Текущее время: Ср сен 30, 2026 13:28
 Заголовок сообщения: DES-3552 SNMP статистика с портов
СообщениеДобавлено: Вт окт 22, 2013 16:58
Здравствуйте!!!
Столкнулся с следующей проблемой на свитче DES-3552 прошивка 2.60.017 при добавлении свитча в Cacti не возможно получить статистику с портов свитча.
Такие проблемы именно на этой версии прошивки.
Cacti:
+ Running data query [1].
+ Found type = '3' [SNMP Query].
+ Found data query XML file at '/usr/share/cacti/site/resource/snmp_queries/interface.xml'
+ XML file parsed ok.
+ Executing SNMP get for num of indexes @ '.1.3.6.1.2.1.2.1.0' Index Count: 57
+ Executing SNMP walk for list of indexes @ '.1.3.6.1.2.1.2.2.1.1' Index Count: 0
+ No SNMP data returned
Настройки snmp свитча не менял по умолчанию:
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp view restricted all
delete snmp view CommunityView all
config snmp engineID 800000ab03b8a3862c3a90
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group svnet v1 read_view CommunityView notify_view CommunityView
create snmp group svnet v2c read_view CommunityView notify_view CommunityView
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group initial v3 noauth_nopriv read_view restricted notify_view restricted
create snmp group private v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group private v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp community private view CommunityView read_write
create snmp community public view CommunityView read_only
create snmp user initial initial
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 62
