Текущее время: Ср сен 30, 2026 07:47
СообщениеДобавлено: Ср май 28, 2014 08:17
Знающие, расскажите, как происходит логирование на коммутаторах DLink?
В локальный лог попадают все события, доступные для логирования?
Настройки syslog --- severity и facility, могут дать больше чем в локальном логе?
Что означают параметры facility: local0 - local7?
facility − Some of the operating system daemons and processes have been assigned Facility values. Processes and daemons that have not been explicitly assigned a Facility may use any of the ‘local use’ facilities or they may use the ‘user-level’ Facility. Those Facilities that have been designated are shown in the table below (Bold font indicates the facility values that the Switch currently supports):
Numerical Code Facility
0 kernel messages
1 user-level messages
2 mail system
3 system daemons
4 security/authorization messages
5 messages generated internally by syslog
6 line printer subsystem
7 network news subsystem
8 UUCP subsystem
9 clock daemon
10 security/authorization messages
11 FTP daemon
12 NTP subsystem
13 log audit
14 log alert
15 clock daemon
16 local use 0 (local0)
17 local use 1 (local1)
18 local use 2 (local2)
19 local use 3 (local3)
20 local use 4 (local4)
21 local use 5 (local5)
22 local use 6 (local6)
23 local use 7 (local7)
local0 − Specifies that local use 0 messages are to be sent to the remote host. This corresponds to number 16 from the list above.
local1 − Specifies that local use 1 messages are to be sent to the remote host. This corresponds to number 17 from the list above.
local2 − Specifies that local use 2 messages are to be sent to the remote host. This corresponds to number 18 from the list above.
local3 − Specifies that local use 3 messages are to be sent to the remote host. This corresponds to number 19 from the list above.
local4 − Specifies that local use 4 messages are to be sent to the remote host. This corresponds to number 20 from the list above.
local5 − Specifies that local use 5 messages are to be sent to the remote host. This corresponds to number 21 from the list above.
local6 − Specifies that local use 6 messages are to be sent to the remote host. This corresponds to number 22 from the list above.
local7 − Specifies that local use 7 messages is sent to the remote host. This corresponds to number 23 from the list above.
СообщениеДобавлено: Пт май 30, 2014 05:24
ау?
Сейчас этот форум просматривают: Google [Bot] и гости: 83
