Текущее время: Сб сен 13, 2025 04:32
СообщениеДобавлено: Вт авг 19, 2025 18:41
Есть DGS-3630-28SC Runtime:2.25.B030
Четко раз в час:
вижу в логах:
#3635 2025-08-18 23:02:34 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3634 2025-08-18 23:02:29 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
#3633 2025-08-18 22:02:35 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3632 2025-08-18 22:02:31 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
#3631 2025-08-18 21:02:36 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3630 2025-08-18 21:02:31 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
#3629 2025-08-18 20:02:32 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3628 2025-08-18 20:02:26 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
#3627 2025-08-18 15:02:36 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3626 2025-08-18 15:02:31 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
Бродкастшторм, сетевые петли исключили. С чего можно начать поиск проблемы?
СообщениеДобавлено: Вт авг 19, 2025 18:44
#3663 2025-08-19 18:02:35 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3662 2025-08-19 18:02:30 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
#3661 2025-08-19 17:02:44 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3660 2025-08-19 17:02:39 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
#3659 2025-08-19 15:02:32 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3658 2025-08-19 15:02:29 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
#3657 2025-08-19 14:02:36 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
#3656 2025-08-19 14:02:27 WARN(4) Unit 1, Safeguard Engine enters EXHAUSTED mode
#3655 2025-08-19 13:02:47 INFO(6) Unit 1, Safeguard Engine enters NORMAL mode
show cpu utilization history 15_minute
CPU Utilization:
19 Aug 2025 18:42:01 - 19 Aug 2025 18:27:01 : 26 %
19 Aug 2025 18:27:01 - 19 Aug 2025 18:12:01 : 25 %
19 Aug 2025 18:12:01 - 19 Aug 2025 17:57:01 : 26 %
19 Aug 2025 17:57:01 - 19 Aug 2025 17:42:01 : 25 %
19 Aug 2025 17:42:01 - 19 Aug 2025 17:27:01 : 25 %
R_VMASL22_sw1#show cpu utilization history 1_day
CPU Utilization:
19 Aug 2025 18:42:18 - 18 Aug 2025 18:42:18 : 26 %
18 Aug 2025 18:42:18 - 17 Aug 2025 18:42:18 : 26 %
show cpu-protect safeguard
Safeguard Engine State: Enabled
Safeguard Engine Status: Normal
Utilization Thresholds:
Rising :95%
Falling :85%
СообщениеДобавлено: Ср авг 20, 2025 15:37
CPU Utilization:
CPU Utilization:
Rising :95%
Falling :85%
Попробуйте обновиться до актуальной версии (направил Вам на почту)
СообщениеДобавлено: Пт сен 12, 2025 20:10
как оказалось свич уходил в Safeguard из за опроса по SNMP со стороны zabbix
Прошивка 2.30.B016 не повлияла на ситуацию.
На других объектах такой проблемы нет из за того что меньше интерфейс вланов (на данном коммутаторе 200+)
На более старых моделях типа DGS3620-28SC такой такой проблемы тоже не отмечали.
Сыровато либо ПО, либо сэкономили на железе.
Сейчас этот форум просматривают: Google [Bot] и гости: 33
