Текущее время: Чт окт 08, 2026 19:53
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 2 ]
СообщениеДобавлено: Вт июн 02, 2009 05:56
Здравствуйте.
Имеется коммутатор DES-3526
FW 6.00.B14
В самой программе D-View: коммутатор отображается нормально, т.е им можно управлять. Но трапы не шлет :?
Код конфига:
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp view restricted all
delete snmp view CommunityView all
config snmp engineID 800000ab0300179a7a9500
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group initial v3  noauth_nopriv read_view restricted notify_view restricted
create snmp group private v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group private v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group ReadGroup v1 read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v2c read_view CommunityView notify_view CommunityView
create snmp group WriteGroup v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group WriteGroup v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp community private view CommunityView read_write
create snmp community public view CommunityView read_only
create snmp user initial initial
create snmp host 192.168.0.53 v1  private
Больше на этом коммутаторе настроек нет.
перепробовала и кучу других настроек на коммутаторе, но результат один и тот- же (трапов нет).
Предполагаю, что надо что-то творить с MIB-ами
PS: В D-View я новичек, поэтому поподробнее :wink:
Заранее спасибо
PPS: если использовать для получения трапов только по snmp v1, то остальные можно удалять? (также с v2c и v3)
СообщениеДобавлено: Вт июн 02, 2009 13:41
проблема решена командой
create syslog host...........
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 65
