Текущее время: Пн сен 28, 2026 17:17
 Заголовок сообщения: DES-3528 IPMB (LBinet)
СообщениеДобавлено: Чт апр 02, 2015 10:13
Артём, вопрос скорее всего к вам, т.к. вы в курсе данных событий.
Build 3.10.B052
A5
DES-3528:admin#show config current_config include "address_binding"
Command: show config current_config include "address_binding"
config address_binding dhcp_snoop max_entry ports 1 limit no_limit
config address_binding dhcp_snoop max_entry ports 2 limit no_limit
config address_binding dhcp_snoop max_entry ports 3 limit no_limit
config address_binding dhcp_snoop max_entry ports 4 limit 1
config address_binding dhcp_snoop max_entry ports 5 limit 2
config address_binding dhcp_snoop max_entry ports 6 limit no_limit
config address_binding dhcp_snoop max_entry ports 7 limit no_limit
config address_binding dhcp_snoop max_entry ports 8 limit no_limit
config address_binding dhcp_snoop max_entry ports 9 limit no_limit
config address_binding dhcp_snoop max_entry ports 10 limit no_limit
config address_binding dhcp_snoop max_entry ports 11 limit no_limit
config address_binding dhcp_snoop max_entry ports 12 limit no_limit
config address_binding dhcp_snoop max_entry ports 13 limit no_limit
config address_binding dhcp_snoop max_entry ports 14 limit no_limit
config address_binding dhcp_snoop max_entry ports 15 limit no_limit
config address_binding dhcp_snoop max_entry ports 16 limit no_limit
config address_binding dhcp_snoop max_entry ports 17 limit no_limit
config address_binding dhcp_snoop max_entry ports 18 limit no_limit
config address_binding dhcp_snoop max_entry ports 19 limit no_limit
config address_binding dhcp_snoop max_entry ports 20 limit no_limit
config address_binding dhcp_snoop max_entry ports 21 limit no_limit
config address_binding dhcp_snoop max_entry ports 22 limit no_limit
config address_binding dhcp_snoop max_entry ports 23 limit no_limit
config address_binding dhcp_snoop max_entry ports 24 limit no_limit
config address_binding dhcp_snoop max_entry ports 25 limit 1
config address_binding dhcp_snoop max_entry ports 26 limit no_limit
config address_binding dhcp_snoop max_entry ports 27 limit no_limit
config address_binding dhcp_snoop max_entry ports 28 limit no_limit
config address_binding ip_mac ports 4-5,25 mode acl
config address_binding ip_mac ports 4-5 state enable strict
config address_binding ip_mac ports 4-5,25 allow_zeroip enable
enable address_binding dhcp_snoop
enable address_binding trap_log
disable address_binding dhcp_snoop ipv6
disable address_binding nd_snoop
config address_binding dhcp_snoop max_entry ports 1-28 limit no_limit ipv6
config address_binding nd_snoop ports 1-28 max_entry no_limit
DES-3528:admin#show config current_config include "dhcp_relay"
Command: show config current_config include "dhcp_relay"
enable dhcp_relay
config dhcp_relay hops 16 time 0
config dhcp_relay option_82 state enable
config dhcp_relay option_82 check enable
config dhcp_relay option_82 policy replace
 config dhcp_relay option_82 remote_id user_define 10.230.0.1
config dhcp_relay option_60 state disable
config dhcp_relay option_61 state disable
config dhcp_relay option_60 default mode drop
config dhcp_relay option_61 default drop
config dhcp_relay add vlanid 1000 100.100.254.253
В 5 порту клиент с iMac, срабатывают видимо какие то настройки сетевой карты (WOL, energy efficient ethernet?) видно как порт сам по себе включается и отключается, после этого почему то происходит discard.
Lease time устанолено в 300 сек. dhcp сервер такой же от LANBilling - LBinet.
На тестируемом стэнде замечаем такие записи в логах:
428   2015-04-02 09:22:19 INFO(6) Port 14 link up, 100Mbps FULL duplex
427   2015-04-02 09:20:16 INFO(6) Port 12 link up, 100Mbps FULL duplex
426   2015-04-02 09:20:14 INFO(6) Port 12 link down
425   2015-04-02 09:19:06 INFO(6) Port 12 link up, 10Mbps HALF duplex
424   2015-04-02 08:43:03 WARN(4) Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<100.100.0.3>, MAC:<C8-2A-14-22-15-99>, Port<5>)
423   2015-04-02 08:43:02 INFO(6) Port 5 link up, 100Mbps FULL duplex
422   2015-04-02 08:43:00 INFO(6) Port 5 link down
421   2015-04-02 08:36:33 INFO(6) Port 8 link up, 100Mbps FULL duplex
420   2015-04-02 08:36:31 INFO(6) Port 8 link down
419   2015-04-02 08:36:21 INFO(6) Port 8 link up, 10Mbps FULL duplex
418   2015-04-02 08:36:20 INFO(6) Port 8 link down
417   2015-04-02 06:54:15 WARN(4) Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<100.100.0.3>, MAC:<C8-2A-14-22-15-99>, Port<5>)
416   2015-04-02 06:54:14 INFO(6) Port 5 link up, 100Mbps FULL duplex
415   2015-04-02 06:54:12 INFO(6) Port 5 link down
414   2015-04-02 05:05:25 WARN(4) Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<100.100.0.3>, MAC:<C8-2A-14-22-15-99>, Port<5>)
413   2015-04-02 05:05:24 INFO(6) Port 5 link up, 100Mbps FULL duplex
412   2015-04-02 05:05:22 INFO(6) Port 5 link down
411   2015-04-02 03:16:35 WARN(4) Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<100.100.0.3>, MAC:<C8-2A-14-22-15-99>, Port<5>)
410   2015-04-02 03:16:34 INFO(6) Port 5 link up, 100Mbps FULL duplex
409   2015-04-02 03:16:32 INFO(6) Port 5 link down
408   2015-04-02 01:27:46 WARN(4) Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<100.100.0.3>, MAC:<C8-2A-14-22-15-99>, Port<5>)
407   2015-04-02 01:27:45 INFO(6) Port 5 link up, 100Mbps FULL duplex
406   2015-04-02 01:27:43 INFO(6) Port 5 link down
405   2015-04-01 23:38:57 WARN(4) Unauthenticated IP-MAC address and discarded by ip mac port binding(IP:<100.100.0.3>, MAC:<C8-2A-14-22-15-99>, Port<5>)
404   2015-04-01 23:38:56 INFO(6) Port 5 link up, 100Mbps FULL duplex
403   2015-04-01 23:38:54 INFO(6) Port 5 link down
 Заголовок сообщения: Re: DES-3528 IPMB (LBinet)
СообщениеДобавлено: Пт апр 03, 2015 12:48
Адрес 100.100.0.3 выдается сервером?
Прежде всего необходимо выяснить, почему хост отключает порт - смотрите софт и пр.
СообщениеДобавлено: Пн апр 06, 2015 11:06
Да, адрес выдаётся. Отключения происходят на 2 секунды, где-то каждые 2 часа.
СообщениеДобавлено: Вт апр 07, 2015 08:53
