Текущее время: Пт авг 28, 2026 09:38
 Заголовок сообщения: LLDP и Jumbo Frame
СообщениеДобавлено: Ср июл 22, 2015 12:35
Свитч - DES-3200-28F/A1.
Прошивка - Build 1.85.B008.
#show jumbo_frame
Command: show jumbo_frame
Jumbo Frame State : Enabled
Maximum Jumbo Frame Size : 2048 Bytes
#sh lldp loc 26
Command: show lldp local_ports 26
Port ID : 26
Port Id Subtype : Local
Port Id : 1/26
Port Description : D-Link DES-3200-28F R1.85 Port 26
Port VLAN ID : 1037
Management Address Count : 1
PPVID Entries Count : 0
VLAN Name Entries Count : 9
Protocol Identity Entries Count : 0
MAC/PHY Configuration/Status : (See detail)
Power Via MDI : (See detail)
Link Aggregation : (See detail)
Maximum Frame Size : 1536
И с соседнего свитча DGS-3610, включенного в 26 порт:
172.16.37.193#sh lldp ne int gi 0/8
Lldp neighbor-information of port [GigabitEthernet 0/8]
Neighbor index : 1
Device type : LLDP Device
Update time : 12day 10hour 1minute 39second
Chassis ID type : MAC address
Chassis ID : 0026.5a97.cc80
System name : 172.16.37.190
System description : Fast Ethernet Switch
System capabilities supported : Repeater, Bridge
System capabilities enabled : Repeater, Bridge
Port ID type : Locally assigned
Port ID : 1/26
Port description : D-Link DES-3200-28F R1.85 Port 26
802.1 organizationally information
Port VLAN ID :
Port and protocol VLAN ID(PPVID) :
PPVID Supported :
PPVID Enabled :
VLAN name of VLAN 52 : vlan0052
VLAN name of VLAN 413 : vlan0413
VLAN name of VLAN 501 : vlan0501
VLAN name of VLAN 641 : vlan0641
VLAN name of VLAN 700 : vlan0700
VLAN name of VLAN 1005 : vlan1005
VLAN name of VLAN 1037 : vlan1037
VLAN name of VLAN 1067 : vlan1067
VLAN name of VLAN 4003 : vlan4003
Protocol Identity :
802.3 organizationally information
Auto-negotiation supported : YES
Auto-negotiation enabled : YES
PMD auto-negotiation advertised : 1000BASE-T full duplex mode, 1000BASE-X, -LX, -SX, -CX full duplex mode, 100BASE-TX full duplex mode, 100BASE-TX half duplex mode, 10BASE-T full duplex mode, 10BASE-T half duplex mode
Operational MAU type : dot3MauType1000BaseTFD: Four-pair Category 5 UTP, full duplex mode
PoE support : NO
Link aggregation supported : YES
Link aggregation enabled : NO
Aggregation port ID : 26
Maximum frame Size : 1536
И собственно вопрос - это LLDP некорректно отображает информацию или на свитче не включаются Jumbo Frame?
Т.к. сейчас на DES-3200-28F/A1 происходит распаковка QinQ канала, и есть подозрения что MTU не хватает.
P.S. Я понимаю, что для QinQ хватит и 1526, но я не знаю, что проходит через этот канал (там может быть MPLS). Поэтому хотелось бы понимать какой MTU все таки у DES-3200-28F/A1.
 Заголовок сообщения: Re: LLDP и Jumbo Frame
СообщениеДобавлено: Ср июл 22, 2015 13:54
Jumbo Frame:
Maximum Tag Frame: 2048bytes
Maximum Un-tag Frame: 2044bytes
СообщениеДобавлено: Ср июл 22, 2015 13:57
Тогда, LLDP показывает некорректную информацию, верно?
Хотелось бы, чтобы это было исправлено в ревизиях A1/B1, в C1 такой проблемы нет.
Maximum Tag Frame: 2084bytes
Maximum Tag Frame: 2048bytes ?
СообщениеДобавлено: Ср июл 22, 2015 14:24
Исправился. По поводу отображения информации LLDP я уточню в ШК.
СообщениеДобавлено: Пн авг 10, 2015 10:01
Выслал исправление Вам на почту. Пожалуйста, попробуйте и сообщите по результатам.
СообщениеДобавлено: Пн авг 10, 2015 10:15
На 1.85.B010 показывает корректный максимальный размер фрейма и локально, и с соседнего свитча.
Спасибо.
