Текущее время: Чт окт 08, 2026 02:44
 Заголовок сообщения: PIM-SM DGS-3130
СообщениеДобавлено: Сб дек 12, 2020 06:22
Здравствуйте!
В 151 влан 4 порт включён сервер-источник
В 152 влан 9 порт клиент
!Current Configuration:
!System Description "DGS-3130-30TS"
!System Software Version "1.14.B034"
!System Up Time "0 days 0 hrs 41 mins 2 secs"
!Current SNTP Synchronized Time: SNTP Client Mode Is Disabled
configure terminal
vlan 151-152
exit
vlan 151
name VLAN-MC-STR
exit
vlan 152
name UserPublic1
multicast filtering-mode filter-unregistered
ip igmp snooping
exit
username admin privilege 15 password 0 admin
ssh user admin authentication-method password
line console
exit
line telnet
password 0 admin
login local
exit
line ssh
exit
ip access-list pim 1999
10 permit any 235.3.21.1 255.0.0.0
exit
ip igmp snooping
ip multicast-routing
interface ethernet 1/0/4
switchport mode access
switchport access vlan 151
exit
interface ethernet 1/0/9
switchport access vlan 152
exit
interface loopback 1
exit
interface mgmt 0
ip address 192.168.0.1 255.255.255.0
exit
interface vlan 1
ip address 10.90.90.90 255.0.0.0
exit
interface vlan 151
description VLAN-MC-STR
ip address 192.168.151.1 255.255.255.0
ip pim sparse-mode
exit
interface vlan 152
description UserPublic1
ip address 192.168.152.1 255.255.255.248
ip igmp enable
ip igmp version 2
ip igmp query-interval 60
ip igmp ignore-subscriber-ip-check
ip pim sparse-mode
exit
interface null 0
exit
logging source-interface Vlan 151
ip pim rp-address 192.168.151.1 235.3.21.1 255.0.0.0
exit
Switch#show ip mroute
IP Multicast Routing Table
Flags: D - PIM-DM, S - PIM-SM, V - DVMRP, s - SSM Group, F - Register flag
P - Pruned, R - (S, G) RPT-bit set, T - SPT-bit set
Outgoing interface flags: W - Assert winner
Timers: Uptime/Expires
( *,235.3.21.1), 0DT00H08M03S/0DT00H00M00S, RP is 192.168.151.1, Flags: S
Incoming interface: NULL, RPF neighbor: NULL
Outgoing interface list:
vlan152, Forwarding 0DT00H08M03S/0DT00H02M06S
( *,235.3.21.2), 0DT00H08M03S/0DT00H00M00S, RP is 192.168.151.1, Flags: S
(192.168.151.11,235.3.11.1), 0DT00H07M51S/0DT00H02M39S, Flags: ST
Incoming interface: vlan151, RPF neighbor: 192.168.151.11
(192.168.151.11,235.3.11.3), 0DT00H07M18S/0DT00H03M12S, Flags: ST
(192.168.151.11,235.3.11.4), 0DT00H07M53S/0DT00H02M37S, Flags: ST
(192.168.151.11,235.3.11.5), 0DT00H07M58S/0DT00H02M32S, Flags: ST
(192.168.151.11,235.3.11.6), 0DT00H07M26S/0DT00H03M04S, Flags: ST
(192.168.151.11,235.3.11.7), 0DT00H07M56S/0DT00H02M34S, Flags: ST
(192.168.151.11,235.3.11.8), 0DT00H07M14S/0DT00H03M16S, Flags: ST
(192.168.151.11,235.3.11.9), 0DT00H08M01S/0DT00H02M29S, Flags: ST
(192.168.151.11,235.3.11.10), 0DT00H06M48S/0DT00H00M12S, Flags: ST
(192.168.151.11,235.3.11.11), 0DT00H07M30S/0DT00H03M00S, Flags: ST
(192.168.151.11,235.3.11.12), 0DT00H07M44S/0DT00H02M46S, Flags: ST
(192.168.151.11,235.3.11.13), 0DT00H08M03S/0DT00H02M27S, Flags: ST
(192.168.151.11,235.3.11.14), 0DT00H07M12S/0DT00H03M18S, Flags: ST
(192.168.151.11,235.3.11.15), 0DT00H07M44S/0DT00H02M46S, Flags: ST
(192.168.151.11,235.3.11.16), 0DT00H07M56S/0DT00H02M34S, Flags: ST
(192.168.151.11,235.3.11.17), 0DT00H07M39S/0DT00H02M51S, Flags: ST
(192.168.151.11,235.3.11.18), 0DT00H07M36S/0DT00H02M54S, Flags: ST
(192.168.151.11,235.3.11.19), 0DT00H07M51S/0DT00H02M39S, Flags: ST
(192.168.151.11,235.3.11.20), 0DT00H07M52S/0DT00H02M38S, Flags: ST
(192.168.151.11,235.3.11.101), 0DT00H07M42S/0DT00H02M48S, Flags: ST
(192.168.151.11,235.3.11.102), 0DT00H07M35S/0DT00H02M55S, Flags: ST
(192.168.151.11,235.3.11.103), 0DT00H08M01S/0DT00H02M29S, Flags: ST
(192.168.151.11,235.3.11.111), 0DT00H07M57S/0DT00H02M33S, Flags: ST
(192.168.151.11,235.3.11.112), 0DT00H08M00S/0DT00H02M30S, Flags: ST
(192.168.151.11,235.3.11.113), 0DT00H07M03S/0DT00H03M27S, Flags: ST
(192.168.151.11,235.3.11.201), 0DT00H07M59S/0DT00H02M31S, Flags: ST
(192.168.151.11,235.3.11.202), 0DT00H07M56S/0DT00H02M34S, Flags: ST
(192.168.151.11,235.3.11.203), 0DT00H07M48S/0DT00H02M42S, Flags: ST
(192.168.151.11,235.3.11.204), 0DT00H08M00S/0DT00H02M30S, Flags: ST
(192.168.151.11,235.3.11.205), 0DT00H07M54S/0DT00H02M36S, Flags: ST
(192.168.151.11,235.3.11.207), 0DT00H08M01S/0DT00H02M29S, Flags: ST
(192.168.151.11,235.3.11.208), 0DT00H07M33S/0DT00H02M57S, Flags: ST
(192.168.151.11,235.3.11.209), 0DT00H07M43S/0DT00H02M47S, Flags: ST
(192.168.151.11,235.3.11.210), 0DT00H07M51S/0DT00H02M39S, Flags: ST
(192.168.151.11,235.3.11.211), 0DT00H07M47S/0DT00H02M43S, Flags: ST
(192.168.151.11,235.3.11.212), 0DT00H07M47S/0DT00H02M43S, Flags: ST
(192.168.151.11,235.3.11.213), 0DT00H07M31S/0DT00H02M59S, Flags: ST
(192.168.151.11,235.3.11.214), 0DT00H07M41S/0DT00H02M49S, Flags: ST
(192.168.151.11,235.3.11.215), 0DT00H07M47S/0DT00H02M43S, Flags: ST
(192.168.151.11,235.3.11.216), 0DT00H07M51S/0DT00H02M39S, Flags: ST
(192.168.151.11,235.3.11.217), 0DT00H07M49S/0DT00H02M41S, Flags: ST
(192.168.151.11,235.3.11.218), 0DT00H08M01S/0DT00H02M29S, Flags: ST
(192.168.151.11,235.3.11.219), 0DT00H06M46S/0DT00H00M14S, Flags: ST
(192.168.151.11,235.3.11.220), 0DT00H07M23S/0DT00H03M07S, Flags: ST
Total Entries: 46
 Заголовок сообщения: Re: PIM-SM DGS-3130
СообщениеДобавлено: Вс дек 13, 2020 07:56
viewtopic.php?f=2&t=178120
Может оно?
СообщениеДобавлено: Вс дек 13, 2020 20:48
уже обновил, все так же.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 56
