Текущее время: Чт окт 15, 2026 18:09
 Заголовок сообщения: RSTP DGS-1210-20/ME
СообщениеДобавлено: Пт мар 11, 2022 07:35
День добрый.
Подскажите с настройкой RSTP.
Собираю на стенде из двух свичей DGS-1210-20/ME.
Device Type                       : DGS-1210-20/ME
MAC Address                       : BC-0F-9A-F9-6F-80
IP Address                        : 10.90.90.90 (Manual)
VLAN Name                         : default
Subnet Mask                       : 255.0.0.0
Default Gateway                   : 0.0.0.0
System Boot Version               : 1.00.023
System Firmware Version           : 6.13.B010
System Hardware Version           : A1
System Serial Number              : TM3T106001140
Схема соединения:
SW01.PORT17 <--> SW02.PORT17
SW01.PORT20 <--> SW02.PORT20
Конфиг SW01
enable stp
config stp version rstp
config stp priority 4096 instance_id 0
config stp txholdcount 6 maxage 20 hellotime 2 forwarddelay 15 maxhops 20
config stp nni_bpdu_addr dot1d
config stp fbpdu enable
config stp ports 1-16 externalcost auto edge true restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu disable
config stp ports 17-20 externalcost auto edge false restricted_tcn false restricted_role false p2p auto state enable priority 128 fbpdu enable
config stp mst_config_id name bc:0f:9a:f9:6f:80 revision_level 0
config stp mst_ports 1-20 instance_id 0 internalCost auto priority 128
Конфиг SW02
enable stp
config stp priority 32768 instance_id 0
config stp ports 1-16 externalcost auto edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu disable
config stp mst_config_id name bc:0f:9a:f9:6f:a0 revision_level 0
SW01
Command: show stp
STP Bridge Global Settings
STP Status            : Enabled
STP Version           : RSTP
Bridge Priority       : 4096
Max Age               : 20
Hello Time            : 2
Forward Delay         : 15
TX Hold Count         : 6
Max Hops              : 20
Forward BPDU          : Enabled
NNI BPDU Address      : dot1d
Root Cost             : 0
Root Maximum Age      : 20
Root Forward Delay    : 15
Root Port             : 0
Root Bridge           : 10:00:BC:0F:9A:F9:6F:80
Command: show stp instance
 ## CIST
Designated Root Bridge   bc:0f:9a:f9:6f:80    Priority 4096
                         We are the Root for CST
                         Port 0        ,  path cost 0
Regional Root Bridge     bc:0f:9a:f9:6f:80    Priority  4096
                         Path cost 0
Designated Bridge        bc:0f:9a:f9:6f:80    Priority  4096
Configured Forward delay 15, Max age 20, Max hops 20
Operational Forward delay 15, Max age 20
Topology Changes Count : 19
Last Topology Change   : 51789
Interface Role         Sts          Cost     Prio.Nbr Type
17        Designated   Forwarding   20000    128.17     Point to point
20        Designated   Forwarding   20000    128.20     Point to point
SW02
Command: show stp
STP Version           : RSTP
Bridge Priority       : 32768
Max Age               : 20
Hello Time            : 2
Forward Delay         : 15
TX Hold Count         : 6
Max Hops              : 20
Root Cost             : 200000000
Root Port             : 17
 ## CIST
                         Port 17       ,  path cost 200000000
Regional Root Bridge     bc:0f:9a:f9:6f:a0    Priority  32768
                         Path cost 0
Topology Changes Count : 16
Last Topology Change   : 52881
17        Root         Forwarding   20000    128.17     Point to point
20        Alternate    Discarding   20000    128.20     Point to point
С первого взгляда все нормально.
При этом трафик на STP портах составляет 110Мбит/с
Command: show utilization ports 17,20
 Port TX(5 sec.) RX(5 sec.) Util(5 sec.) One min. Five min.
 17   892212     3                   11%      10%       11%
 20   0          764907              11%      11%       11%
При подключении в порт, не являющегося участником STP, еще одного свича имею следующую картину
 ## CIST
                         Path cost 0
Last Topology Change   : 52038
16        Disabled     Forwarding   200000   128.16     Point to point
Command: show utilization ports 16,17,20
 16   513975     305                 51%      27%        7%
 17   293        1785945             25%      14%       12%
 20   1528280    0                   22%      14%       12%
Подскажите что не так делаю
 Заголовок сообщения: Re: RSTP DGS-1210-20/ME
СообщениеДобавлено: Ср мар 16, 2022 10:25
Вопрос решился сменой прошивки
Сейчас этот форум просматривают: Google [Bot] и гости: 44
