Текущее время: Ср ноя 04, 2026 04:05
 Заголовок сообщения: Подвисание DI-804 и VPN
СообщениеДобавлено: Вт мар 21, 2006 00:24
Здравствйте.
с сабжем регулярно возникает проблема - перестаёт устанавливаться VPN.
При этом инет работает, а доступ к сети через VPN отсутствует - ибо он не устанавливается.
Перезагрузка устройства не спасает. Смена ключей и перенастройка на обоих DI-804 аналогично не спасает.
Лечится проблема передёргиванием питания.
В логахво время проблемы пишется - вот что:
Tuesday March 21, 2006 00:44:16 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:44:16 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:44:26 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:44:26 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:44:46 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:44:46 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:44:47 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:44:47 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:45:05 Restarted by 83.239.80.86
Tuesday March 21, 2006 00:45:16 Blocked access attempt from 83.239.102.59:2884 to TCP port 139
Tuesday March 21, 2006 00:45:19 Blocked access attempt from 83.239.102.59:2884 to TCP port 139
Tuesday March 21, 2006 00:45:41 Receive IKE A1(AINIT) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:45:41 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:45:41 Send IKE A2(ARESP) : [83.239.76.90]-->[83.239.80.86]
Tuesday March 21, 2006 00:45:46 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:45:46 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:45:46 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:45:51 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:45:51 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:45:51 Blocked access attempt from 204.16.208.106:34479 to UDP port 1026
Tuesday March 21, 2006 00:45:51 Blocked access attempt from 204.16.208.106:34479 to UDP port 1027
Tuesday March 21, 2006 00:46:01 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:46:01 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:46:11 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:46:11 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:46:12 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:46:12 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:46:31 Receive IKE A1(AINIT) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:46:31 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:46:31 Send IKE A2(ARESP) : [83.239.76.90]-->[83.239.80.86]
Tuesday March 21, 2006 00:46:32 Receive IKE INFO : 83.239.80.86 --> 83.239.76.90
Tuesday March 21, 2006 00:46:37 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:46:38 Receive IKE A1(AINIT) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:46:38 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:46:39 Send IKE A2(ARESP) : [83.239.76.90]-->[83.239.80.86]
Tuesday March 21, 2006 00:46:42 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:46:44 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:46:44 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:46:44 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:46:49 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:46:49 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:46:52 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:46:59 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:46:59 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:47:02 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:47:09 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:47:09 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:47:10 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:47:09 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:47:21 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:47:22 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:47:22 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:47:29 Receive IKE A1(AINIT) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:47:29 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:47:29 Send IKE A2(ARESP) : [83.239.76.90]-->[83.239.80.86]
Tuesday March 21, 2006 00:47:30 Receive IKE INFO : 83.239.80.86 --> 83.239.76.90
Tuesday March 21, 2006 00:47:34 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:47:39 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:47:49 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:48:00 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:48:20 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:48:21 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:48:21 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:49:22 Restarted by 83.239.80.86
Tuesday March 21, 2006 00:50:22 Restarted by 83.239.80.86
Tuesday March 21, 2006 00:51:31 Send IKE A1(AINIT) : 83.239.76.90 --> 83.239.80.86
Tuesday March 21, 2006 00:51:32 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:51:32 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:51:37 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:51:37 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:51:37 IKED re-TX : AINIT to 83.239.80.86
Tuesday March 21, 2006 00:51:42 IKED re-TX : AINIT to 83.239.80.86
Tuesday March 21, 2006 00:51:42 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:51:42 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:51:52 IKED re-TX : AINIT to 83.239.80.86
Tuesday March 21, 2006 00:51:52 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:51:52 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:52:02 IKED re-TX : AINIT to 83.239.80.86
Tuesday March 21, 2006 00:52:02 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:52:02 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:52:03 Receive IKE INFO : 83.239.80.86 --> 83.239.76.90
Tuesday March 21, 2006 00:52:22 IKED re-TX : AINIT to 83.239.80.86
Tuesday March 21, 2006 00:52:23 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:52:23 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:52:23 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:52:23 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:53:43 Restarted by 83.239.80.86
Tuesday March 21, 2006 00:54:19 Receive IKE A1(AINIT) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:54:19 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:54:19 Send IKE A2(ARESP) : [83.239.76.90]-->[83.239.80.86]
Tuesday March 21, 2006 00:54:24 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:54:24 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:54:29 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:54:29 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:54:39 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:54:42 Receive IKE INFO : 83.239.80.86 --> 83.239.76.90
Tuesday March 21, 2006 00:54:49 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:55:05 Receive IKE A1(AINIT) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:55:05 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:55:06 Send IKE A2(ARESP) : [83.239.76.90]-->[83.239.80.86]
Tuesday March 21, 2006 00:55:09 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:55:10 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:55:10 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:55:10 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:55:11 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:55:11 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:55:16 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:55:16 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:55:25 Blocked access attempt from 221.203.189.44:48060 to UDP port 1026
Tuesday March 21, 2006 00:55:26 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:55:26 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:55:26 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:55:27 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:55:27 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:55:36 Receive IKE A1(AINIT) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 00:55:36 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday March 21, 2006 00:55:36 Send IKE A2(ARESP) : [83.239.76.90]-->[83.239.80.86]
Tuesday March 21, 2006 00:55:41 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:55:46 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:55:56 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:55:56 receiving a re-Tx MM msg, response the last msg
Tuesday March 21, 2006 00:55:56 IKED re-TX : MM to 83.239.80.86
Tuesday March 21, 2006 00:55:57 Receive IKE INFO : 83.239.80.86 --> 83.239.76.90
Tuesday March 21, 2006 00:56:16 IKED re-TX : ARESP to 83.239.80.86
Tuesday March 21, 2006 00:56:17 Send IKE (INFO) : delete 83.239.76.90 -> 83.239.80.86 phase 1
Tuesday March 21, 2006 00:56:17 IKE phase1 (ISAKMP SA) remove : 83.239.76.90 <-> 83.239.80.86
Tuesday March 21, 2006 00:56:41 Blocked access attempt from 83.239.102.60:2415 to TCP port 139
Tuesday March 21, 2006 00:56:44 Blocked access attempt from 83.239.102.60:2415 to TCP port 139
Tuesday March 21, 2006 01:00:31 Restarted by 83.239.80.86
Tuesday March 21, 2006 01:00:59 Send IKE A1(AINIT) : 83.239.76.90 --> 83.239.80.86
Tuesday March 21, 2006 01:00:59 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 01:01:20 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
Tuesday March 21, 2006 01:00:32 Restarted by 83.239.80.86
Tuesday March 21, 2006 01:01:00 Send IKE A1(AINIT) : 83.239.76.90 --> 83.239.80.86
Tuesday March 21, 2006 01:01:00 Receive IKE A2(ARESP) : [83.239.80.86]-->[83.239.76.90]
....до бесконечности...
спасибо.
 Заголовок сообщения: Re: Подвисание DI-804 и VPN
СообщениеДобавлено: Вт мар 21, 2006 10:56
укажите версию FW и более подробно по настройкам, все это, включая логи, по почте на support@dlink.ru, пожалуйста.
Сейчас этот форум просматривают: Google [Bot] и гости: 20
