Текущее время: Пн сен 28, 2026 23:48
СообщениеДобавлено: Пн окт 20, 2014 18:32
После включения колец по технологии Erps, наблюдаются проблемы в работе сети, а именно после потери сигнала на некоторых узлах, пропадает доступ и на других кольцах, к примеру лог последнего падения:
70885 2014-10-20 18:33:37 NOTI(5) Signal failure cleared on node 00-26-5A-39-6D-F0
70884 2014-10-20 18:33:37 NOTI(5) Signal failure detected on node 00-26-5A-39-6D-F0
70883 2014-10-20 18:33:25 INFO(6) Port 1:20 link up, 1000Mbps FULL duplex
70882 2014-10-20 18:33:25 INFO(6) Port 1:20 link down
70881 2014-10-20 18:33:25 NOTI(5) Signal failure detected on node 78-54-2E-44-4C-E0
70880 2014-10-20 18:33:22 NOTI(5) Signal failure cleared on node 00-26-5A-39-9B-38
70879 2014-10-20 18:33:22 NOTI(5) Signal failure detected on node 00-26-5A-39-9B-38
70878 2014-10-20 18:33:22 NOTI(5) Signal failure cleared on node 00-26-5A-39-6D-FC
70877 2014-10-20 18:33:22 NOTI(5) Signal failure detected on node 00-26-5A-39-6D-FC
70876 2014-10-20 18:33:20 NOTI(5) Signal failure cleared on node 00-26-5A-39-6D-FC
70875 2014-10-20 18:33:20 NOTI(5) Signal failure detected on node 00-26-5A-39-6D-FC
70874 2014-10-20 18:33:14 NOTI(5) Signal failure detected on node 00-26-5A-39-70-18
70873 2014-10-20 18:33:11 INFO(6) Port 1:18 link up, 1000Mbps FULL duplex
70872 2014-10-20 18:33:11 NOTI(5) Signal failure cleared on node 78-54-2E-44-4C-E0
70871 2014-10-20 18:33:11 INFO(6) Port 1:18 link down
70870 2014-10-20 18:33:11 NOTI(5) Signal failure detected on node 78-54-2E-44-4C-E0
70869 2014-10-20 18:33:10 INFO(6) Port 1:23 link up, 1000Mbps FULL duplex
70868 2014-10-20 18:33:10 NOTI(5) Signal failure cleared on node 00-26-5A-39-9B-A4
70867 2014-10-20 18:33:08 INFO(6) Port 2:23 link up, 1000Mbps FULL duplex
70866 2014-10-20 18:33:08 NOTI(5) Signal failure cleared on node 78-54-2E-44-4C-E0
70865 2014-10-20 18:33:08 NOTI(5) Signal failure detected on node 00-26-5A-39-9B-A4
70864 2014-10-20 18:33:08 INFO(6) Port 2:23 link down
70863 2014-10-20 18:33:08 NOTI(5) Signal failure detected on node 78-54-2E-44-4C-E0
70862 2014-10-20 18:32:40 INFO(6) Port 1:23 link down
70861 2014-10-20 18:32:40 INFO(6) Port 1:23 link up, 1000Mbps FULL duplex
70860 2014-10-20 18:32:40 INFO(6) Port 1:23 link down
70859 2014-10-20 18:32:37 INFO(6) Port 1:23 link up, 1000Mbps FULL duplex
70858 2014-10-20 18:32:36 NOTI(5) Signal failure cleared on node 00-26-5A-39-9B-A4
70857 2014-10-20 18:32:36 NOTI(5) Signal failure cleared on node 00-26-5A-39-70-18
70856 2014-10-20 18:32:35 INFO(6) Port 2:23 link up, 1000Mbps FULL duplex
70855 2014-10-20 18:32:35 INFO(6) Port 1:20 link up, 1000Mbps FULL duplex
70854 2014-10-20 18:32:35 NOTI(5) Signal failure cleared on node 78-54-2E-44-4C-E0
70853 2014-10-20 18:32:35 INFO(6) Port 1:18 link up, 1000Mbps FULL duplex
70852 2014-10-20 18:32:35 NOTI(5) Signal failure cleared on node 78-54-2E-44-4C-E0
70851 2014-10-20 18:32:12 NOTI(5) Signal failure detected on node 00-26-5A-39-70-18
70850 2014-10-20 18:32:12 NOTI(5) Signal failure detected on node 00-26-5A-39-9B-A4
70849 2014-10-20 18:32:12 INFO(6) Port 1:23 link down
70848 2014-10-20 18:32:12 INFO(6) Port 1:20 link down
70847 2014-10-20 18:32:12 INFO(6) Port 1:18 link down
70846 2014-10-20 18:32:12 NOTI(5) Signal failure detected on node 78-54-2E-44-4C-E0
70845 2014-10-20 18:32:12 NOTI(5) Signal failure detected on node 78-54-2E-44-4C-E0
70844 2014-10-20 18:32:12 INFO(6) Port 2:23 link down
70843 2014-10-20 18:32:12 NOTI(5) Signal failure detected on node 78-54-2E-44-4C-E0
Я к примеру подключен к порту 1:19 и в это самое время вообще терял доступ к сети.
В чем может быть проблема?
СообщениеДобавлено: Пт окт 31, 2014 12:40
Здравствуйте.
Для оперативности лучше по почте писать о таких проблемах.
Рекомендации я написал по почте, пожалуйста, напишите по результатам.
Бигаров Руслан.
