Текущее время: Чт авг 27, 2026 05:26
 Заголовок сообщения: Новая прошивка des 3200 глюк
СообщениеДобавлено: Чт июл 25, 2013 11:23
обновил прошивку на 1,51 008в
теперь не работает ни прошивка через ком не сброс на dlink.com в мануале написано что должно работать а оно не работает что делать?? пароль не помню да и не замарачивался ибо раньше все работало кстате перепрошивал через шифт + 3
текст с мануала
xStack® DES-3200 Series Layer 2 Managed Fast Ethernet Switch
292
Document Appendices
Appendix A Password Recovery Procedure
This document describes the procedure for
resetting passwords on D-Link Switches.
Authenticating any user who tries to access networks
is necessary and important. The basic authentication method
used to accept qualified users is through a local logi
n, utilizing a Username and Password. Sometimes, passwords
get forgotten or destroyed, so network administrators need to reset these passwords. This document will explain
how the Password Recovery feature can hel
p network administrators reach this goal.
The following steps explain how to use the Password Recovery feature on D-Link devices to easily recover
passwords.
Complete these steps to reset the password:
1. For security reasons, the Passwo
rd Recovery feature requires the user
to physically access the device.
Therefore this feature is only applicable when there is a
direct connection to the console port of the device.
It is necessary for the user needs to attach a terminal or
PC with terminal emulation to the console port of
the switch.
2. Power on the Switch. After the ‘Starting runtime im
age’ message, the Switch will allow 2 seconds for the
user to press the hotkey [^] (Shift + 6) to enter the
“Password Recovery Mode.” Once the Switch enters the
“Password Recovery Mode,” all ports on the Swit
ch will be disabled and all port LEDs will be lit.
Boot Procedure V4.00.001
Power On Self Test ........................................ 100 %
MAC Address : 00-01-02-03-04-00
H/W Version : C1
Please Wait, Loading V4.04.004 Runtime Image .............. 100 %
UART init ................................................. 100 %
Starting runtime image
Chapter 15 In the “Password Recovery M
ode” only the following commands can be used.
Command
Parameters
reset config
{force_agree}
The
reset config
command resets the whole configuration back to the default values. The
option '
force_agree
' means to reset the whole configuration without the user’s agreement.
reboot
The
reboot
command exits the Reset Password Recovery Mode and restarts the switch.
A confirmation message will be displayed to a
llow the user to save the current settings.
reset account
The
reset
account command deletes all the previously created accounts.
reset password
{<username>}
The
reset password
command resets the password of the specified user. If a username
is not specified,
the passwords of all users will be reset.
show account
The
show account
command displays all previously created accounts.
 Заголовок сообщения: Re: Новая прошивка des 3200 глюк
СообщениеДобавлено: Чт июл 25, 2013 11:34
Официальный выход из ситуации здесь такой: http://dlink.ru/ru/faq/65/168.html
СообщениеДобавлено: Чт июл 25, 2013 12:58
ну как вы себе это представляете свич стоял на крыше полтора года где от него документы и коробка понятия не имею ... зачем тогда выпускать новые прошивки в которых не работают функции описанные в официальной документации.... http://www.dlink.com/-/media/Business_P ... e_4_04.pdf
СообщениеДобавлено: Чт июл 25, 2013 15:13
Вы ничего не путаете? Какая 1.51? Для С1 актуальна v4.35.B014
