Текущее время: Вт сен 29, 2026 19:22
 Заголовок сообщения: DES 3200-28 A1 не работает SNMPSET
СообщениеДобавлено: Вт апр 14, 2015 06:53
Good day!
Коммутатор DES 3200-28 A1 после прошивки DES-3200R_1.85.B008.had не срабатывает snmpset
для бэкапирования конфиги:
root@cacti:~# snmpset -v2c -c back 192.168.50.9 1.3.6.1.4.1.171.12.1.2.1.1.8.3 i 3
Error in packet.
Reason: commitFailed
Failed object: iso.3.6.1.4.1.171.12.1.2.1.1.8.3
Кто-нибудь столкнулся с подобной проблемой?
Заранее благодарен за помощь.
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp view restricted all
delete snmp view CommunityView all
delete snmp group public
delete snmp group private
delete snmp group ReadGroup
delete snmp group WriteGroup
config snmp engineID 800000ab0300265a8ab380
create snmp view back 1 view_type included
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group back v1 read_view back write_view back notify_view back
create snmp group back v2c read_view back write_view back notify_view back
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group initial v3 noauth_nopriv read_view restricted notify_view restricted
create snmp group ReadGroup v1 read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v2c read_view CommunityView notify_view CommunityView
create snmp group WriteGroup v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group WriteGroup v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp community back view back read_write
create snmp community public view CommunityView read_only
create snmp user initial initial
disable community_encryption
 Заголовок сообщения: Re: DES 3200-28 A1 не работает SNMPSET
СообщениеДобавлено: Вт апр 14, 2015 11:33
Ну и правильно делает, что выдаёт ошибку.
Вы делаете: agentBscSwFileCtrl (i) 3 - тип операции start
Комутатор тупо не понимает, что вы хотите этим сказать. Да и я тоже не понимаю.
Расскажите, каким образом вы хотите делать бекап конфига? на tftp слить? Какие команды указываются ДО этой?
СообщениеДобавлено: Вт апр 14, 2015 11:53
Да, таким образом я выгружал по tftp конфигу с коммутатора и всё было замечательно на прошивке DES-3200R_1.84.B015.had
(аналог команды download cfg_fromTFTP 192.168.50.20 src_file 1.txt).
На DES-3200R_1.85.B008.had коммутатор перестал меня понимать)
Как узнать какой OID используется теперь?
В кроне у меня выполнялось только root@cacti:~# snmpset -v2c -c back 192.168.50.9 1.3.6.1.4.1.171.12.1.2.1.1.8.3 i 3
СообщениеДобавлено: Вт апр 14, 2015 12:26
Парни, отбой!
Видимо после обновления прошивки видимо сбросилось то, что настраивал до этого и именно:
snmpset -v2c -c back 192.168.50.9 1.3.6.1.4.1.171.12.1.2.1.1.3.3 a 192.168.50.20 - установили ip tftp и что передаём (конфиг)
snmpset -v2c -c back 192.168.50.9 1.3.6.1.4.1.171.12.1.2.1.1.4.3 i 2 - способ передачи данных
snmpset -v2c -c back 192.168.50.9 1.3.6.1.4.1.171.12.1.2.1.1.5.3 s DES3200SW1.cfg - имя файла сохраняемого на ftp
snmpset -v2c -c back 192.168.50.9 1.3.6.1.4.1.171.12.1.2.1.1.7.3 i 2 - загрузка на tftp
snmpset -v2c -c back 192.168.50.9 1.3.6.1.4.1.171.12.1.2.1.1.8.3 i 3 - Поехали!
Всё работает.
СообщениеДобавлено: Вт апр 14, 2015 12:35
Лучше делайте это одним запросом:
snmpset -v2c -c back 192.168.50.9 1.3.6.1.4.1.171.12.1.2.1.1.3.3 a 192.168.50.20 1.3.6.1.4.1.171.12.1.2.1.1.4.3 i 2 1.3.6.1.4.1.171.12.1.2.1.1.5.3 s DES3200SW1.cfg 1.3.6.1.4.1.171.12.1.2.1.1.7.3 i 2 1.3.6.1.4.1.171.12.1.2.1.1.8.3 i 3
СообщениеДобавлено: Чт апр 16, 2015 14:55
Да, одним запросом много лучше, а иногда и вообще необходимо.
К тому же меньшее кол-во транзакций по сети, если будете работать с большим числом коммутаторов это придется учитывать.
ТС, посмотрите тут еще.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 77
