKE phase1 (ISAKMP SA) remove : ххх.ххх.ххх.35 <-> х.х.х.214
Friday June 02, 2006 17:53:31 Send IKE M1(INIT) : ххх.ххх.ххх.35 --> х.х.х.214
Friday June 02, 2006 17:53:37 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:53:42 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:53:52 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:54:02 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:54:22 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:54:23 Send IKE (INFO) : delete ххх.ххх.ххх.35 -> х.х.х.214 phase 1
Friday June 02, 2006 17:54:23 IKE phase1 (ISAKMP SA) remove : ххх.ххх.ххх.35 <-> х.х.х.214
Friday June 02, 2006 17:54:24 Send IKE M1(INIT) : ххх.ххх.ххх.35 --> х.х.х.214
Friday June 02, 2006 17:54:29 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:54:34 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:54:44 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:54:54 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:55:14 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:55:15 Send IKE (INFO) : delete ххх.ххх.ххх.35 -> х.х.х.214 phase 1
Friday June 02, 2006 17:55:15 IKE phase1 (ISAKMP SA) remove : ххх.ххх.ххх.35 <-> х.х.х.214
Friday June 02, 2006 17:55:15 Send IKE M1(INIT) : ххх.ххх.ххх.35 --> х.х.х.214
Friday June 02, 2006 17:55:20 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:55:25 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:55:35 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:55:45 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:56:05 IKED re-TX : INIT to х.х.х.214
Friday June 02, 2006 17:56:06 Send IKE (INFO) : delete ххх.ххх.ххх.35 -> х.х.х.214 phase 1
СообщениеДобавлено: Пт июн 02, 2006 13:18
Проверяйте Proposals и точно ли указаны удаленные подсети и шлюзы.
СообщениеДобавлено: Пт июн 02, 2006 14:39
Отправил скриншоты вам на почту
СообщениеДобавлено: Пн июн 05, 2006 12:33
У маршрутизатора на провайдера были закрыты порты.
Тунель поднялся.
Однако даже с самих маршрутизаторов LAN ip адреса не пингуются т.е. с 35 не пингуется Lan ip адрес 214-го, а с 214 не пингуется Lan ip адрес 35-го.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 136
