Текущее время: Чт сен 03, 2026 04:36
Начать новую тему Ответить на тему  [ Сообщений: 63 ]  На страницу 1, 2, 3, 4, 5  След.
 Заголовок сообщения: DES-3200-18, не видит соседей по LLDP
СообщениеДобавлено: Чт сен 04, 2014 12:53
Device Type        : DES-3200-18 Fast Ethernet Switch
Boot PROM Version  : Build 1.00.007
Firmware Version   : Build 1.84.B006
Hardware Version   : B1
GVRP               : Disabled
IGMP Snooping      : Enabled
LLDP System Information
    Chassis Id Subtype        : MAC Address
    Chassis Id                : 28-10-7B-FA-2D-B8
    System Name               : s317-1-1
    System Description        : Fast Ethernet Switch
    System Capabilities       : Repeater, Bridge
LLDP Configurations
    LLDP Status               : Enable
    LLDP Forward Status       : Disable
    Message Tx Interval       : 30
    Message Tx Hold Multiplier: 4
    ReInit Delay              : 2
    Tx Delay                  : 2
    Notification Interval     : 5
Command: show lldp remote_ports
Remote Entities Count : 0
Command: show lldp local_ports 17-18
Port ID : 17
Port Id Subtype                            : Local
Port Id                                    : 1/17
Port Description                           : D-Link DES-3200-18 R1.84 Port 17
Port VLAN ID                               : 1
Management Address Count                   : 1
PPVID Entries Count                        : 0
VLAN Name Entries Count                    : 5
Protocol Identity Entries Count            : 1
MAC/PHY Configuration/Status               : (See detail)
Power Via MDI                              : (See detail)
Link Aggregation                           : (See detail)
Maximum Frame Size                         : 1536
Port ID : 18
Port Id                                    : 1/18
Port Description                           : D-Link DES-3200-18 R1.84 Port 18
Port VLAN ID                               : 1
Command: show gvrp 17-18
Global GVRP  : Disabled
Port  PVID  Reassigned  GVRP      Ingress   Acceptable Frame Type
            PVID        State     Checking
17    1     -           Disabled    Enabled     All Frames
18    1     -           Disabled    Enabled     All Frames
Total Entries  : 2
 Заголовок сообщения: Re: DES-3200-18, не видит соседей по LLDP
СообщениеДобавлено: Чт сен 04, 2014 12:56
Command: show lldp ports 17
Port ID                 : 17
Admin Status            : TX_and_RX
Notification Status     : Disable
Advertised TLVs Option  :
    Port Description                                      Enable
    System Name                                           Enable
    System Description                                    Enable
    System Capabilities                                   Enable
    Enabled Management Address
        (NONE)
    Port VLAN ID                                          Disable
    Enabled Port_and_protocol_VLAN_ID
        (NONE)
    Enabled VLAN Name
        (NONE)
    Enabled Protocol_identity
        (NONE)
    MAC/PHY Configuration/Status                          Disable
    Power Via MDI                                         Disable
    Link Aggregation                                      Disable
    Maximum Frame Size                                    Disable
СообщениеДобавлено: Чт сен 04, 2014 13:10
http://forum.dlink.ru/viewtopic.php?f=2&t=156053&start=75#p875508
rmika писал(а):
На коммутаторах (des-3200) прошивкой 1.83.B004, 1.83.B005 не работает (не видет соседей) lldp пока не скажешь "config gvrp 25-28 state disable ingress_checking disable"
На 1.21.B006 работало сразу
но мне это не помогло, да и pvid`ы у меня корректные.
СообщениеДобавлено: Чт сен 04, 2014 19:28
Dlink'овцы, ау, расскажите, известно ли о такой проблеме или я чего-то не донастроил?
СообщениеДобавлено: Пт сен 05, 2014 11:29
На прошивке 1.84.B010 проблема на стенде не подтвердилась. Попробуйте обновить ПО. https://cloud.dlink.ru/owcl/public.php? ... 3&download
Если же проблема останется, то приложите пожалуйста конфиг DES-3200-18.
Спасибо.
СообщениеДобавлено: Пт сен 05, 2014 12:01
Спасибо, но и с B010 все так же. Выслал вам на почту конфиг.
upd:
# DES-3200-18 Configuration
# Firmware: Build 1.84.B010
# Copyright(C) 2010 D-Link Corporation. All rights reserved.
# BASIC
config serial_port baud_rate 9600 auto_logout 10_minutes
# ACCOUNT LIST
# ACCOUNT END
# PASSWORD ENCRYPTION
disable password encryption
config terminal_line default
enable clipaging
disable command logging
enable password_recovery
# STORM
config traffic control_trap none
config traffic control 1-16 broadcast enable multicast enable unicast disable action shutdown threshold 500 countdown 5 time_interval 5
config traffic control 17-18 broadcast disable multicast disable unicast disable action drop threshold 64 countdown 0 time_interval 5
# LOOP_DETECT
disable loopdetect
config loopdetect recover_timer 60
config loopdetect interval 10
config loopdetect mode port-based
config loopdetect trap none
config loopdetect ports 1-18 state disabled
# QOS
config scheduling_mechanism strict
config scheduling 0 strict
config scheduling 0 weight 1
config scheduling 1 weight 2
config scheduling 2 weight 4
config scheduling 3 weight 8
config 802.1p user_priority 0 1
config 802.1p user_priority 1 0
config 802.1p user_priority 2 0
config 802.1p user_priority 3 1
config 802.1p user_priority 4 2
config 802.1p user_priority 5 2
config 802.1p user_priority 6 3
config 802.1p user_priority 7 3
config cos tos value 0 class 0
config cos tos value 1 class 0
config cos tos value 2 class 0
config cos tos value 3 class 0
config cos tos value 4 class 0
config cos tos value 5 class 0
config cos tos value 6 class 0
config cos tos value 7 class 0
config dscp_mapping dscp_value 0 class 0
config dscp_mapping dscp_value 1 class 0
config dscp_mapping dscp_value 2 class 0
config dscp_mapping dscp_value 3 class 0
config dscp_mapping dscp_value 4 class 0
config dscp_mapping dscp_value 5 class 0
config dscp_mapping dscp_value 6 class 0
config dscp_mapping dscp_value 7 class 0
config dscp_mapping dscp_value 8 class 0
config dscp_mapping dscp_value 9 class 0
config dscp_mapping dscp_value 10 class 0
config dscp_mapping dscp_value 11 class 0
config dscp_mapping dscp_value 12 class 0
config dscp_mapping dscp_value 13 class 0
config dscp_mapping dscp_value 14 class 0
config dscp_mapping dscp_value 15 class 0
config dscp_mapping dscp_value 16 class 0
config dscp_mapping dscp_value 17 class 0
config dscp_mapping dscp_value 18 class 0
config dscp_mapping dscp_value 19 class 0
config dscp_mapping dscp_value 20 class 0
config dscp_mapping dscp_value 21 class 0
config dscp_mapping dscp_value 22 class 0
config dscp_mapping dscp_value 23 class 0
config dscp_mapping dscp_value 24 class 0
config dscp_mapping dscp_value 25 class 0
config dscp_mapping dscp_value 26 class 0
config dscp_mapping dscp_value 27 class 0
config dscp_mapping dscp_value 28 class 0
config dscp_mapping dscp_value 29 class 0
config dscp_mapping dscp_value 30 class 0
config dscp_mapping dscp_value 31 class 0
config dscp_mapping dscp_value 32 class 0
config dscp_mapping dscp_value 33 class 0
config dscp_mapping dscp_value 34 class 0
config dscp_mapping dscp_value 35 class 0
config dscp_mapping dscp_value 36 class 0
config dscp_mapping dscp_value 37 class 0
config dscp_mapping dscp_value 38 class 0
config dscp_mapping dscp_value 39 class 0
config dscp_mapping dscp_value 40 class 0
config dscp_mapping dscp_value 41 class 0
config dscp_mapping dscp_value 42 class 0
config dscp_mapping dscp_value 43 class 0
config dscp_mapping dscp_value 44 class 0
config dscp_mapping dscp_value 45 class 0
config dscp_mapping dscp_value 46 class 0
config dscp_mapping dscp_value 47 class 0
config dscp_mapping dscp_value 48 class 0
config dscp_mapping dscp_value 49 class 0
config dscp_mapping dscp_value 50 class 0
config dscp_mapping dscp_value 51 class 0
config dscp_mapping dscp_value 52 class 0
config dscp_mapping dscp_value 53 class 0
config dscp_mapping dscp_value 54 class 0
config dscp_mapping dscp_value 55 class 0
config dscp_mapping dscp_value 56 class 0
config dscp_mapping dscp_value 57 class 0
config dscp_mapping dscp_value 58 class 0
config dscp_mapping dscp_value 59 class 0
config dscp_mapping dscp_value 60 class 0
config dscp_mapping dscp_value 61 class 0
config dscp_mapping dscp_value 62 class 0
config dscp_mapping dscp_value 63 class 0
config 802.1p default_priority 1-18 0
config cos mapping port 1-18 ethernet 802.1p
# MIRROR
disable mirror
config mirror port 1 delete source ports 1 both
# BANDWIDTH
config bandwidth_control 1-18 rx_rate no_limit tx_rate no_limit
config per_queue bandwidth_control ports 1-18 0 max_rate no_limit
config per_queue bandwidth_control ports 1-18 1 max_rate no_limit
config per_queue bandwidth_control ports 1-18 2 max_rate no_limit
config per_queue bandwidth_control ports 1-18 3 max_rate no_limit
# SYSLOG
enable syslog
create syslog host 1 ipaddress 192.168.253.4 severity all facility local6 udp_port 514 state enable
config log_save_timing on_demand
# TRAF-SEGMENTATION
config traffic_segmentation 1-18 forward_list 1-18
# PACKET_FROM_CPU
config mgmt_pkt_priority default
# SSL
disable ssl
enable ssl ciphersuite RSA_with_RC4_128_MD5
enable ssl ciphersuite RSA_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite DHE_DSS_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite RSA_EXPORT_with_RC4_40_MD5
config ssl cachetimeout 600
# PORT
enable jumbo_frame
config ports 1-17 speed auto flow_control disable state enable clear_description
config ports 1-17 learning enable
config ports 1-17 mdix auto
config autocable_diag ports 1-17 state disable
config ports 17-18 medium_type fiber speed auto flow_control disable state enable clear_description
config ports 17-18 medium_type fiber learning enable
# OAM
# DDM
config ddm trap disable
config ddm log enable
config ddm ports 17-18 state enable shutdown none
# TIME_RANGE
# GM
config sim candidate
disable sim
config sim dp_interval 30
config sim hold_time 100
# MANAGEMENT
enable snmp traps
enable snmp authenticate_traps
enable snmp linkchange_traps
config snmp linkchange_traps ports all enable
config snmp system_name s317-1-1
config snmp system_location Gercena 68/2 TC EXTRA
disable rmon
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp view restricted all
delete snmp view CommunityView all
delete snmp group public
delete snmp group private
delete snmp group ReadGroup
delete snmp group WriteGroup
config snmp engineID 800000ab0328107bfa2db8
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group initial v3 noauth_nopriv read_view restricted notify_view restricted
create snmp group s317-1-1 v1 read_view CommunityView notify_view CommunityView
create snmp group s317-1-1 v2c read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v1 read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v2c read_view CommunityView notify_view CommunityView
create snmp group s317-1-1w v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group s317-1-1w v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group WriteGroup v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group WriteGroup v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group montomcomro v1 read_view CommunityView notify_view CommunityView
create snmp group montomcomro v2c read_view CommunityView notify_view CommunityView
create snmp community montomcomro view CommunityView read_only
create snmp community s317-1-1 view CommunityView read_only
create snmp community s317-1-1w view CommunityView read_write
create snmp user initial initial
create snmp host 192.168.252.2 v1 s317-1-1
disable community_encryption
# VLAN
disable asymmetric_vlan
enable pvid auto_assign
config vlan default delete 1-18
config vlan default advertisement enable
config vlan default add untagged 17-18
create vlan east tag 16
config vlan east add tagged 17-18
config vlan east add untagged 1,3-7,9-16
create vlan allegro tag 953
config vlan allegro add tagged 17-18
config vlan allegro add untagged 8
create vlan rayff tag 992
config vlan rayff add tagged 17-18
config vlan rayff add untagged 2
disable qinq
disable gvrp
config qinq ports 1-18 role nni outer_tpid 0x88A8 trust_cvid disable vlan_translation disable
config gvrp 1,3-7,9-16 state disable ingress_checking enable acceptable_frame admit_all pvid 16
config gvrp 2 state disable ingress_checking enable acceptable_frame admit_all pvid 992
config gvrp 8 state disable ingress_checking enable acceptable_frame admit_all pvid 953
config gvrp 17-18 state disable ingress_checking enable acceptable_frame admit_all pvid 1
# PROTOCOL_VLAN
# 8021X
disable 802.1x
config 802.1x auth_protocol radius_eap
config radius parameter timeout 5 retransmit 2
config 802.1x capability ports 1-18 none
config 802.1x auth_parameter ports 1-18 direction both port_control auto quiet_period 60 tx_period 30 supp_timeout 30 server_timeout 30 max_req 2 reauth_period 3600 enable_reauth disable
# PORT_LOCK
disable port_security trap_log
config port_security ports 1-18 admin_state disable max_learning_addr 1 lock_address_mode DeleteOnTimeout
# PPPOE
config pppoe circuit_id_insertion state disable
config pppoe circuit_id_insertion ports 1-18 state enable circuit_id ip remote_id default
# MAC_ADDRESS_TABLE_NOTIFICATION
config mac_notification interval 1 historysize 1
disable mac_notification
config mac_notification ports 1-18 disable
# LACP
config lacp_ports 1-18 mode passive
config link_aggregation algorithm mac_source
# STP
config stp version rstp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu enable hellotime 2
config stp nni_bpdu_addr dot1d
config stp priority 36864 instance_id 0
config stp mst_config_id name 28:10:7B:FA:2D:B8 revision_level 0
config stp ports 1-16 externalCost auto edge true p2p auto state enable
config stp mst_ports 1-18 instance_id 0 internalCost auto priority 128
config stp ports 1-18 fbpdu disable
config stp ports 1-16 restricted_role true
config stp ports 1-16 restricted_tcn true
config stp loop_guard ports 1-18 state disable
config stp ports 17-18 externalCost auto edge false p2p auto state enable
config stp ports 17-18 restricted_role false
config stp ports 17-18 restricted_tcn false
enable stp
# ERPS
config erps log disable
config erps trap disable
disable erps
# MULTI FILTER
config control_pkt ipv4 igmp replace priority none dscp none
config control_pkt ipv4 vrrp replace priority none dscp none
config control_pkt ipv4 rip replace priority none dscp none
config control_pkt ipv4 pim replace priority none dscp none
config control_pkt ipv4 dvmrp replace priority none dscp none
config control_pkt ipv4 ospf replace priority none dscp none
config control_pkt ipv6 mld replace priority none dscp none
config control_pkt ipv6 pim replace priority none dscp none
config control_pkt ipv6 ospf replace priority none dscp none
config control_pkt ipv6 ripng replace priority none dscp none
config control_pkt ipv6 nd replace priority none dscp none
config max_mcast_group ports 1-18 max_group 1024
config max_mcast_group ports 1-18 ipv6 max_group 1024
# BPDU_TUNNEL
config bpdu_tunnel ports all type none
disable bpdu_tunnel
# BPDU_PROTECTION
config bpdu_protection ports 1-18 mode shutdown
# SAFEGUARD_ENGINE
config safeguard_engine state disable utilization rising 30 falling 20 trap_log disable mode fuzzy
# BANNER_PROMP
config command_prompt s317-1-1
config greeting_message default
# SSH
config ssh algorithm 3DES enable
config ssh algorithm AES128 enable
config ssh algorithm AES192 enable
config ssh algorithm AES256 enable
config ssh algorithm arcfour enable
config ssh algorithm blowfish enable
config ssh algorithm cast128 enable
config ssh algorithm twofish128 enable
config ssh algorithm twofish192 enable
config ssh algorithm twofish256 enable
config ssh algorithm MD5 enable
config ssh algorithm SHA1 enable
config ssh algorithm RSA enable
config ssh algorithm DSA enable
config ssh authmode password enable
config ssh authmode publickey enable
config ssh authmode hostbased enable
config ssh server maxsession 8
config ssh server contimeout 120
config ssh server authfail 2
config ssh server rekey never
config ssh user expl authmode password
config ssh publickey bypass_login_screen state disable
disable ssh
# SNOOP
enable igmp_snooping
config igmp_snooping data_driven_learning max_learned_entry 56
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan iptv 14
config igmp_snooping multicast_vlan iptv state enable
config igmp_snooping multicast_vlan iptv add member_port 1-16
config igmp_snooping multicast_vlan iptv add source_port 17-18
config igmp_snooping vlan_name default state disable fast_leave disable report_suppression disable
config igmp_snooping data_driven_learning vlan_name default aged_out disable
config igmp_snooping querier all query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan_name iptv fast_leave disable report_suppression disable
config igmp_snooping data_driven_learning vlan_name iptv aged_out disable
config igmp_snooping vlan_name east state disable fast_leave disable report_suppression disable
config igmp_snooping data_driven_learning vlan_name east aged_out disable
config igmp_snooping vlan_name allegro state disable fast_leave disable report_suppression disable
config igmp_snooping data_driven_learning vlan_name allegro aged_out disable
config igmp_snooping vlan_name rayff state disable fast_leave disable report_suppression disable
config igmp_snooping data_driven_learning vlan_name rayff aged_out disable
config igmp access_authentication ports 1-18 state disable
# MLDSNP
# FDB
config fdb aging_time 300
config multicast port_filtering_mode 1-18 filter_unregistered_groups
disable flood_fdb
config flood_fdb log disable trap disable
config block tx ports 1-18 unicast disable
# VLAN_TRUNK
disable vlan_trunk
# SMTP
disable smtp
# ACL
create access_profile ip destination_ip 224.0.0.0 profile_id 1
config access_profile profile_id 1 add access_id 1 ip destination_ip 224.0.0.0 port 1-18 permit priority 5
disable cpu_interface_filtering
# SNTP
enable sntp
config time_zone operator + hour 7 min 0
config sntp primary 78.140.0.250 secondary 78.140.0.1 poll-interval 720
config dst disable
# RebootSchedule
# DOS_PREVENTION
disable dos_prevention trap_log
config dos_prevention dos_type land_attack action drop state enable
config dos_prevention dos_type blat_attack action drop state enable
config dos_prevention dos_type smurf_attack action drop state enable
config dos_prevention dos_type tcp_null_scan action drop state enable
config dos_prevention dos_type tcp_xmascan action drop state enable
config dos_prevention dos_type tcp_synfin action drop state enable
config dos_prevention dos_type tcp_syn_srcport_less_1024 action drop state disable
# DHCP_SERVER_SCREENING
config filter dhcp_server ports 1-18 state disable
config filter dhcp_server illegal_server_log_suppress_duration 5min
config filter dhcp_server trap disable
config filter dhcp_server log disable
# COMPOUND_AUTHENTICATION
config authentication ports 1-18 auth_mode host_based
config authentication ports 1-18 multi_authen_methods none
# ADDRBIND
config address_binding ip_mac ports 1,3-7,9 state enable loose allow_zeroip disable forward_dhcppkt disable
config address_binding ip_mac ports 1-18 mode arp stop_learning_threshold 500
config address_binding dhcp_snoop max_entry ports 1-18 limit 5
config address_binding dhcp_snoop max_entry ports 1-18 limit no_limit ipv6
config address_binding ip_mac ports 2,8,10-18 state disable allow_zeroip disable forward_dhcppkt enable
disable address_binding dhcp_snoop
create address_binding ip_mac ipaddr 78.140.8.48 mac_address 00-14-85-DB-22-A6 ports 4
create address_binding ip_mac ipaddr 78.140.8.77 mac_address 50-3D-E5-A0-CC-E1 ports 3
create address_binding ip_mac ipaddr 78.140.8.94 mac_address D4-CA-6D-D4-A5-29 ports 1
create address_binding ip_mac ipaddr 78.140.8.138 mac_address 74-D0-2B-C6-E2-7F ports 9
create address_binding ip_mac ipaddr 78.140.8.212 mac_address 00-25-22-C5-7B-B0 ports 5
create address_binding ip_mac ipaddr 78.140.8.217 mac_address 00-16-E6-90-BB-FB ports 6
create address_binding ip_mac ipaddr 78.140.8.222 mac_address 00-50-FC-1E-ED-D7 ports 7
disable address_binding trap_log
disable address_binding dhcp_snoop ipv6
# ARPSPOOF
# CFM
# IP
config ipif System vlan default ipaddress 192.168.254.122/24 state enable
config ipif System dhcp_option12 state disable
enable telnet 23
enable web 80
disable autoconfig
config autoconfig timeout 50
# MBA
disable mac_based_access_control
enable authorization attributes
config mac_based_access_control authorization attributes radius enable
config mac_based_access_control authorization attributes local enable
config mac_based_access_control trap state enable
config mac_based_access_control log state enable
config mac_based_access_control ports 1-18 state disable
config mac_based_access_control ports 1-18 mode host_based
config mac_based_access_control method local
config mac_based_access_control auth_failover disable
config mac_based_access_control password default
config mac_based_access_control max_users 128
# LLDP
enable lldp
config lldp message_tx_interval 30
config lldp tx_delay 2
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp ports 1-18 notification disable
config lldp ports 1-16 admin_status disable
config lldp ports 17-18 admin_status tx_and_rx
config lldp ports 17-18 basic_tlvs port_description system_name system_description system_capabilities enable
# ARP
config arp_aging time 20
config gratuitous_arp send ipif_status_up enable
config gratuitous_arp send dup_ip_detected enable
config gratuitous_arp learning enable
disable gratuitous_arp ipif System trap
enable gratuitous_arp ipif System log
# AAA
config authen_login default method local
config authen_enable default method local_enable
config authen application console login default
config authen application console enable default
config authen application telnet login default
config authen application telnet enable default
config authen application ssh login default
config authen application ssh enable default
config authen application http login default
config authen application http enable default
config authen parameter response_timeout 30
config authen parameter attempt 3
disable authen_policy
disable authen_policy_encryption
config admin local_enable
# DHCP_RELAY
disable dhcp_relay
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state disable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
config dhcp_relay option_82 circuit_id default
config dhcp_relay option_82 remote_id default
config dhcp_relay ports 1-18 state enable
# DHCP_LOCAL_RELAY
disable dhcp_local_relay
config dhcp_local_relay option_82 circuit_id default
config dhcp_local_relay option_82 remote_id default
config dhcp_local_relay option_82 ports 1-18 policy keep
# NDP
# ROUTE
create iproute default 192.168.254.2 1
# DHCPV6_LOCAL_RELAY
disable dhcpv6_local_relay
# RELAY6
config dhcpv6_relay hop_count 4
disable dhcpv6_relay
config dhcpv6_relay option_37 state disable check disable
config dhcpv6_relay option_37 remote_id default
config dhcpv6_relay option_18 state enable check disable
config dhcpv6_relay option_18 interface_id default
# End of configuration file for DES-3200-18
Строил другой кусок сети, еще на двух DES-3028-18 та же беда, но есть несколько, где соседи нашлись, буду сравнивать настройки.
СообщениеДобавлено: Пт сен 05, 2014 12:48
Ни о чем не говорит.
D-Link User: DGS-3120-24, DGS-3324SR, DGS-3627G, DGS-3612G, DGS-3312SR, DGS-3100-24TG, DGS-3200-10, DES-3200-26, DES-3200-28, DES-3200-18, DES-3528, DES-3526, DES-3028, DES-1228, DES-2108, DES-2110, DES-3326SR, DMC-920, DMC-810.
СообщениеДобавлено: Пт сен 05, 2014 12:58
Это вопрос или утверждение? Что не так в этом куске?
VLAN Trunk State        : Disabled
VLAN Trunk Member Ports :
VID             : 1           VLAN Name       : default
VLAN Type       : Static      Advertisement   : Enabled
Member Ports    : 17-18
Static Ports    : 17-18
Current Tagged Ports   :
Current Untagged Ports : 17-18
Static Tagged Ports    :
Static Untagged Ports  : 17-18
Forbidden Ports        :
СообщениеДобавлено: Пт сен 05, 2014 13:00
Command: show vlan ports 17-18
Port 17
VLAN ID  Untagged  Tagged  Forbidden  Dynamic
 1          X        -         -         -
 16         -        X         -         -
 953        -        X         -         -
 992        -        X         -         -
Port 18
 1          X        -         -         -
 16         -        X         -         -
 953        -        X         -         -
 992        -        X         -         -
СообщениеДобавлено: Сб сен 06, 2014 06:36
поставьте в пвид номер влана управления.
СообщениеДобавлено: Вс сен 07, 2014 08:52
zhenyatsk
pvid должен соответствовать существующему влану, так и есть, он равен 1 (default vlan).
что тут неправильно?
СообщениеДобавлено: Пн сен 08, 2014 07:39
Это сосед:
Port ID : 6
    lldpStatsTxPortFramesTotal           : 11220
    lldpStatsRxPortFramesDiscardedTotal  : 0
    lldpStatsRxPortFramesErrors          : 0
    lldpStatsRxPortFramesTotal           : 11216
    lldpStatsRxPortTLVsDiscardedTotal    : 0
    lldpStatsRxPortTLVsUnrecognizedTotal : 0
    lldpStatsRxPortAgeoutsTotal          : 1
Это DES-3028-18
Port ID : 17
    lldpStatsTxPortFramesTotal           : 8112
    lldpStatsRxPortFramesDiscardedTotal  : 8112
    lldpStatsRxPortFramesErrors          : 8112
    lldpStatsRxPortFramesTotal           : 8112
    lldpStatsRxPortAgeoutsTotal          : 0
СообщениеДобавлено: Пн сен 08, 2014 07:59
Полагаю, несовпадение формата пакета. Попробуйте на обоих коммутаторах обновить прошивку.
СообщениеДобавлено: Пн сен 08, 2014 08:00
А вот немного про счетчики:
Счетчик, который представляет число удалений по устареванию информации, имевших ме-
сто для заданного порта. Ликвидация по устареванию представляет собой число операций,
когда полный набор информации, анонсированной соседним устройством, был удален из
таблиц, содержащихся в объекте lldpRemoteSystemsData, по причине истечения интервала
времени актуальности данной информации.
Количество LLDP-кадров, принятых этим LLDP-агентом указанного порта, а затем удаленных
по любой причине. Этот счетчик может обеспечить индикацию того, что могут существовать
проблемы форматирования LLDP-заголовка для локального LLDP-агента в передающей
системе, либо того, что проблемы валидации LLDPDU могут существовать для локального
LLDP-агента в принимающей системе.
Количество недопустимых LLDP-кадров, принятых этим LLDP-агентом указанного порта,
пока данный LLDP-агент активен.
Количество допустимых LLDP-кадров, принятых этим LLDP-агентом указанного порта,
СообщениеДобавлено: Пн сен 08, 2014 09:04
Увы, это не помогло:
Device Type        : DES-3028 Fast Ethernet Switch
Boot PROM Version  : Build 1.00.B06
Firmware Version   : Build 2.94.B05
Hardware Version   : A1
Port ID : 6
    lldpStatsRxPortFramesTotal           : 12
Firmware Version   : Build 1.84.B010
Port ID : 17
    lldpStatsTxPortFramesTotal           : 8290
    lldpStatsRxPortFramesDiscardedTotal  : 8287
    lldpStatsRxPortFramesErrors          : 8287
    lldpStatsRxPortFramesTotal           : 8288
Сейчас этот форум просматривают: Google [Bot] и гости: 18
