Текущее время: Пн сен 28, 2026 13:02
 Заголовок сообщения: D-Link 3200-10 rev A1
СообщениеДобавлено: Пн мар 16, 2015 19:46
Здравствуйте все) Есть проблема следующего характера: иногда просто перестают создаваться запросы на IPTV.
коммутатор D-Link 3200-10 rev A1 Boot PROM Version : Build 1.00.B003 Firmware Version : Build 1.85.B007
конфиг
enable igmp_snooping
config igmp_snooping data_driven_learning max_learned_entry 200
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan mcast 3101
config igmp_snooping multicast_vlan mcast state enable
config igmp_snooping multicast_vlan mcast replace_source_ip 10.10.200.228
config igmp_snooping multicast_vlan mcast add member_port 1-8
config igmp_snooping multicast_vlan mcast add source_port 9-10
config igmp_snooping multicast_vlan_group mcast add 239.1.1.1-239.1.1.254,224.2 .127.254
config igmp_snooping vlan_name default state disable fast_leave disable report_s uppression disable
config igmp_snooping data_driven_learning vlan_name default aged_out disable
config igmp_snooping querier all query_interval 125 max_response_time 10 robustn ess_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan_name mgmt state disable fast_leave disable report_supp ression disable
config igmp_snooping data_driven_learning vlan_name mgmt aged_out disable
config igmp_snooping vlan_name mcast fast_leave disable report_suppression enabl e
config igmp_snooping data_driven_learning vlan_name mcast aged_out disable
config igmp_snooping querier vlan_name mcast query_interval 200 max_response_tim e 20 robustness_variable 200 last_member_query_interval 20 state disable version 2
config igmp_snooping vlan_name asta_z state disable fast_leave disable report_su ppression disable
config igmp_snooping data_driven_learning vlan_name asta_z aged_out disable
config igmp_snooping vlan_name adtv state disable fast_leave disable report_supp ression disable
config igmp_snooping data_driven_learning vlan_name asta1 aged_out disable
config igmp access_authentication ports 1-10 state disable
У абонента приставка подключена напрямую. Такая проблема у всех подключенных абонентов к этому коммутатору.
Сегментация траффика
Traffic Segmentation Table
Port Forward Portlist
1 9-10
2 9-10
3 9-10
4 9-10
5 9-10
6 9-10
7 9-10
8 9-10
9 1-10
10 1-10
Траффик контрол никаких ограничений. Прошу помощи.
 Заголовок сообщения: Re: D-Link 3200-10 rev A1
СообщениеДобавлено: Вт мар 17, 2015 11:25
Как часто возникает проблема? после чего запросы снова начинают создаваться?
СообщениеДобавлено: Вт мар 17, 2015 16:10
Полный рандом. Иногда группа может создаться но не уходить дальше этого коммутатора. Такая проблема со всеми портами. пробовали делать его курьером всё одно(
СообщениеДобавлено: Пт мар 20, 2015 15:31
Querier в сети должен быть только один. Попробуйте добавить следующие настройки:
config igmp_snooping vlan_name mcast fast_leave disable report_suppression disable
config router_ports mcast add 9-10
Сейчас этот форум просматривают: Google [Bot], Majestic-12 [Bot] и гости: 29
