Текущее время: Чт сен 24, 2026 19:55
 Заголовок сообщения: DES-1210-28/ME B2
СообщениеДобавлено: Чт май 22, 2014 10:10
Device Type : DES-1210-28/ME
MAC Address : C0-A0-BB-DA-A1-D5
System Boot Version : 1.00.009
System Protocol Version : 2.001.004
System Firmware Version : 6.05.B039
System Hardware Version : B2
System Serial Number : QBM51DA001958
Настроен менеджмент влан в котором все свичи. Через свитч выдаеться инет по дхцп и iptv (multicast)
Настройки мультикаста:
# ISM vlan
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan "iptv-xzh" 337
config igmp_snooping multicast_vlan "iptv-xzh" add member_port 1-2,7,10,14
config igmp_snooping multicast_vlan "iptv-xzh" add source_port 26
config igmp_snooping multicast_vlan "iptv-xzh" add untag_source_port 25
config igmp_snooping multicast_vlan "iptv-xzh" state enable
config igmp_snooping multicast_vlan "iptv-xzh" replace_source_ip none
config mld_snooping multicast_vlan "iptv-xzh" replace_source_ipv6 none
config igmp_snooping multicast_vlan_group "iptv-xzh" add ipv4_range 228.0.0.0 228.0.0.255
# IGMP snooping
config igmp_snooping all router_timeout 260
config igmp_snooping all host_timeout 18000
config igmp_snooping data_driven_learning max_learned_entry 1
disable igmp_snooping forward_mcrouter_only
config igmp_snooping vlanid 1,327,370,601 state disable fast_leave disable report_suppression enable
config igmp_snooping vlanid 337 state enable fast_leave enable report_suppression enable
config igmp_snooping data_driven_learning vlanid 1,327,370,601 state disable
config igmp_snooping data_driven_learning vlanid 1,327,337,370,601 aged_out disable
config igmp_snooping data_driven_learning vlanid 337 state enable
config igmp_snooping querier vlanid 1,327,370,601 state disable querier_version 2 last_member_query_interval 1 max_response_time 10 query_int
erval 125 robustness_variable 2
config igmp_snooping querier vlanid 337 state disable querier_version 3 last_member_query_interval 1 max_response_time 10 query_interval 125
config router_ports vlan_name "iptv-xzh" add 25-26
config igmp access_authentication ports 1-28 state disable
Сейчас на свиче 15 абонентов из них 5 потребителей мультикаста
Command: show utilization cpu
CPU Utilization :
Five Seconds - 54 % One Minute - 48 % Five Minutes - 51 %
1. Подозрительно высокая нагрузка на процессор
2. Иногда появляються абоненты которые не отписываеться
3. На данный коммутатор появляеться незбожное количество прошивок, без каких то анотаций к нему. Хоть обьясните последнюю:
DES-1210-28-B2-6-05-T041.hex 21-May-2014 23:45 11M
Почему Т а не Б?
4. Вот ошибки с порта:
Command: show error ports 26
Port Number : 26
RX Frames TX Frames
CRC Error 0 Excessive Deferral 0
Undersize 0 CRC Error 0
Oversize 0 Late Collision 0
Fragment 0 Excessive Collision 0
Jabber 0 Single Collision 0
Drop Pkts 0 Collision 0
FWD Disc Pkts 1055207961
Что такое FWD Disc Pkts ? В мане на фтп не нашол ничего похожего
Заранее спасибо
 Заголовок сообщения: Re: DES-1210-28/ME B2
СообщениеДобавлено: Чт май 22, 2014 11:02
сомневаюсь что виной загрузки проца - мультикаст. у меня есть места, где на свиче по 12-15 каналов смотрят одновременно и загрузка не более 30%
СообщениеДобавлено: Чт май 22, 2014 13:07
И Я не могу понять в чем проблема. После перехода с 1228 на 1210 со старта начались пляски, загрузка проца 50% моментами до 100 подскакивает. Вроде сеть более менее в номральном ввиде, под менеджмент отдельный влан, мультикаст разделен. Веб отключен:
вывод top-a со свича, хотя даже не знаю как он может помочь.
em: 92508K used, 31584K free, 0K shrd, 7572K buff, 22940K cached
CPU: 43.7% usr 43.7% sys 0.0% nic 12.5% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 3.20 2.62 2.99 1/93 816
PID PPID USER STAT VSZ %MEM CPU %CPU COMMAND
657 623 root S 196m162.1 0 25.7 GphS
816 815 root R 2320 1.8 0 15.4 /usr/bin/top -n1
642 623 root S 196m162.1 0 10.2 ISS.exe
708 623 root S 196m162.1 0 10.2 ISS.exe
645 623 root S 196m162.1 0 10.2 ISS.exe
650 623 root S 196m162.1 0 5.1 CFA
638 623 root S 196m162.1 0 5.1 ISS.exe
659 623 root S 196m162.1 0 5.1 VLAN
643 623 root S 196m162.1 0 0.0 ISS.exe
669 623 root S 196m162.1 0 0.0 IPFW
640 623 root S 196m162.1 0 0.0 ISS.exe
671 623 root S 196m162.1 0 0.0 ARP
644 623 root S 196m162.1 0 0.0 ISS.exe
646 623 root S 196m162.1 0 0.0 ISS.exe
698 623 root S 196m162.1 0 0.0 PORT
664 623 root S 196m162.1 0 0.0 SnpT
680 623 root S 196m162.1 0 0.0 DCS
693 623 root S 196m162.1 0 0.0 SNTP
670 623 root S 196m162.1 0 0.0 UDP
709 623 root S 196m162.1 0 0.0 MSR
Трафик контроль отключал, ддос гварды тоже, safeguard engine выключен
Подскажите позжалуйста что не так. Когда загрузка проца достигает 100%, команды по консоле ввести нереально, иногда пингуеться с потерями. (про высокий ms молчу)
СообщениеДобавлено: Чт май 22, 2014 14:23
traffic segmentation используете?
PS обсуждение DES-1210/ME ведется в соседней ветке - на будущее.
СообщениеДобавлено: Пт май 23, 2014 08:52
Извиняюсь за предоставленые неудобства лишней темой.
Нет сегментирования трафиком не исользуеться:
DES-1210-28/ME:5# show traffic_segmentation
Command: show traffic_segmentation
Port Forward Portlist
1 1-28
2 1-28
3 1-28
4 1-28
5 1-28
6 1-28
7 1-28
8 1-28
9 1-28
10 1-28
11 1-28
12 1-28
13 1-28
14 1-28
15 1-28
16 1-28
17 1-28
18 1-28
19 1-28
20 1-28
21 1-28
22 1-28
23 1-28
24 1-28
25 1-28
26 1-28
27 1-28
28 1-28
СообщениеДобавлено: Пт май 23, 2014 10:31
По существу.
1. Если загрузка не испытывает всплесков - беспокоиться рано.
2. Приходят ли от этих клиентов leave? Что при этом происходит и при каких обстоятельствах?
3. Берите прошивки с форума.
4. FWD Disc Pkts - временный счетчик, введенный для анализа проблем, возникающих при передаче трафика, в основном - мультикаста.
СообщениеДобавлено: Чт май 25, 2017 14:05
1. Прошил свой DES-1210-28/ME
было
System Boot Version : 1.00.012
System Firmware Version : 6.10.B020
стало:
System Firmware Version : 6.10.B028
Обновилась только прошвка, а не BOOT. Это нормально?
Временному счётчику 3 года уже. Если проблемы с мультикастом и онлайн-тв - в какую сторону копать?
На портах растут Excessive Deferral и FWD Disc Pkts .
Ещё вопрос - коммутаторы не пингуются выше 1472. Почему?
СообщениеДобавлено: Чт май 25, 2017 19:37
потому что при 1472 общий размер пакета с заголовками получается как раз 1500
СообщениеДобавлено: Чт май 25, 2017 19:57
и что? Я вкурсе про стандартный размер MTU. Что дальше?
Что-то в настройках не так? на коммутаторах других моделей этой проблемы нет.
Все отвечают на фрагментированный пинг, а этот нет...
СообщениеДобавлено: Вт май 30, 2017 09:05
все так в настройках..
просто данный коммутатор подешевле, потому и мозгов в нем поменьше, вот и ответ (как ни обидно это звучит).
-Временному счётчику 3 года уже - это точно!
Никто не может внятно ответить, почему этот счетчик растет, ответы расплывчатые и общие, скорее всего это фишка программистов, которые ее сделали в момент отладки да забыли про нее.
Сейчас этот форум просматривают: Google [Bot] и гости: 17
