Текущее время: Вс авг 23, 2026 14:06
 Заголовок сообщения: DGS-3610-26G непонятные проблемы.
СообщениеДобавлено: Ср авг 09, 2017 10:20
Начались какие то непонятные проблемы с сетью, ядро 2 штуки DGS-3610-26G объединённые в стек. На периферии несколько DES-3200-52P и DES-3200-52. Между DGS и DES оптический линк, включена агрегация портов. В какой то момент перестали быть доступны несколько DES-3200-52P, 3 штуки в частности. Остальные работали в штатном режиме. В логах проблемных коммутаторов :
Port 51 LBD loop occurred. Port blocked
Port 52 LBD loop occurred. Port blocked
Port 51 LBD port recovered. Loop detection restarted
Port 52 LBD port recovered. Loop detection restarted
В логах DGS:
*Jul 28 06:22:32: %LINK-3-UPDOWN: Interface AggregatePort 1, changed state to down.
*Jul 28 06:22:32: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 1, changed state to down.
*Jul 28 06:22:35: %LINK-3-UPDOWN: Interface AggregatePort 3, changed state to down.
*Jul 28 06:22:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 3, changed state to down.
*Jul 28 06:23:32: %LINK-3-UPDOWN: Interface AggregatePort 5, changed state to up.
*Jul 28 06:23:32: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 5, changed state to up.
*Jul 28 06:23:35: %LINK-3-UPDOWN: Interface AggregatePort 1, changed state to up.
*Jul 28 06:23:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 1, changed state to up.
*Jul 28 06:23:37: %LINK-3-UPDOWN: Interface AggregatePort 3, changed state to up.
*Jul 28 06:23:37: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 3, changed state to up.
*Jul 28 06:23:40: %LINK-3-UPDOWN: Interface AggregatePort 5, changed state to down.
*Jul 28 06:23:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 5, changed state to down.
*Jul 28 06:23:43: %LINK-3-UPDOWN: Interface AggregatePort 1, changed state to down.
*Jul 28 06:23:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 1, changed state to down.
*Jul 28 06:23:45: %LINK-3-UPDOWN: Interface AggregatePort 3, changed state to down.
*Jul 28 06:23:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 3, changed state to down.
*Jul 28 06:24:42: %LINK-3-UPDOWN: Interface AggregatePort 5, changed state to up.
*Jul 28 06:24:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface AggregatePort 5, changed state to up.
Ясно что петля, откуда она могла взяться на магистральном порту ума не приложу. Отключили один DGS, стек естественно разобрался, линк на всех интерфейсах поднялся.
Переговорил с самарской техподдержкой, посоветовали отключить обнаружение петли на магистральных портах и проверить агрегацию. Ок, с агрегацией проблем вроде бы нет, обнаружение петли отключил на всех коммутаторах DES на портах 51-52. На абонентских портах оставил. Заново собираю стек и в итоге стек собирается, магистральные порты не отключаются, но ни одно абонентское устройство не доступно.
Т.е. для конечных устройств сеть недоступна, между собой DGS и DES пингуются. Пришлось опять разобрать стек. Никаких изменений ни в конфигурацию коммутаторов, ни тем более в физику сети не вносилось уже порядка 2-3 лет.
В какую сторону можно копнуть подскажите пожалуйста? Проблема стоит достаточно остро. Если надо могу выложить конфиг с DGS.
