Текущее время: Вс окт 04, 2026 18:23
 Заголовок сообщения: DES-3528 dhcp_snoop address_binding
СообщениеДобавлено: Пн авг 04, 2014 17:12
Здравствуйте.
DES-3528 Build 3.10.B45 A5
Объясните пожалуйста как настроить в режиме dhcp snoop, хочу протестировать метод подключения через "IPoE". Вот так настроил:
Command: show dhcp_relay
DHCP/BOOTP Relay Status         : Enabled
DHCP/BOOTP Hops Count Limit     : 16
DHCP/BOOTP Relay Time Threshold : 0
DHCP Vendor Class Identifier Option 60 State: Disabled
DHCP Client Identifier Option 61 State: Disabled
DHCP Relay Agent Information Option 82 State  : Enabled
DHCP Relay Agent Information Option 82 Check  : Disabled
DHCP Relay Agent Information Option 82 Policy : Replace
DHCP Relay Agent Information Option 82 Remote ID : AC-F1-DF-3D-74-50
Interface    Server 1        Server 2        Server 3        Server 4
Server           VLAN ID List
192.168.254.218   254
DES-3528:admin#show address_binding
Command: show address_binding
Trap/Log          : Enabled
DHCP Snoop(IPv4)  : Enabled
DHCP Snoop(IPv6)  : Disabled
ND Snoop
DES-3528:admin#show address_binding ip_mac all
Command: show address_binding ip_mac all
 M(Mode) - D:DHCP, N:ND S:Static ST(ACL Status) - A:Active I:Inactive
 IP Address                              MAC Address       M  ST Ports
Total Entries : 0
DES-3528:admin#show address_binding dhcp_snoop
Command: show address_binding dhcp_snoop
DHCP_Snoop(IPv4) : Enabled
DHCP_Snoop(IPv6) : Disabled
DES-3528:admin#show address_binding ports
Command: show address_binding ports
 Port   IPv4      IPv6      Mode  Zero IP    DHCP Packet  Stop Learning
        State     State                                   Threshold/Mode
 1      Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 2      Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 3      Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 4      Loose     Disabled  ACL   Allow      Forward      500/Normal
 5      Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 6      Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 7      Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 8      Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 9      Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 10     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 11     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 12     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 13     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 14     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 15     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 16     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 17     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 18     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 19     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 20     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 21     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 22     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 23     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 24     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 25     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 26     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 27     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
 28     Disabled  Disabled  ARP   Not Allow  Forward      500/Normal
DES-3528:admin#show address_binding blocked
Command: show address_binding blocked
Next possible completions:
all                 vlan_name
DES-3528:admin#show address_binding blocked all
Command: show address_binding blocked all
 VID  VLAN Name                        MAC Address       Port
Total Entries : 0
Адрес по DHCP + Option 82 получает, но трафик не пускает. Схема: сервер (локальный интерфейс DHCP) - свич (проброшен VLAN)
В логе:
DES-3528:admin#sh log
Command: show log
Index Date       Time     Level   Log Text
98    2014-08-04 18:09:42 WARN(4) Unauthenticated IP-MAC address and discarded b
                                  y ip mac port binding(IP:<192.168.254.81>, MAC:
                                  <8C-89-A5-02-99-06>, Port<4>)
97    2014-08-04 18:09:40 INFO(6) Port 4 link up, 100Mbps FULL duplex
96    2014-08-04 18:09:37 INFO(6) Port 4 link down
Если прописать жёстко связку MAC+IP то работает.
 Заголовок сообщения: Re: DES-3528 dhcp_snoop address_binding
СообщениеДобавлено: Пн авг 04, 2014 18:13
где логи DHCP сервака по выдаче IP адреса?
приведите конфиг DHCP сервера
свичу достепен адрес 192.168.254.218? Почему и зачем адрес DHCP сервера совпадает с подсетью DHCP клиентов?
СообщениеДобавлено: Пн авг 04, 2014 18:50
Используется проприетарный DHCP сервер от разработчиков билинга. Выдачу адресов от него добился :)
Могу предложить такой лог если он чем то поможет. Раздача адресов работает по Options 82 и relay, но хочу добиться работы adress_binding в режиме dhcp snoop.
2014-08-04 19:33:04.891740 [0x000000c08800] DEBUG    dhcp_op82_parse:362: Op82 Circuit ID 00FE0004:VLAN 254, Unit 0, Port 4 (l=4), Remote ID ACF1DF3D7450 (l=6)
2014-08-04 19:33:04.891751 [0x000000c08800] DEBUG    dhcp_allocate_ip:4177: lookup up client by Op.82: 0x801c816c0
2014-08-04 19:33:04.891760 [0x000000c08800] DEBUG    pool_ip_entry_match_op82:141: branched by Op.82 RemoteID ACF1DF3D7450
2014-08-04 19:33:04.891769 [0x000000c08800] DEBUG    pool_ip_entry_match_op82:170: RemoteID = ACF1DF3D7450, record not FOUND
2014-08-04 19:33:04.891777 [0x000000c08800] DEBUG    dhcp_allocate_ip:4191: Op.82 check passed: device entry=0x800c173b0 id=9
2014-08-04 19:33:04.891786 [0x000000c08800] DEBUG    dhcp_allocate_ip:4203: lookup client by Op.82: 8c:89:a5:02:99:06 vgd=0x800c17880 vg_id=16609 device_id=9: curr_session_limit=1 of 1
2014-08-04 19:33:04.891796 [0x000000c08800] DEBUG    dhcp_allocate_ip:4209: client by Op.82: vgd=0x800c17880 vg_id=16609: try open session 1 of 1
2014-08-04 19:33:04.891806 [0x000000c08800] DEBUG    dhcp_pool_lookup_static_ip:229: lookup static IP by MAC: 8c:89:a5:02:99:06 on device_id=9 vg_id=16609
2014-08-04 19:33:04.891817 [0x000000c08800] DEBUG    dhcp_pool_lookup_static_ip:290: pool_item 0x800c44600: i=81 - ip=192.168.254.81 found by MAC=16609
2014-08-04 19:33:04.891827 [0x000000c08800] DEBUG    dhcp_pool_lookup_static_ip:342: result non-expired 0x800c1e700
2014-08-04 19:33:04.891836 [0x000000c08800] DEBUG    dhcp_pool_lookup_static_ip:344: lookup static IP by MAC: 8c:89:a5:02:99:06: result 0x800c1e700
2014-08-04 19:33:04.891845 [0x000000c08800] DEBUG    dhcp_allocate_ip:4216: lookup up client by MAC 8c:89:a5:02:99:06: static IP found 192.168.254.81
2014-08-04 19:33:04.891854 [0x000000c08800] DEBUG    dhcp_msg_dispatch:149: DHCPREQUEST from 8c:89:a5:02:99:06 -> DHCPACK, XID=0xa00b3231, sec=0
2014-08-04 19:33:04.891865 [0x000000c08800] DEBUG    dhcp_msg_dispatch:169: accept DHCPREQUEST XID A00B3231 : match MAC/IP address 8c:89:a5:02:99:06/192.168.254.81 in our pool, prolongate_lease=1
2014-08-04 19:33:04.891876 [0x000000c08800] DEBUG    dhcp_msg_dispatch:235: handling DHCP agent '192.168.254.1:67'
2014-08-04 19:33:04.891895 [0x000000c08800] DEBUG    dhcp_msg_dispatch:306: OP.55:5 ignore SubOp '46' unknown by our DHCP.
2014-08-04 19:33:04.891905 [0x000000c08800] DEBUG    dhcp_msg_dispatch:306: OP.55:7 ignore SubOp '31' unknown by our DHCP.
2014-08-04 19:33:04.891914 [0x000000c08800] DEBUG    dhcp_msg_dispatch:306: OP.55:9 ignore SubOp '249' unknown by our DHCP.
2014-08-04 19:33:04.891924 [0x000000c08800] DEBUG    dhcp_msg_dispatch:396: client HW 8c:89:a5:02:99:06 assiged IP 192.168.254.81, XID=0xa00b3231
2014-08-04 19:33:04.891942 [0x000000c08800] DEBUG    dhcp_option_print:233: DHCP Op: 82/0x52, type: 5, len: 18, value: HEX: 01 06 00 04 00 FE 00 04 02 08 00 06 AC F1 DF 3D 74 50 ASCII '...............=tP'
2014-08-04 19:33:04.891953 [0x000000c08800] DEBUG    dhcp_msg_dispatch:405: handicrafting Op.82 back...
2014-08-04 19:33:04.891965 [0x000000c08800] DEBUG    dhcp_msg_dispatch:414: using leased address!
2014-08-04 19:33:04.891987 [0x000000c08800] DEBUG    Dump DHCP packet: op=2, htype=1, hlen=6, hops=0x00, xid=0x31320ba0, secs=0, flags=0x0000, ciaddr=0.0.0.0, yiaddr=192.168.254.81, siaddr=192.168.254.81, giaddr=192.168.254.1, chaddr=8c:89:a5:02:99:06, sname=(null), filename=(null), cookie=0x63825363, len=0, sin_addr=192.168.254.255, sin_port=68, client_sockaddr=(0, 0, 0.0.0.0), dhcp_nopt=9, client_hw_addr=, client_dhcp_pkt_len_max=1400, dhcp_req_type=DHCPREQUEST, dhcp_reply_type=DHCPACK
2014-08-04 19:33:04.892002 [0x000000c08800] DEBUG    dhcp_main:201: encoded UDP-reply packet is 319 bytes long
2014-08-04 19:33:04.892012 [0x000000c08800] DEBUG    dhcp_main:234: sending from 192.158.254.218:67 via relay-agent 192.168.254.1:67
2014-08-04 19:33:04.892030 [0x000000c08800] DEBUG    get_udp_sock:107 opened socket 8 for sending from 192.168.254.218:67 to ...
2014-08-04 19:33:04.892049 [0x000000c08800] DEBUG    dhcp_packet_send_udp:140 UDP sent 319 (really 319) bytes  192.168.254.218:67 -> 192.168.254.1:67
2014-08-04 19:33:04.892069 [0x000000c08800] DEBUG    dhcp_main:243: encoded packet (len=319) sent for relay-agent 192.168.254.1:67
2014-08-04 19:33:04.892082 [0x000000c08800] INFO     assigned 192.168.254.81 to 8c:89:a5:02:99:06 via relay 192.168.254.1:67
dhcpdump
TIME: 2014-08-04 19:46:36.595
    IP: 192.168.254.1 (3c:61:04:47:1f:f0) > 192.168.254.218 (44:1e:a1:54:31:e5)
    OP: 1 (BOOTPREQUEST)
 HTYPE: 1 (Ethernet)
  HLEN: 6
  HOPS: 1
   XID: 5a468893
  SECS: 0
 FLAGS: 0
CIADDR: 192.168.254.81
YIADDR: 0.0.0.0
SIADDR: 0.0.0.0
GIADDR: 192.168.254.1
CHADDR: 8c:89:a5:02:99:06:00:00:00:00:00:00:00:00:00:00
 SNAME: .
 FNAME: .
OPTION:  53 (  1) DHCP message type         3 (DHCPREQUEST)
OPTION:  61 (  7) Client-identifier         01:8c:89:a5:02:99:06
OPTION:  12 (  8) Host name                 user
OPTION:  81 ( 12) Client FQDN               0-0-0 user.
OPTION:  60 (  8) Vendor class identifier   MSFT 5.0
OPTION:  55 ( 11) Parameter Request List      1 (Subnet mask)
                                             15 (Domainname)
                                              3 (Routers)
                                              6 (DNS server)
                                             44 (NetBIOS name server)
                                             46 (NetBIOS node type)
                                             47 (NetBIOS scope)
                                             31 (Perform router discovery)
                                             33 (Static route)
                                            249 (MSFT - Classless route)
                                             43 (Vendor specific info)
OPTION:  43 (  3) Vendor specific info      dc0100           ...
OPTION:  82 ( 18) Relay Agent Information
                  Circuit-ID    00:04:00:fe:00:04                  <unknown-0>   02:08:00:06                  <unknown-0>   ac:f1:df:3d:74:50
Да, свичу доступен адрес - всё в одной сети.
Для тестового стэнда мне сейчас не важно какой адрес будет у DHCP сервера и клиентов, в большинстве случаев у провайдера обычно адреса DHCP сервера находятся в том же диапазоне и vlan.
DES-3528:admin#show address_binding dhcp_snoop binding_entry
Command: show address_binding dhcp_snoop binding_entry
 LT(Lease Time)  ST(Status) - A:Active I:Inactive
 IP Address                              MAC Address       LT(sec)    Port  ST
Total Entries :0
СообщениеДобавлено: Вт авг 05, 2014 06:32
Если клиент на 4 порту то зачем там :
Используйте MODE: ARP
СообщениеДобавлено: Вт авг 05, 2014 10:54
Пробовал и ARP mode.
Всё равно в логах:
Unauthenticated IP-MAC address and discarded by ip mac port binding
И здесь пусто:
Total Entries : 0
Как я понимаю здесь должна быть запись с флагом A:Active
СообщениеДобавлено: Вт авг 05, 2014 11:08
Я так понимаю ревизия железа у вас А1? Если да то мы по данному вопросу сейчас тоже ведем переговоры, так как на всех коммутаторах данной ревизии, которые мы используем пришлось выключить address_binding так как, данная функция блокирует всех кто получает ip через dhcp_relay. Если есть коммутаторы другой ревизии попробуйте проверить на них.
СообщениеДобавлено: Вт авг 05, 2014 11:13
Спасибо за ответ, но тогда хочется услышать комментарии от администрации - у нас сейчас как раз начали закупать данные коммутаторы в большом количестве и хотелось бы чтобы этот функционал работал.
СообщениеДобавлено: Вт авг 05, 2014 13:32
Не внимательно прочитал, у нас A5 ревизия. Но заставить функционал работать не получается.
СообщениеДобавлено: Вт авг 05, 2014 13:50
От аппаратной ревизии это не зависит.
Смотрите дампы dhcp пакетов. Наиболее вероятно, что ответы от вашего проприетарного dhcp сервера несколько кривоваты, и коммутатор по ним не может создать корректную cвязку impb.
Попробуйте на стенде с ISC DHCP Server.
СообщениеДобавлено: Вт авг 05, 2014 14:00
Зависит или нет я не знаю, но на С1 все отлично, а на А1 данная связка не работает, просто данный факт, что не работает в нашей сети только на А1 наводит на мысль, что "Наиболее вероятно, что ответы от вашего проприетарного dhcp сервера несколько кривоваты, и коммутатор по ним не может создать корректную cвязку impb" звучит как то менее правдоподобно.
СообщениеДобавлено: Вт авг 05, 2014 15:07
Спасибо за ответы, мы попробуем и на ISC DHCP и на других моделей коммутаторов.
СообщениеДобавлено: Вт авг 05, 2014 15:37
hsvt, данная схема была воспроизведена на стенде с ISC DHCP, проблема не подтвердилась.
10.90.90.91 38-EA-A7-E9-EB-7D D A 8
Total Entries : 1
2 Strict Disabled ARP Allow Forward 500/Normal
3 Strict Disabled ARP Allow Forward 500/Normal
4 Strict Disabled ARP Allow Forward 500/Normal
5 Strict Disabled ARP Allow Forward 500/Normal
6 Strict Disabled ARP Allow Forward 500/Normal
7 Strict Disabled ARP Allow Forward 500/Normal
8 Loose Disabled ACL Allow Forward 500/Normal
СообщениеДобавлено: Вт авг 05, 2014 15:47
Alexander Gavrilin: А что у вас на 8 порту state disable стоит? Может я настраиваю на коммутаторе не правильно? Поправьте если не так.
СообщениеДобавлено: Вт авг 05, 2014 15:56
IPv6 State Disabled. Все настройки сделаны как у вас.
СообщениеДобавлено: Вт авг 05, 2014 17:26
Режим выбран ACL. Таблица задается статически и DHCP выдает статический адрес или я ошибаюсь, просто я говорил про ARP и динамику.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 102
