Текущее время: Вт окт 06, 2026 20:37
СообщениеДобавлено: Пн мар 30, 2009 02:00
Добрый день !
Столкнулся со следующей проблемой.
На свиче
Device Type DGS-3612G Gigabit Ethernet Switch
Boot PROM Version Build 1.10-B09
Firmware Version Build 2.50.B15
Hardware Version A1 ?
Serial Number P1J5185000701 ?
сконфигурирован DHCP сервер :
# DGS-3612G Gigabit Ethernet Switch
# Configuration
# Firmware: Build 2.50.B15
# Copyright(C) 2008 D-Link Corporation. All rights reserved.
# DOUBLE_VLAN
disable double_vlan
# BASIC
# ACCOUNT LIST
# ACCOUNT END
config serial_port auto_logout 10_minutes
enable telnet 23
enable web 80
enable clipaging
# STORM
config traffic trap both
config traffic control 1-11 broadcast enable multicast enable unicast enable action drop threshold 1310 countdown 5 time_interval 5
config traffic control 12 broadcast enable multicast enable unicast enable action drop threshold 131072 countdown 5 time_interval 5
# LOOP_DETECT
# GM
config sim candidate
disable sim
config sim dp_interval 30
config sim hold_time 100
# GM_H
# SYSLOG
disable syslog
config system_severity log information
config system_severity trap warning
create syslog host 1 severity all facility local0 udp_port 514 ipaddress 172.25.4.91 state enable
create syslog host 2 severity all facility local0 udp_port 514 ipaddress 172.25.4.1 state enable
create syslog host 3 severity all facility local0 udp_port 514 ipaddress 172.25.4.2 state enable
config log_save_timing on_demand
# QOS
config scheduling_mechanism strict
config scheduling 0 max_packet 1
config scheduling 1 max_packet 2
config scheduling 2 max_packet 3
config scheduling 3 max_packet 4
config scheduling 4 max_packet 5
config scheduling 5 max_packet 6
config scheduling 6 max_packet 7
config 802.1p user_priority 0 2
config 802.1p user_priority 1 0
config 802.1p user_priority 2 1
config 802.1p user_priority 3 3
config 802.1p user_priority 4 4
config 802.1p user_priority 5 5
config 802.1p user_priority 6 6
config 802.1p user_priority 7 6
enable hol_prevention
config 802.1p default_priority 1-12 0
config bandwidth_control 1-12 rx_rate no_limit tx_rate no_limit
# MIRROR
disable mirror
# TRAF-SEGMENTATION
config traffic_segmentation 1-8,11 forward_list 9-10,12
config traffic_segmentation 9,12 forward_list 1-8,10-11
config traffic_segmentation 10 forward_list 1-9,11-12
# SSL
disable ssl
enable ssl ciphersuite RSA_with_RC4_128_MD5
enable ssl ciphersuite RSA_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite DHE_DSS_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite RSA_EXPORT_with_RC4_40_MD5
config ssl cachetimeout 600
# PORT
disable jumbo_frame
config ports 1-8 speed auto capability_advertised 100_full 1000_full flow_control disable learning enable state enable
config ports 9-12 medium_type copper speed auto capability_advertised 10_half 10_full 100_half 100_full 1000_full flow_control disable learning enable state enable
config ports 9-12 medium_type fiber speed auto capability_advertised 100_full 1000_full flow_control disable learning enable state enable
# PORT_LOCK
config port_security ports 1-12 admin_state disable max_learning_addr 1 lock_address_mode DeleteOnReset
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp group ReadGroup
delete snmp group WriteGroup
delete snmp view restricted all
delete snmp view CommunityView all
config snmp engineID 800000ab03001e58ce8300
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group xxxxxx v1 read_view CommunityView notify_view CommunityView
create snmp group xxxxxx v2c read_view CommunityView notify_view CommunityView
create snmp group yyyyyy v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group yyyyyy v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group private v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group private v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp community yyyyyy view CommunityView read_only
create snmp community yyyyyy view CommunityView read_write
# MANAGEMENT
enable snmp traps
enable snmp authenticate_traps
disable snmp
enable snmp linkchange_traps
config snmp system_location WWWWWW
disable rmon
config snmp linkchange_traps ports 1-12 enable
# VLAN
enable pvid auto_assign
config vlan default delete 1-12
config vlan default advertisement disable
create vlan Vlan_kkk tag 7
config vlan Vlan_kkk add tagged 1-8,10-12 advertisement disable
create vlan Vlan_254 tag 254
config vlan Vlan_254 add tagged 1-8,10-12 advertisement disable
create vlan Vlan_850 tag 850
config vlan Vlan_850 add tagged 1-8,10-11 advertisement disable
create vlan Vlan888 tag 888
config vlan Vlan888 add tagged 1-8,10-11
config vlan Vlan888 add untagged 9 advertisement disable
create vlan Vlan_999 tag 999
config vlan Vlan_999 add tagged 1-8,10-12 advertisement disable
disable qinq
disable gvrp
config gvrp 1-12 state disable ingress_checking enable acceptable_frame admit_all pvid 1
# PROTOCOL_VLAN
# QINQ
config qinq ports 1-12 missdrop disable tpid 0x8100
# RSPAN
disable rspan
# 8021X
disable 802.1x
config 802.1x auth_protocol radius_eap
config 802.1x capability ports 1-12 none
config 802.1x auth_parameter ports 1-12 direction both port_control auto quiet_period 60 tx_period 30 supp_timeout 30 server_timeout 30 max_req 2 reauth_period 3600 enable_reauth disable
# guestvlan
# TR
# ACL
create access_profile profile_id 1 ip udp src_port_mask 0xFFFF
config access_profile profile_id 1 add access_id 1 ip udp src_port 67 port 1-11 permit rx_rate no_limit
config access_profile profile_id 1 add access_id 2 ip udp src_port 67 port 12 deny
config access_profile profile_id 1 add access_id 3 ip udp src_port 68 port 12 deny
disable cpu_interface_filtering
# LIMITED_MULTICAST_RANGE
# MULTICAST_VLAN
# FDB
config fdb aging_time 300
# ADDRBIND
config address_binding ip_mac ports 1-12 forward_dhcppkt enable
disable address_binding dhcp_snoop
disable address_binding trap_log
config address_binding dhcp_snoop max_entry ports 1-12 limit no_limit
# DhcpServerScreening
config filter dhcp_server port all state disable
config filter dhcp_server illegal_server_log_suppress_duration 5min
config filter dhcp_server trap_log disable
# MAC_ADDRESS_TABLE_NOTIFICATION
enable mac_notification
config mac_notification interval 15 historysize 50
config mac_notification ports 1-12 enable
# STP
config stp version rstp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 3 fbpdu enable hellotime 2 lbd enable lbd_recover_timer 60
config stp priority 32768 instance_id 0
config stp mst_config_id name 00:1E:58:CE:83:00 revision_level 0
disable stp
config stp ports 1-12 externalCost auto edge false p2p auto state enable lbd disable
config stp mst_ports 1-12 instance_id 0 internalCost auto priority 128
config stp ports 1-12 fbpdu enable
# BPDU_TUNNEL
config bpdu_tunnel ports all type none
disable bpdu_tunnel
# SAFEGUARD_ENGINE
config safeguard_engine state enable utilization rising 30 falling 20 trap_log enable mode fuzzy
# BANNER_PROMP
config command_prompt default
config greeting_message default
# SSH
config ssh algorithm 3DES enable
config ssh algorithm AES128 enable
config ssh algorithm AES192 enable
config ssh algorithm AES256 enable
config ssh algorithm arcfour enable
config ssh algorithm blowfish enable
config ssh algorithm cast128 enable
config ssh algorithm twofish128 enable
config ssh algorithm twofish192 enable
config ssh algorithm twofish256 enable
config ssh algorithm MD5 enable
config ssh algorithm SHA1 enable
config ssh algorithm RSA enable
config ssh algorithm DSA enable
config ssh authmode password enable
config ssh authmode publickey enable
config ssh authmode hostbased enable
config ssh server maxsession 8
config ssh server contimeout 120
config ssh server authfail 2
config ssh server rekey never
config ssh user zzzzzzzz authmode password
disable ssh
# SNTP
disable sntp
config time_zone operator + hour 0 min 0
config sntp primary 0.0.0.0 secondary 0.0.0.0 poll-interval 720
config dst disable
# LACP
config link_aggregation algorithm ip_source
config lacp_port 1-12 mode passive
# IP
config ipif_mac_mapping ipif System mac_offset 0
config ipif System ipaddress 172.25.4.9/16 vlan Vlan888
config ipif System proxy_arp disable local disable
config ipif_mac_mapping ipif internet mac_offset 1
create ipif internet 10.109.48.5/21 Vlan_kkk state enable
config ipif internet proxy_arp disable local disable
config ipif_mac_mapping ipif in-tel-lud mac_offset 2
create ipif in-tel-lud 192.168.168.1/24 Vlan_850 state enable
config ipif in-tel-lud proxy_arp disable local disable
config ipif System ip_mtu 1500
config ipif internet ip_mtu 1500
config ipif in-tel-lud ip_mtu 1500
disable autoconfig
# LLDP
disable lldp
config lldp message_tx_interval 30
config lldp tx_delay 2
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp ports 1-12 notification disable
config lldp ports 1-12 admin_status tx_and_rx
# MBA
disable mac_based_access_control
config mac_based_access_control ports 1-12 state disable
config mac_based_access_control ports 1-12 mode host_based
config mac_based_access_control method local
config mac_based_access_control password default
# MCFILTER
# SNOOP
config limited_multicast_addr ports 1-12 state disable
# MLDSNP
# ACCESS_AUTHENTICATION_CONTROL
config authen_login default method local
config authen_enable default method local_enable
config authen application console login default
config authen application console enable default
config authen application telnet login default
config authen application telnet enable default
config authen application ssh login default
config authen application ssh enable default
config authen application http login default
config authen application http enable default
config authen parameter response_timeout 30
config authen parameter attempt 3
disable authen_policy
# AAA_LOCAL_ENABLE_PASSWORD
# AAA ADMIN PWD LIST
config admin local_enable
# AAA ADMIN PWD END
# NDP
config ipv6 nd ns ipif System retrans_time 0
config ipv6 nd ra ipif System state disable life_time 1800 reachable_time 1200000 retrans_time 0 hop_limit 64 managed_flag disable other_config_flag disable min_rtr_adv_interval 198 max_rtr_adv_interval 600
config ipv6 nd ns ipif internet retrans_time 0
config ipv6 nd ra ipif internet state disable life_time 1800 reachable_time 1200000 retrans_time 0 hop_limit 64 managed_flag disable other_config_flag disable min_rtr_adv_interval 198 max_rtr_adv_interval 600
config ipv6 nd ns ipif in-tel-lud retrans_time 0
config ipv6 nd ra ipif in-tel-lud state disable life_time 1800 reachable_time 1200000 retrans_time 0 hop_limit 64 managed_flag disable other_config_flag disable min_rtr_adv_interval 198 max_rtr_adv_interval 600
# WAC
config wac method local
disable wac
# ARP
config arp_aging time 20
config gratuitous_arp send ipif_status_up enable
config gratuitous_arp send dup_ip_detected enable
config gratuitous_arp learning enable
# ROUTE
config route preference static 60
config route preference rip 100
config route preference ospfIntra 80
config route preference ospfInter 90
config route preference ospfExt1 110
config route preference ospfExt2 115
create iproute default 10.109.48.1 1 primary
config ecmp algorithm ip_destination crc_low
enable ecmp ospf
# PROUTE
# IGMP
config igmp ipif System version 3 query_interval 125 max_response_time 10 robustness_variable 2 state disable
config igmp ipif System last_member_query_interval 1
config igmp ipif internet version 3 query_interval 125 max_response_time 10 robustness_variable 2 state disable
config igmp ipif internet last_member_query_interval 1
config igmp ipif in-tel-lud version 3 query_interval 125 max_response_time 10 robustness_variable 2 state disable
config igmp ipif in-tel-lud last_member_query_interval 1
# PIMSM
disable pim
config pim cbsr hash_masklen 30
config pim cbsr bootstrap_period 60
config pim register_suppression_time 60
config pim register_probe_time 5
config pim last_hop_spt_switchover never
config pim crp holdtime 150 priority 192
config pim crp wildcard_prefix_cnt 0
config pim ipif System state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif System priority -1
config pim ipif internet state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif internet priority -1
config pim ipif in-tel-lud state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif in-tel-lud priority -1
# DVMRP
disable dvmrp
config dvmrp ipif System metric 1 probe 10 neighbor_timeout 35 state disable
config dvmrp ipif internet metric 1 probe 10 neighbor_timeout 35 state disable
config dvmrp ipif in-tel-lud metric 1 probe 10 neighbor_timeout 35 state disable
# IPMROUTE
# RIP
disable rip
config rip ipif System tx_mode disable state disable
config rip ipif System rx_mode disable state disable
config rip ipif internet tx_mode disable state disable
config rip ipif internet rx_mode disable state disable
config rip ipif in-tel-lud tx_mode disable state disable
config rip ipif in-tel-lud rx_mode disable state disable
# MD5
# SFLOW
# OSPF
config ospf ipif internet area 0.0.0.0 priority 1 hello_interval 10 dead_interval 40
config ospf ipif internet authentication none metric 1 state disable passive disable
config ospf ipif System area 0.0.0.0 priority 1 hello_interval 10 dead_interval 40
config ospf ipif System authentication none metric 1 state disable passive disable
config ospf ipif in-tel-lud area 0.0.0.0 priority 1 hello_interval 10 dead_interval 40
config ospf ipif in-tel-lud authentication none metric 1 state disable passive disable
config ospf router_id 0.0.0.0
disable ospf
# DNSR
disable dnsr
config dnsr primary nameserver 0.0.0.0
config dnsr secondary nameserver 0.0.0.0
disable dnsr cache
disable dnsr static
# DHCP_RELAY
disable dhcp_relay
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state disable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
# DHCP_SERVER
create dhcp pool Pool_1
config dhcp pool network_addr Pool_1 10.109.48.0/21
config dhcp pool netbios_node_type Pool_1 peer_to_peer
config dhcp pool default_router Pool_1 10.109.48.5 0.0.0.0 0.0.0.0
config dhcp pool lease Pool_1 0 12 0
create dhcp excluded_address begin_address 10.109.48.1 end_address 10.109.48.10
config dhcp ping_packets 2
config dhcp ping_timeout 500
enable dhcp_server
# VRRP
config vrrp ipif System authtype none
config vrrp ipif internet authtype none
config vrrp ipif in-tel-lud authtype none
disable vrrp
disable vrrp ping
# End of configuration file for DGS-3612G
к портам 1 - 8 подключены свичи второго уровня des-3526, на каждом от 5 до 12 штук.
Общее число ip - адресов, наблюдаемых при раздаче по DHCP доходит до 350.
Реальное время получения адреса - 4-8 секунд. Всё прекрасно работает много дней.
Не меняя конфигурационного файла, заливаю прошивку - Build 2.50.B35 ,
сохраняю её и перезагружаю свич отключением из розетки.
Раздача адресов сильно сокращается - только несколько компьютеров получило ip-шники.
Дальше с этим свичем не игрался - вернул старую прошивку, перегрузился розеткой, всё заработало как прежде.
Делаю по другому.
Беру другой свич с уже залитой прошивкой Build 2.50.B35 но Hardware Version 1A1G ? -
и заливаю ту же конфигурацию.
Абоненты получают ip-шки, и видно что скорость выделения ip -адреса заметно выше чем при старой прошивке Build 2.50.B15. (пробую сам много раз)
Но по мере роста числа подключающихся, время выделения ip - растёт. На числе подключившихся абонентов около 45 -
выделение адресов прекрашается. (Винда кричит - подключение ограничено или отсутствует).
Смотрю журнал свича - всё чисто,режим не менялся, утилизация процессора ~ 10 % ,нагрузка на порты до 8 %, сеть работает , а ip-шники не раздаются.
Вытягиваю шнурок из 12 го порта (туда бегут все пакеты), и через несколько секунд получаю ip-шку. Перепроверяюсь несколько раз - ip-шки раздаются.
Вставляю шнурок назад - опять не раздаются.
Вынимаю шнурки из трёх портов, идущих на внутренние свичи. Опять ip-шки раздаются. Вставляю два шнурка - не раздаются.
Проверяю журнал, слежу за утилизацией процессора и портов - всё чисто.
Похоже что в этой прошивке алгоритм вадачи ip - адреса перестаёт работать при незначительной нагрузке на свич.
СообщениеДобавлено: Пн мар 30, 2009 16:28
Пришлите, пожалуйста, мне на rbigarov]a[dlink].[ru отдельным файлом конфигурационный файл, топологию сети с указанными портами подключения и описание проблемы, я займусь её решением.
Бигаров Руслан.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 67
