Текущее время: Пн ноя 02, 2026 10:44
 Заголовок сообщения: G604T в режиме маршрут.
СообщениеДобавлено: Чт мар 30, 2006 17:17
помогите подалуйста решить вопрос. Есть аршрутизатор g604t. Сеть - Стрим. У меня никак не получатся настроить роутер в режиме маршрутизатор В режиме моста все работает нормально. Я делаю все как у вас укказаено в "Часто задаваемых вопросах", но ниче не выходит., пробовал и черезх ethernet и через wifi - одно и тоже. Вот мой лог после этого:
Sep 8 14:02:25> Connection terminated.
Sep 8 14:02:25> Doing disconnect
Sep 8 14:02:25> Failed to Authenicate
Sep 8 14:02:27> pppd 2.4.1 started by root, uid 0
Sep 8 14:02:27> Connecting PPPoE socket: 00:30:88:00:66:92 4714 nas0 0x1000d3b8
Sep 8 14:02:27> Connect: ppp0 {--} nas0
Sep 8 14:02:28> CHAP authentication failed
Sep 8 14:02:34> Connection terminated.
Sep 8 14:02:34> Failed to Authenicate
Sep 8 14:02:34> Doing disconnect
Sep 8 14:02:34> pppd 2.4.1 started by root, uid 0
Sep 8 14:02:34> Connecting PPPoE socket: 00:30:88:00:66:92 9805 nas0 0x1000d3b8
Sep 8 14:02:34> Connect: ppp0 {--} nas0
Sep 8 14:02:34> CHAP authentication failed
Sep 8 14:02:40> Connection terminated.
Sep 8 14:02:40> Doing disconnect
Sep 8 14:02:40> Failed to Authenicate
Sep 8 14:02:46> pppd 2.4.1 started by root, uid 0
Sep 8 14:02:56> Connecting PPPoE socket: 00:30:88:00:66:92 413b nas0 0x1000d3b8
Sep 8 14:02:56> Connect: ppp0 {--} nas0
Sep 8 14:02:56> CHAP authentication failed
Sep 8 14:03:02> Connection terminated.
Sep 8 14:03:02> Doing disconnect
Sep 8 14:03:02> Failed to Authenicate
Sep 8 14:03:08> pppd 2.4.1 started by root, uid 0
Sep 8 14:03:08> Connecting PPPoE socket: 00:30:88:00:66:92 4733 nas0 0x1000d3b8
Sep 8 14:03:08> Connect: ppp0 {--} nas0
Sep 8 14:03:08> CHAP authentication failed
Sep 8 14:03:14> Connection terminated.
Sep 8 14:03:14> Doing disconnect
Sep 8 14:03:14> Failed to Authenicate
Sep 8 14:03:20> pppd 2.4.1 started by root, uid 0
Sep 8 14:03:20> Connecting PPPoE socket: 00:30:88:00:66:92 f545 nas0 0x1000d3b8
Sep 8 14:03:20> Connect: ppp0 {--} nas0
Sep 8 14:03:20> CHAP authentication failed
Sep 8 14:03:20> Connection terminated.
Sep 8 14:03:20> Doing disconnect
Sep 8 14:03:20> Failed to Authenicate
Sep 8 14:03:25> pppd 2.4.1 started by root, uid 0
Sep 8 14:03:25> Connecting PPPoE socket: 00:30:88:00:66:92 de47 nas0 0x1000d3b8
Sep 8 14:03:25> Connect: ppp0 {--} nas0
Sep 8 14:03:26> CHAP authentication failed
Sep 8 14:03:26> Failed to Authenicate
Sep 8 14:03:26> Connection terminated.
Sep 8 14:03:26> Doing disconnect
Sep 8 14:03:26> pppd 2.4.1 started by root, uid 0
Sep 8 14:03:36> Connecting PPPoE socket: 00:30:88:00:66:92 6628 nas0 0x1000d3b8
Sep 8 14:03:36> Connect: ppp0 {--} nas0
Sep 8 14:03:38> CHAP authentication failed
Sep 8 14:03:42> Failed to Authenicate
Sep 8 14:03:42> Connection terminated.
Sep 8 14:03:42> Doing disconnect
Sep 8 14:03:43> pppd 2.4.1 started by root, uid 0
Sep 8 14:03:43> Connecting PPPoE socket: 00:30:88:00:66:92 0826 nas0 0x1000d3b8
Sep 8 14:03:43> Connect: ppp0 {--} nas0
Sep 8 14:03:43> CHAP authentication failed
Sep 8 14:03:49> Failed to Authenicate
Sep 8 14:03:49> Connection terminated.
Sep 8 14:03:49> Doing disconnect
Sep 8 14:03:50> pppd 2.4.1 started by root, uid 0
Sep 8 14:03:50> Connecting PPPoE socket: 00:30:88:00:66:92 f945 nas0 0x1000d3b8
Sep 8 14:03:50> Connect: ppp0 {--} nas0
Sep 8 14:03:50> CHAP authentication failed
Sep 8 14:03:56> Connection terminated.
Sep 8 14:03:56> Doing disconnect
Sep 8 14:03:56> Failed to Authenicate
Sep 8 14:04:02> pppd 2.4.1 started by root, uid 0
Sep 8 14:04:02> Connecting PPPoE socket: 00:30:88:00:66:92 9702 nas0 0x1000d3b8
Sep 8 14:04:02> Connect: ppp0 {--} nas0
Sep 8 14:04:02> CHAP authentication failed
Sep 8 14:04:03> Connection terminated.
Sep 8 14:04:03> Doing disconnect
Sep 8 14:04:03> Failed to Authenicate
Sep 8 14:04:06> pppd 2.4.1 started by root, uid 0
Sep 8 14:04:07> Connecting PPPoE socket: 00:30:88:00:66:92 0c43 nas0 0x1000d3b8
Sep 8 14:04:07> Connect: ppp0 {--} nas0
Sep 8 14:04:07> CHAP authentication failed
Sep 8 14:04:13> Connection terminated.
Sep 8 14:04:15> Doing disconnect
Sep 8 14:05:37> Bridge Interface Added: tiwlan0
Sep 8 14:06:40> Bridge Module is stopping and is set at State = 5
Sep 8 14:06:40> Bridge Created: br0
Sep 8 14:06:40> Bridge Interface Added: nas0
Sep 8 14:06:41> Bridge Interface Added: tiwlan0
Sep 8 14:06:41> Bridge Interface Added: eth0
Sep 8 14:06:41> Add Bridge Iface Error: 1
Sep 8 14:06:41> Duplicate Bridge Iface: tiwlan0
Sep 8 14:06:48> Bridge Interface Added: nas0
Sep 8 14:07:58> Valid Configuration Tree
Sep 8 14:07:59> pppd 2.4.1 started by root, uid 0
Sep 8 14:08:09> Bridge Interface Added: nas0
Sep 8 14:08:52> pppd 2.4.1 started by root, uid 0
Sep 8 14:08:52> Connecting PPPoE socket: 00:30:88:00:66:92 4814 nas1 0x1000d3b8
Sep 8 14:08:52> Connect: ppp0 {--} nas1
Sep 8 14:08:53> CHAP authentication failed
Sep 8 14:08:53> Connection terminated.
Sep 8 14:08:53> Doing disconnect
Sep 8 14:08:53> pppd 2.4.1 started by root, uid 0
Sep 8 14:08:54> Connecting PPPoE socket: 00:30:88:00:66:92 f947 nas1 0x1000d3b8
Sep 8 14:08:54> Connect: ppp0 {--} nas1
Sep 8 14:08:54> CHAP authentication failed
Sep 8 14:08:54> Connection terminated.
Sep 8 14:08:54> Doing disconnect
Sep 8 14:08:54> Failed to Authenicate
Sep 8 14:08:55> pppd 2.4.1 started by root, uid 0
Sep 8 14:08:56> Connecting PPPoE socket: 00:30:88:00:66:92 781a nas1 0x1000d3b8
Sep 8 14:08:56> Connect: ppp0 {--} nas1
Sep 8 14:08:56> CHAP authentication failed
Sep 8 14:08:56> Connection terminated.
Sep 8 14:08:56> Doing disconnect
Sep 8 14:08:56> Failed to Authenicate
Sep 8 14:08:57> pppd 2.4.1 started by root, uid 0
Sep 8 14:08:58> Connecting PPPoE socket: 00:30:88:00:66:92 fa0e nas1 0x1000d3b8
Sep 8 14:08:58> Connect: ppp0 {--} nas1
Sep 8 14:08:58> Connection terminated.
Sep 8 14:09:01> Doing disconnect
Sep 8 14:09:01> pppd 2.4.1 started by root, uid 0
Sep 8 14:09:10> Bridge Interface Added: nas0
Sep 8 14:09:15> Failed to negotiate PPPoE connection: 127
Sep 8 14:09:23> Bridge Interface Added: nas0
Sep 9 12:28:00> Valid Configuration Tree
Sep 9 12:28:00> Bridge Module is stopping and is set at State = 5
Sep 9 12:28:01> Bridge Created: br0
Sep 9 12:28:02> Bridge Interface Added: tiwlan0
Sep 9 12:28:02> Bridge Interface Added: eth0
Sep 9 12:28:02> Add Bridge Iface Error: 1
Sep 9 12:28:02> Duplicate Bridge Iface: tiwlan0
Sep 9 12:28:03> pppd 2.4.1 started by root,
Помогите пожалуйста
 Заголовок сообщения: Re: G604T в режиме маршрут.
СообщениеДобавлено: Чт мар 30, 2006 18:01
Версия прошивки? У вас неправильный логин или пароль задан в роутере.
Бигаров Руслан.
СообщениеДобавлено: Чт мар 30, 2006 18:18
Парольи имя правильные, я же сним с моста захожу, прошивка... software version V1.00B02T02.RU.20041014 это оно?
СообщениеДобавлено: Чт мар 30, 2006 18:26
А лог говорит обратное, хотя могла подвиснуть сессия у провайдера.
Бигаров Руслан.
СообщениеДобавлено: Чт мар 30, 2006 18:40
ну а че делать то? сообраения есть?
СообщениеДобавлено: Чт мар 30, 2006 18:52
Sep 9 14:00:51> Connect: ppp0 {--} nas2
Sep 9 14:00:51> WAN IP address 85.140.150.163
Sep 9 14:00:51> WAN gateway 85.140.150.1
Sep 9 14:00:51> PPPoE Connect with IP Address 85.140.150.163
Sep 9 14:00:51> PPPoE Connection Successfully Established
Sep 9 14:00:51> PPPoE Connect with Gateway IP Address: 85.140.150.1
попробовал еще раз получился такой лог
СообщениеДобавлено: Чт мар 30, 2006 18:53
но инет не коннектится
СообщениеДобавлено: Чт мар 30, 2006 19:20
вроде как получилось
Mar 31 00:13:44> Connect: ppp0 {--} nas0
Mar 31 00:13:44> WAN IP address 85.140.113.41
Mar 31 00:13:44> PPPoE Connect with IP Address 85.140.113.41
Mar 31 00:13:44> WAN gateway 85.140.113.1
Mar 31 00:13:44> primary DNS address 212.188.4.10
Mar 31 00:13:44> secondary DNS address 195.34.32.116
Mar 31 00:13:44> PPPoE Connection Successfully Established
Mar 31 00:13:44> PPPoE Connect with Gateway IP Address: 85.140.113.1
но коннектится только isq болше вообще ничего
СообщениеДобавлено: Чт мар 30, 2006 20:00
Значит роутер законектился у вас проблема в настройках DNS. Как их настроить!? Через "Поиск" в ветке "ADSL и последняя миля" можно найти описание.
Бигаров Руслан.
Сейчас этот форум просматривают: Google [Bot] и гости: 12
