Текущее время: Пн авг 31, 2026 19:34
 Заголовок сообщения: DES-3200-28A1 cpu_filter igmp query
СообщениеДобавлено: Ср июл 08, 2015 16:29
Подскажите, пожалуйста, как можно защититься от флуда на абонентском порту (шлет кучу igmp query group specific, причем группа из тех, на которую вещается один из каналов в ISM VLAN).
traffic control threshhold 64 не помогает, router_ports_forbidden на клиентские порты прописан
#show multicast port_filtering_mode
Command: show multicast port_filtering_mode
Multicast Filter Mode For Unregistered Group:
    Forwarding List: 25-28
    Filtering  List: 1-24
#show traffic control
Command: show traffic control
Traffic Storm Control Trap :[Both]
Traffic Control Auto Recover Time: 0 Minutes
Port Thres   Broadcast Multicast Unicast  Action   Count    Time
     hold    Storm     Storm     Storm             down     Interval
1    64      Enabled   Enabled   Enabled  drop     5        5
2    64      Enabled   Enabled   Enabled  drop     5        5
3    64      Enabled   Enabled   Enabled  drop     5        5
4    64      Enabled   Enabled   Enabled  drop     5        5
5    64      Enabled   Enabled   Enabled  drop     5        5
6    64      Enabled   Enabled   Enabled  drop     5        5
7    64      Enabled   Enabled   Enabled  drop     5        5
8    64      Enabled   Enabled   Enabled  drop     5        5
9    64      Enabled   Enabled   Enabled  drop     5        5
10   64      Enabled   Enabled   Enabled  drop     5        5
11   64      Enabled   Enabled   Enabled  drop     5        5
12   64      Enabled   Enabled   Enabled  drop     5        5
13   64      Enabled   Enabled   Enabled  drop     5        5
14   64      Enabled   Enabled   Enabled  drop     5        5
15   64      Enabled   Enabled   Enabled  drop     5        5
16   64      Enabled   Enabled   Enabled  drop     5        5
17   64      Enabled   Enabled   Enabled  drop     5        5
18   64      Enabled   Enabled   Enabled  drop     5        5
19   64      Enabled   Enabled   Enabled  drop     5        5
20   64      Enabled   Enabled   Enabled  drop     5        5
21   64      Enabled   Enabled   Enabled  drop     5        5
22   64      Enabled   Enabled   Enabled  drop     5        5
23   64      Enabled   Enabled   Enabled  drop     5        5
24   64      Enabled   Enabled   Enabled  drop     5        5
25   64      Disabled  Disabled  Disabled drop     0        5
26   64      Disabled  Disabled  Disabled drop     0        5
27   64      Disabled  Disabled  Disabled drop     0        5
28   64      Disabled  Disabled  Disabled drop     0        5
#show router_ports
Command: show router_ports
 VLAN Name          : default
 Static Router Port :
 Dynamic Router Port:
 Forbidden Router Port:
 VLAN Name          : 39mkr
 Dynamic Router Port: 27
 Forbidden Router Port: 1-24
 VLAN Name          : IPTV
 Dynamic Router Port: 28
 VLAN Name          : VoIP
 VLAN Name          : Management
 Total Entries: 5
Firmware Version   : Build 1.85.B008
Hardware Version   : A1
Не хватает команды как в C1 серии - cpu_filter.
Более того, этот igmp флуд грузит cpu коммутатора 90+%, а также создает некоторые проблемы абонентам с IPTV, такие как: при переключении каналов старые группы остаются на порту, трафик по новым группам приходит с задержкой в секунд 10, далее через неопределенные промежутки iptv мультикаст поток перестает литься на нужные порты.
Что посоветуете?
 Заголовок сообщения: Re: DES-3200-28A1 cpu_filter igmp query
СообщениеДобавлено: Ср июл 08, 2015 16:56
Вот тут случайно не про это?
СообщениеДобавлено: Ср июл 08, 2015 17:23
xcme, благодарю за ссылку. Помогло именно оно. Продублирую здесь:
enable cpu_interface_filtering
create cpu access_profile profile_id 1 ip igmp type
config cpu access_profile profile_id 1 add access_id 1 ip igmp type 17 port 1-24 deny
