Текущее время: Пт окт 02, 2026 11:15
СообщениеДобавлено: Пт май 25, 2007 12:04
При включении bandwidth_control RX возникают потери.
Просьба помочь разобраться.
Success rate is 99 percent (999/1000), round-trip min/avg/max = 1/3/52 ms
DES-3018:4#config bandwidth_control 1 rx_rate 17408
Command: config bandwidth_control 1 rx_rate 17408
Note: To perform precise bandwidth control, it is required to enable the flow
control to mitigate the retransmission of TCP traffic.
Success
#ping x.x.x.x repeat 1000 size 1500
Sending 1000, 1500-byte ICMP Echos to 195.69.202.14, timeout is 2 seconds:
Success rate is 98 percent (985/1000), round-trip min/avg/max = 1/3/20 ms
Success rate is 98 percent (981/1000), round-trip min/avg/max = 1/3/20 ms
Success rate is 98 percent (985/1000), round-trip min/avg/max = 1/3/24 ms
Sending 1000, 100-byte ICMP Echos to 195.69.202.14, timeout is 2 seconds:
Success rate is 99 percent (993/1000), round-trip min/avg/max = 1/2/12 ms
Success rate is 98 percent (987/1000), round-trip min/avg/max = 1/2/12 ms
Success rate is 98 percent (984/1000), round-trip min/avg/max = 1/1/16 ms
DES-3018:4#show error ports 1
Command: show error ports 1
Port number : 1
RX Frames TX Frames
CRC Error 0 Excessive Deferral 0
Undersize 0 CRC Error 0
Oversize 0 Late Collision 0
Fragment 0 Excessive Collision 0
Jabber 0 Single Collision 0
Drop Pkts 0 Collision 0
DES-3018:4#show switch
Command: show switch
Device Type : DES-3018 Fast Ethernet Switch
Module 1 Type : None
Module 2 Type : None
MAC Address : 00-13-46-65-81-E8
IP Address : 192.168.110.230 (Manual)
VLAN Name : mng
Subnet Mask : 255.255.255.0
Default Gateway : 0.0.0.0
Boot PROM Version : Build 1.01.007
Firmware Version : Build 3.00.053
Hardware Version : A1
System Name :
System Location :
System Contact :
Spanning Tree : Disabled
IGMP Snooping : Disabled
802.1X : Disabled
TELNET : Enabled(TCP 23)
WEB : Enabled(TCP 80)
RMON : Disabled
СообщениеДобавлено: Пт май 25, 2007 12:06
Перезвоните пожалуйста в офис по телефону 744-00-99 доб.390.
