Текущее время: Вс ноя 08, 2026 05:22
СообщениеДобавлено: Пн ноя 24, 2025 10:56
Здравствуйте.
Имеется 20 коммутаторов DGS-1510-52X, с разными прошивками, начиная от 1.70.012 и заканчивая 1.81
Приобретены коммутаторы Eltex MES 5400-24, MES 2300-24
В коммутаторах тестировались SFP модули FIBO, NetworK Logic, DLINK.
Информация об SFP модуле на D-LINK:
eth1/0/51
Интерфейс Тип 10GBASE-R
Laser Identifier SFP
Connector type SFP LC
Ethernet Compliance Code 1000BASE-LX
Encoding 8B/10B
Vendor Name FIBO
Vendor OUI 0 :1b:21
Vendor PN FT-S1-W5520LDI
Vendor Rev A
Vendor SN FC24096854
Date Code 240918
Received Power Measurements Type Average Power
Compatibility Single Mode (SM),1300Mbd, 1550nm
Transfer Distance
SMF Fiber: 20km
Информация об SFP модуле на Eltex:
Port Temp Voltage Current Output Input LOS Transceiver
[C] [V] [mA] Power Power Type
[mW / dBm] [mW / dBm]
te1/0/1 29 3.27 11.41 0.22 / -6.47 0.34 / -4.64 No Fiber
Temp - Internally measured transceiver temperature
Voltage - Internally measured supply voltage
Current - Measured TX bias current
Output Power - Measured TX output power in milliWatts/dBm
Input Power - Measured RX received power in milliWatts/dBm
LOS - Loss of signal
N/A - Not Available, N/S - Not Supported, W - Warning, E - Error
Transceiver information:
Vendor name: FIBO
Serial number: FO2412243152
Part number: FT-S1-W3120LDI
Vendor revision: 00 00 00 00
Connector type: LC
Type: SFP/SFP+
Compliance code: 1000BASE-LX
Laser wavelength: 1310 nm
Transfer distance: 20000 m
Diagnostic: supported
Threshold parameters:
Temperature [C]
Low Warning: -40 High Warning: 100
Low Alarm: -45 High Alarm: 105
Voltage [V]
Low Warning: 3.00 High Warning: 3.60
Low Alarm: 2.90 High Alarm: 3.70
Current [mA]
Low Warning: 3.00 High Warning: 90.00
Low Alarm: 1.00 High Alarm: 100.00
Output Power [mW / dBm]
Low Warning: 0.11 / -9.50 High Warning: 0.50 / -3.00
Low Alarm: 0.04 / -13.49 High Alarm: 1.25 / 0.99
Input Power [mW / dBm]
Low Warning: 0.01 / -18.99 High Warning: 0.50 / -3.00
Low Alarm: 0.00 / -23.01 High Alarm: 1.25 / 0.99
Между оптическим портом D-LINK и оптическим портом Eltex не получается установить физическое соединение.
Физическое соединение без проблем устанавливается на тех же SFP модулях между D-LINK - D-LINK и между Eltex - Eltex.
Перепробованы все возможные варианты настройки портов у d-link и eltex.
Все параметры безопасности отключены.
Конфигурация настраивалась с нуля.
Никакие действия пока не приводят к положительному результату, физическое соединение не устанавливается в статус UP.
Помогите пожалуйста решить эту проблему.
СообщениеДобавлено: Вт ноя 25, 2025 06:04
Со стороны элтекс на порту:
no negotiation bypass
Если не поможет - на длинк скорость на порту принудительно в 1000
СообщениеДобавлено: Вт ноя 25, 2025 08:37
Здравствуйте.
Команда на Eltex: negotiation bypass forced помогла установить физическое соединение с D-LINK
Спасибо огромное за помощь!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 77
