Текущее время: Ср авг 19, 2026 00:58
СообщениеДобавлено: Ср апр 18, 2012 10:48
Настройки, касательно мультикаста:
create access_profile ip destination_ip_mask 255.255.248.0 profile_id 7
config access_profile profile_id 7 add access_id auto_assign ip destination_ip 239.1.8.0 port 25-28 permit priority 6 replace_priority replace_dscp_with 48
create access_profile ip destination_ip_mask 240.0.0.0 profile_id 8
config access_profile profile_id 8 add access_id auto_assign ip destination_ip 224.0.0.0 port 1-24 deny
enable cpu_interface_filtering
create cpu access_profile profile_id 1 ip destination_ip_mask 255.255.255.252
config cpu access_profile profile_id 1 add access_id 1 ip destination_ip 224.0.0.0 port 1-24 permit
create cpu access_profile profile_id 2 ip destination_ip_mask 255.255.248.0
config cpu access_profile profile_id 2 add access_id 1 ip destination_ip 239.1.8.0 port 1-24 permit
create cpu access_profile profile_id 3 ip destination_ip_mask 240.0.0.0
config cpu access_profile profile_id 3 add access_id 1 ip destination_ip 224.0.0.0 port 1-24 deny
config limited_multicast_addr ports 1-28 delete profile_id 1
delete mcast_filter_profile profile_id 1
create mcast_filter_profile profile_id 1 profile_name iptv
config mcast_filter_profile profile_id 1 add 239.1.8.1-239.1.15.254
config limited_multicast_addr ports 1-24 add profile_id 1
enable igmp_snooping
enable igmp_snooping multicast_vlan
delete igmp_snooping multicast_vlan multicast-vlan
create igmp_snooping multicast_vlan multicast-vlan 950
config igmp_snooping multicast_vlan multicast-vlan state enable
config igmp_snooping multicast_vlan multicast-vlan replace_source_ip 10.14.0.1
config igmp_snooping vlan_name multicast-vlan fast_leave enable
config igmp_snooping data_driven_learning vlan_name multicast-vlan aged_out enable
config igmp_snooping multicast_vlan multicast-vlan add source_port 25
config igmp_snooping multicast_vlan multicast-vlan add tag_member_port 26,27,28
config igmp_snooping multicast_vlan multicast-vlan add member_port 1-24
config multicast port_filtering_mode all forward_unregistered_groups
Проблема заключается в том, что трафик нагружает CPU коммутатора. Как это уже стало традицией, проблема возникает бессистемно, воспроизведению не подлежит. Если на вышестоящем коммутаторе исключить downlink на проблемный коммутатор из tag_member_port то последний моментально оживает. flood fdb выключен.
p.s. Дополнительно насчет мультикаста: Иногда наблюдаю ситуацию, когда счетчики порта(ов) показывают необоснованно высокие значения TX. При отключении мультикаста в этот порт исходящий трафик пропадает. При этом за такими портами потребителей мультикаста в данный момент нет.
СообщениеДобавлено: Ср апр 18, 2012 11:07
config multicast port_filtering_mode all filter_unregistered_groups
СообщениеДобавлено: Ср апр 18, 2012 11:09
Это поможет? Дело в том, что если ставить filter то появляется такая проблема, как выборочное залипание каналов из разрешенного диапазона. Поэтому ставим forward - с такой настройкой этой проблемы нет.
СообщениеДобавлено: Ср апр 18, 2012 19:34
Мультикастовый трафик идёт мимо проца, сам трафик я имею в виду. Возможно у вас грузят процы подписки на группы.
Если при filter_unregistered_groups на всех портах у вас начинаются залипания трафа некоторых групп, значит проблема где-то ещё.
При включенном filter_unregistered_groups на портах проанализируйте ситуацию, сколько у вас igmp групп на коммутаторе и с каких вланов эти группы.
Если группы числятся на свиче, но зарегистрированы в пользовательских вланах - включайте на пользовательских вланах снупинг.
СообщениеДобавлено: Чт апр 19, 2012 02:19
А не пробовали отключать CPU ACL проблема остается? Когда группы залипали не пробовали смотреть flood? Есть группа на самом коммутаторе, льется ли группа с вышестоящего коммутатора? У нас залипали группы но только из-за flood. По поводу того что мультикаст идет мимо проца - это еще тот вопрос. У нас на 3528/52 возникали проблемы, что мультикаст в коммутаторе становился броадкастам, рассылался на все порты и на проц похоже, и коммутатор погибал. Помогало убрать мультикаст влан в сторону коммутатора, все передернуть на нем и обратно отдать влан - проблемы уходили. Так что варианты разные возможны :).
СообщениеДобавлено: Чт май 31, 2012 17:21
Как решили проблему?
СообщениеДобавлено: Сб июн 02, 2012 09:56
Пока никаких сдвигов нет. Мультикаст на D-Link'ах это еще та головная боль, встроенный функционал мониторинга flood fdb - тоже.
Была точка, где IPTV периодически сыпалось, во flood fdb пусто, замена свича/модулей/патчей ничего не дала. В итоге поставили старенький каталист - глюки как рукой сняло.
СообщениеДобавлено: Пн июн 04, 2012 01:33
У нас на 3200/3028/52 вообще никаких проблем (кроме флуда). Сейчас есть периодические проблемы на 3528/52 серии (как раз аномалии с трафиком и высокой загрузкой). А там где меняли на каталист какого рода проблема была? Раз в две минуты отваливается мультикаст? Нас помогало внимательно смотреть на настройки параметров квериера и коммутаторов доступа. В циске и длинке значения по умолчанию отличались.
СообщениеДобавлено: Пн июн 04, 2012 12:33
Это был конкретный бокс в доме. У всех, кто подключен оттуда, наблюдались кратковременные "цыкания" звука и изображения. Проявлялась проблема "раз на раз", в основном ближе к вечеру. Причем наблюдалась еще одна интересная аномалия: переключение канала одним абонентом вызывало кратковременное замирание картинки у других абонентов, причем даже у тех, что были подключены к другому коммутатору в том же боксе. Замена коммутаторов, модулей, патчей и т.д. ничего не дала. Заменили один из D-Link'ов на Catalyst - с тех пор все ровно.
p.s.
Коммутаторы квериером у нас не являются.
Как правильнее настраивать replace source ip на 3028/3200? Может вообще лучше отключать?
СообщениеДобавлено: Пн июн 04, 2012 14:57
xcme писал(а):
... Как правильнее настраивать replace source ip на 3028/3200? Может вообще лучше отключать?
Он должен быть уникальным на каждом коммутаторе, если данный параметр задаётся.
Бигаров Руслан.
СообщениеДобавлено: Пн июн 04, 2012 15:06
А в каком случае надо задавать, а в каком нет? В первом посте описаны наши настройки, касательно мультикаста. Может порекомендуете что-нибудь поменять?
СообщениеДобавлено: Пн июн 04, 2012 15:08
Здесь всё описано:
ftp://ftp.dlink.ru/pub/Trainings/D-Link ... ticast.zip
Бигаров Руслан.
СообщениеДобавлено: Вт июн 05, 2012 03:30
У нас реплейс не настроен. Проблем не наблюдаем. На 3528/52 включаем report supression. Фича очень хорошая. Помогла победить проблему с кратковременным пропаданием мультикаста. Может на новом софте в 3200 появилась, проверьте.
СообщениеДобавлено: Вт июн 05, 2012 10:19
При использовании "replace source ip" коммутатор проксирует запросы, без данной функции просто пробрасывает их, но в этом случае на агрегаторе нужно сделать соответствующую донастройку на IGMP интерфейсе. В презентации всё описано.
Бигаров Руслан.
СообщениеДобавлено: Вт ноя 24, 2015 08:10
Кто нибудь может подсказать команду для включения Report Supression на DES 3200-26 ревизия А1??Буду очень признателен!!В веб морде не нахожу данную функцию.Насколько я понимаю по сравнению с ревизией С у данных коммутаторов разный синтаксис.
