Текущее время: Вс ноя 01, 2026 02:20
СообщениеДобавлено: Вт апр 03, 2018 17:16
DGS-3627G:5#sh sw
Command: show switch
Device Type       : DGS-3627G Gigabit Ethernet Switch
IP Address        : 10.90.90.90 (Manual)
VLAN Name         : default
Subnet Mask       : 255.0.0.0
Default Gateway   : 0.0.0.0
Boot PROM Version : Build 1.10-B09
Firmware Version  : Build 2.52.B45
Hardware Version  : A1
При попытке сохранить конфиг или лог свич зависает.
DGS-3627G:5#save
Command: save
 Saving all configurations to NV-RAM..........   0 %
Error: UTL_INTL_Set_Lock_State: fail status=A8
Error: UTL_INTL_Sector_Erase fail, write_address=70000000 sector_address=70400000
OS_Fatal_Error_Handler :
 errormsg =
 ERROR :UTL_FLSH_EEPROM_Write: erase fail
Current Stack Pointer = 556F288
!! System in EXCEPTION MODE !!!
Prom: 1.10-B09, Runtime: 2.52.B45
PAUSE System Exception:
   Pause source code     : 1
   Current Task: FS_W_Tas
   Current Stack Pointer : 0556F278
0556F278 : 0556F288 0001BFFC 0556F288 0000B214
0556F288 : 0556F318 0000C448 0000B214 00000000
0556F298 : FEFEFEFF 0556F194 0056F2E0 0556F348
0556F2A8 : 0556F168 FFFFFFFF 01000000 0556F320
0556F2B8 : 0556F290 0A0D2045 52524F52 203A5554
0556F2C8 : 4C5F464C 53485F45 4550524F 4D5F5772
0556F2D8 : 6974653A 20657261 73652066 61696C00
0556F2E8 : 0556F320 0556F360 0556F318 0000A7FC
0556F2F8 : 00001BF7 00400000 00014600 00400000
0556F308 : 04999674 00000001 00000000 0556F360
0556F318 : 0556F358 0000AAF4 0101B550 70000000
0556F328 : 00000081 01000000 00000001 00000000
0556F338 : 0000B84C 0000BAD4 0000B8D8 0000B9A4
0556F348 : 0000B770 04999674 00000000 0556F3C8
0556F358 : 0556F3C0 000286B0 70400000 04999674
0556F368 : 00020000 00000000 06ADF63C 00014600
0556F378 : 00000001 04F135A0 04ED2E3C 00000000
0556F388 : 0556F398 0004A890 04ED2E3C 0556F3E8
0556F398 : 0556F3B0 0004A07C 00001BF7 00000000
0556F3A8 : 06AE1233 00000000 00000021 04ED2E3C
0556F3B8 : 0556F448 0556F448 0556F3E0 0002A470
0556F3C8 : 00000002 00414600 00001BF7 06ADF63C
0556F3D8 : 0556F448 00000001 0556F428 0004A3B4
0556F3E8 : 00000001 00000020 00014600 06ADF63C
0556F3F8 : 00001BF7 0556F420 00000400 00000200
0556F408 : 02EA9B68 00000000 00000000 00000000
0556F418 : 00000000 04ED2E3C 00000000 0556F448
0556F428 : 0556F440 0004A480 0556F448 00001BF7
0556F438 : 00414600 06ADF63C 0556F468 000373F4
0556F448 : 00414600 06ADF63C 00001BF7 00000000
0556F458 : 00001BF7 06ADF63C 0169BB94 0556F50C
0556F468 : 0556F4E8 000315A4 4300FFFF 00000043
The relation of function calling:
00020BB0
00521484
00520F9C
001ED1FC
0002A204
0003CB1C
00031174
000315A4
000373F4
0004A480
0004A3B4
0002A470
000286B0
0000AAF4
0000C448
0001BFFC
TCD_Interrupt_Level=00000000  Interrrupt Disabled
TCD_Current_Thread=053DF4A4  Thread name=FS_W_Tas
TCD_Execute_Task=053DF4A4  Current Task=FS_W_Tas
TCD_Execute_HISR=00000000
TCD_System_Stack=046A542C#
Не подскажете, что делать?
Внимательность! Это было на букву "Э"!
DES/DGS-3200-XX(A1/B1/C1), DGS-3627G(A1), DGS-3426(A1), DGS-3120-24SC(A1/A2/B1), DES-1210-28/ME(B2/B3)
СообщениеДобавлено: Вт апр 03, 2018 17:31
Обновитесь на актуальную прошивку 3.00.B48 (если это получится сделать), предварительно выгрузив конфигурацию.
Подробности по обновлению можно найти на форуме.
СообщениеДобавлено: Вт апр 03, 2018 17:37
Alexey Konstantinov писал(а):
Обновитесь на актуальную прошивку 3.00.B48, предварительно выгрузив конфигурацию.
Не возможно сохранить конфигурацию и/или лог(!) вываливается в ошибку ту, что под спойлером.
upd: прошить тоже не выходит.
DGS-3627G:5#download firmware_fromTFTP 172.20.27.254 src_file DGS36xx_Run_3_00_B
48.had
Command: download firmware_fromTFTP 172.20.27.254 src_file DGS36xx_Run_3_00_B48.had
 Connecting to server................... Done.
 Download firmware...................... Done.  Do not power off!
 Upload file to FLASH...................   0 %
Error: UTL_INTL_Sector_Erase fail, write_address=70000000 sector_address=70000000
 errormsg =
0556F2F8 : 00010000 00000000 00004600 00000000
0556F358 : 0556F3C0 000286B0 70000000 04999674
0556F368 : 00020000 00000000 06ADF63C 00004600
0556F378 : 00000001 04EF2EE8 04ED2E3C 00000000
0556F398 : 0556F3B0 0004A07C 00010000 00000000
0556F3A8 : 06AEF63C 00000000 00000001 04ED2E3C
0556F3C8 : 00000002 00004600 00010000 06ADF63C
0556F3E8 : 00000001 00000000 00004600 06ADF63C
0556F3F8 : 00010000 0556F420 00000400 00000200
0556F428 : 0556F440 0004A480 0556F448 00010000
0556F438 : 00004600 06ADF63C 0556F468 000373F4
0556F448 : 00004600 06ADF63C 00010000 00000000
0556F458 : 004D403C 06ADF63C 0169BB94 0556F50C
0556F468 : 0556F4E8 000315A4 0300FFFF 00000002
00020BB0
00521484
00520F9C
001ED1FC
0002A204
0003CB1C
00031174
000315A4
000373F4
0004A480
0004A3B4
0002A470
000286B0
0000AAF4
0000C448
0001BFFC
Может попробовать через BootPROM?
СообщениеДобавлено: Вт апр 03, 2018 17:52
Скорее всего это аппаратная проблема, обратитесь в сервисный центр.
Сейчас этот форум просматривают: Bing [Bot] и гости: 68
