Текущее время: Вс окт 04, 2026 02:52
 Заголовок сообщения: cat3550+WS-G5483 -> D-link DGS-3324SR
СообщениеДобавлено: Ср май 09, 2007 18:34
Есть Catalyst 3550, есть GBIC WS-G5483 (он же подключен к 24 порту DGS'а)
cisco-cat-01#sh interfaces GigabitEthernet 0/2
GigabitEthernet0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0013.80f9.4900 (bia 0013.80f9.4900)
  Internet address is 172.16.1.51/27
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 33/255, rxload 98/255
  Encapsulation ARPA, loopback not set
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is T
  input flow-control is off, output flow-control is off
  ARP type: ARPA, ARP Timeout 04:00:00
  1000BaseT module (WS-G5483) in GBIC slot.
  Last input 00:00:13, output 00:00:01, output hang never
  Last clearing of "show interface" counters never
  Input queue: 0/75/475/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 385087000 bits/sec, 42803 packets/sec
  5 minute output rate 132200000 bits/sec, 33706 packets/sec
     3300205904 packets input, 1851880363 bytes, 0 no buffer
     Received 128133 broadcasts (0 IP multicast)
     0 runts, 2 giants, 0 throttles
     2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     0 input packets with dribble condition detected
     2084449415 packets output, 1859571337 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 babbles, 0 late collision, 0 deferred
     0 lost carrier, 0 no carrier, 0 PAUSE output
     0 output buffer failures, 0 output buffers swapped out
К нему подключен D-link DGS-3324SR
DGS-3324SR:4#show ports
Command: show ports
 Port    Port           Settings             Connection           Address
         State    Speed/Duplex/FlowCtrl  Speed/Duplex/FlowCtrl    Learning
 1:21   Enabled   Auto/Disabled           1000M/Full/None         Enabled
 1:22   Enabled   Auto/Disabled           100M/Full/None          Enabled
 1:23   Enabled   Auto/Disabled           10M/Half/None           Enabled
 1:24   Enabled   Auto/Disabled           1000M/Full/None         Enabled
catalyst работает на 3 уровне
dlink на 2
И там и там интерфейсы подняты, 1000М, Full-Duplex, но скорость выше 120 Мбит не поднимается.
С чем это может быть связано? Есть какие-нибудь соображения?
Спасибо.
[/code]
СообщениеДобавлено: Ср май 09, 2007 18:36
Версия прошивки? И кстати чем и как измеряли пропускную способность?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 108
