Текущее время: Вт ноя 03, 2026 11:43
 Заголовок сообщения: DI-804 HV открыть порты
СообщениеДобавлено: Вс апр 02, 2006 00:45
Доброе время суток.
Пользуюсь выше указанным девайсом уже 2 года. Раньше когда мне надо было открыть порты (из вне ко внутренему компьютеру) я пользовался Virtual Server. Возникла необходимость открыть диапазон портов, Virtual Server этого сделать не позволяет. Порылся в документации к роутеру и нашел слудущее
How do I open a range of ports on my DI-804HV using Firewall rules?
Step 1 Access the router’s web configuration by entering the router’s IP Address in your web browser. The default IP Address is 192.168.0.1. Login using your password. The default username is “admin” and the password is blank. If you are having difficulty accessing web management, please see the first questionin this section.
Step 2 From the web management Home page, click the Advanced tab then click the Firewall button.
Step 3 Click on Enabled and type in a name for the new rule.
Step 4 Choose WAN as the Source and enter a range of IP Addresses out  in the internet that you would like this rule applied to. If you would like
this rule to allow all internet users to be able to access these ports, then put an Asterisk in the first box and leave the second box empty.
Step 5 Select LAN as the Destination and enter the IP Address of the computer on your local network that you want to allow the incoming service to. This will not work with a range of IP Addresses.
Step 6 Enter the port or range of ports that are required to be open for the incoming service.
Step 7 Click Apply and then click Continue. Because our routers use NAT (Network Address Translation), you can only open a specific port to one computer at a time. For example: If you have 2 web servers on
your network, you cannot open port 80 to both computers. You will need to configure 1 of the web servers to use port 81. Now you can open port 80 to the first computer and then open port 81 to the other computer.
Согласно этому ФАКу я могу открыть диапразон портов, которые будут маршрутизироватся из вне на локальный компьютер.
Но вот беда. ни диапазаона портов ни порта таким способом я не открыл. Вопрос почему? С помощью Virtual Server порты открываются без проблем, но правилом FireWall'a ни в какую.
I NEED YOUR HELP!
WBR. Sp!ZER
 Заголовок сообщения: Re: DI-804 HV открыть порты
СообщениеДобавлено: Вс апр 02, 2006 02:45
А в чем выражается невозможность открыть порты? Какие настройки файрвола при этом используются?
best wishes, drserge
СообщениеДобавлено: Вс апр 02, 2006 02:53
FireWall Rules
1. Enabled
2. 123
3. Allow
4. WAN, *
5. LAN, 192.168.1.1, , TCP, 7900 , 8000
6. Always
7. Apply
Правило добавляется. а трафик пришедший на порт с 7900 до 8000 не передается внутрь на 192.168.1.1. Добавление в Virual Server все работает как надо. Но проблема в том что нужено добавить диапазон.
DMZ выключен
WBR. Sp!ZER
СообщениеДобавлено: Вс апр 02, 2006 14:22
Подтверждаю, данная функция (Port Forwarding с использованием правила Firewall) не работает (проверил), причем не работает не только с диапазонами, но и с одиночными портами, не смотря на явное описание этой возможности в документации.
PS: А какая прошивка используется? У меня не поддерживаемая официально в России 1.43...
СообщениеДобавлено: Вс апр 02, 2006 14:25
СообщениеДобавлено: Вс апр 02, 2006 14:30
Current Firmware Version: V1.40
Firmware Date: Thu, Aug 12 2004
Кстати единственная, котороая корректно работает на данном девайсе.
WBR. Sp!ZER
СообщениеДобавлено: Вс апр 02, 2006 17:39
Видимо, не вполне корректно :-)
СообщениеДобавлено: Вс апр 02, 2006 20:41
Я имел ввиду корректно работает с VPN и не выкидывает сообщения о совпадении "маков"
WBR. Sp!ZER
СообщениеДобавлено: Вс апр 02, 2006 22:45
Sp!ZER писал(а):
[Current Firmware Version: V1.40
Ну, подобных проблем в моей 1,43 я не встречал, да и еще несколько человек, уже поставивших эту прошивку, тоже ни о чем подобном не упоминали. Правда, официально она не поддерживается (будем надеяться, только пока).
СообщениеДобавлено: Вс апр 02, 2006 22:57
Я бы даже ее поставил если бы удалось открыть порты в ней.
WBR. Sp!ZER
СообщениеДобавлено: Вс апр 02, 2006 23:47
но, к сожалению, в ней это тоже не получается сделать...
СообщениеДобавлено: Вт апр 04, 2006 01:33
Инетрестно, а чего молчит наша тех поддержка?
WBR. Sp!ZER
