Текущее время: Вс сен 06, 2026 05:48
СообщениеДобавлено: Сб мар 12, 2016 18:57
DES-3200-52
KURххххххх:admin#show switch
Command: show switch
Device Type : DES-3200-52 Fast Ethernet Switch
MAC Address : хх-хх-хх-хх-хх-хх-хх
IP Address : хх.хх.хх.хх (Manual)
VLAN Name : MGMT
Subnet Mask : ххх.ххх.ххх.ххх
Default Gateway : ххх.ххх.ххх.ххх
Boot PROM Version : Build 4.00.002
Firmware Version : Build 4.38.B000
Hardware Version : C1
Serial Number : RZBI1E6001431
System Name :
System Location :
System Uptime : 0 days, 2 hours, 46 minutes, 12 seconds
System Contact :
Spanning Tree : Disabled
GVRP : Enabled
IGMP Snooping : Enabled
MLD Snooping : Disabled
VLAN Trunk : Disabled
Telnet : Enabled (TCP 23)
Web : Disabled
SNMP : Enabled
SSL Status : Disabled
SSH Status : Disabled
802.1X : Disabled
Jumbo Frame : Enabled
CLI Paging : Enabled
MAC Notification : Disabled
Port Mirror : Disabled
SNTP : Disabled
Syslog Global State : Disabled
Single IP Management : Disabled
Password Encryption Status : Enabled
Свич работал долго, больше 200 дней, проблем не было никаких.
Пару дней назад начались проблемы.
KUR-хххххх:admin#show log
Command: show log
Index Date Time Level Log Text
56 2016-03-12 17:31:15 INFO(6) Port 23 link up, 100Mbps FULL duplex
55 2016-03-12 17:31:07 INFO(6) Port 23 link down
54 2016-03-12 16:52:28 INFO(6) Port 17 link down
53 2016-03-12 16:38:35 INFO(6) Port 14 link up, 100Mbps FULL duplex
52 2016-03-12 16:38:33 INFO(6) Port 14 link down
51 2016-03-12 16:38:23 INFO(6) Port 14 link up, 100Mbps FULL duplex
50 2016-03-12 16:26:42 INFO(6) Port 17 link up, 100Mbps FULL duplex
45 2016-03-12 15:36:24 INFO(6) Port 8 link up, 100Mbps FULL duplex
44 2016-03-12 15:36:22 INFO(6) Port 8 link down
43 2016-03-12 15:36:20 INFO(6) Port 8 link up, 100Mbps FULL duplex
42 2016-03-12 15:36:10 INFO(6) Port 8 link down
40 2016-03-12 15:29:12 INFO(6) Port 1 link down
38 2016-03-12 15:14:53 INFO(6) Port 7 link up, 10Mbps FULL duplex
36 2016-03-12 15:14:50 INFO(6) Port 7 link down
35 2016-03-12 15:14:50 INFO(6) Port 7 link up, 10Mbps FULL duplex
34 2016-03-12 15:14:50 INFO(6) Port 7 link down
33 2016-03-12 15:13:54 INFO(6) Port 7 link up, 100Mbps FULL duplex
32 2016-03-12 15:13:52 INFO(6) Port 7 link down
31 2016-03-12 15:13:06 INFO(6) Port 7 link up, 100Mbps FULL duplex
30 2016-03-12 15:13:04 INFO(6) Port 7 link down
28 2016-03-12 15:07:47 INFO(6) Port 7 link up, 100Mbps FULL duplex
27 2016-03-12 15:07:46 INFO(6) Port 7 link down
25 2016-03-12 15:07:17 INFO(6) Port 20 link up, 100Mbps FULL duplex
24 2016-03-12 15:07:15 INFO(6) Port 20 link down
23 2016-03-12 15:07:12 INFO(6) Port 15 link up,
На портах ошибок нет.
На аплинке ошибок нет. На порту ядра, куда приходит линк с этого коммутатора, тоже ошибок нет.
Куда ковырять? )
СообщениеДобавлено: Сб мар 12, 2016 20:27
Для начала обновите софт
СообщениеДобавлено: Пн мар 14, 2016 13:25
Firmware Version : Build 4.42.B003
Обновил.
Последим.
Выяснилась ещё одна подробность. В момент, когда абоненты звонят с жалобой на отсутствие услуги, их оборудование отвечает на запросы. Т.е. пингуется, без потерь и ошибок вообще.
СообщениеДобавлено: Ср мар 30, 2016 16:11
Проблема не ушла.
Т.е. прошивка вообще не помогла.
Порты хлопают как и раньше.
СообщениеДобавлено: Чт мар 31, 2016 11:37
Похожая тема.
Сейчас этот форум просматривают: Google [Bot] и гости: 12
