Текущее время: Вс сен 27, 2026 03:41
СообщениеДобавлено: Сб авг 31, 2013 01:29
Boot PROM Version : Build 4.00.002
Firmware Version : Build 4.35.B016
Hardware Version : C1
Копятся ошибки на ап линке :
Port Number : 25
RX Frames
CRC Error 0
Undersize 0
Oversize 0
Fragment 0
Jabber 0
Drop Pkts 7127080
Symbol Error 0
Так же по логам вот такая канитель :
27088 2013-08-31 02:22:40 INFO(6) Port 19 link up, 100Mbps FULL duplex
27087 2013-08-31 02:22:40 INFO(6) Port 19 link down
27086 2013-08-31 02:22:40 INFO(6) Port 18 link up, 100Mbps FULL duplex
27085 2013-08-31 02:22:40 INFO(6) Port 18 link down
27084 2013-08-31 02:22:40 INFO(6) Port 17 link up, 100Mbps FULL duplex
27083 2013-08-31 02:22:40 INFO(6) Port 17 link down
27082 2013-08-31 02:22:40 INFO(6) Port 16 link up, 100Mbps FULL duplex
27081 2013-08-31 02:22:40 INFO(6) Port 16 link down
27080 2013-08-31 02:22:40 INFO(6) Port 15 link up, 100Mbps FULL duplex
27079 2013-08-31 02:22:40 INFO(6) Port 15 link down
27078 2013-08-31 02:22:40 INFO(6) Port 14 link up, 100Mbps FULL duplex
27077 2013-08-31 02:22:40 INFO(6) Port 14 link down
27076 2013-08-31 02:22:40 INFO(6) Port 13 link up, 100Mbps FULL duplex
27075 2013-08-31 02:22:40 INFO(6) Port 13 link down
27074 2013-08-31 02:22:40 INFO(6) Port 12 link up, 100Mbps FULL duplex
27073 2013-08-31 02:22:40 INFO(6) Port 12 link down
27072 2013-08-31 02:22:40 INFO(6) Port 11 link up, 100Mbps FULL duplex
27071 2013-08-31 02:22:40 INFO(6) Port 11 link down
27070 2013-08-31 02:22:40 INFO(6) Port 10 link up, 100Mbps FULL duplex
27069 2013-08-31 02:22:40 INFO(6) Port 10 link down
27068 2013-08-31 02:22:40 INFO(6) Port 9 link up, 100Mbps FULL duplex
27067 2013-08-31 02:22:40 INFO(6) Port 9 link down
27066 2013-08-31 02:22:40 INFO(6) Port 8 link up, 100Mbps FULL duplex
27065 2013-08-31 02:22:40 INFO(6) Port 8 link down
27064 2013-08-31 02:22:40 INFO(6) Port 7 link up, 100Mbps FULL duplex
27063 2013-08-31 02:22:40 INFO(6) Port 7 link down
27062 2013-08-31 02:22:40 INFO(6) Port 6 link up, 100Mbps FULL duplex
27061 2013-08-31 02:22:40 INFO(6) Port 6 link down
27060 2013-08-31 02:22:40 INFO(6) Port 5 link up, 100Mbps FULL duplex
27059 2013-08-31 02:22:40 INFO(6) Port 5 link down
27058 2013-08-31 02:22:40 INFO(6) Port 4 link up, 100Mbps FULL duplex
27057 2013-08-31 02:22:40 INFO(6) Port 4 link down
27056 2013-08-31 02:22:40 INFO(6) Port 3 link up, 100Mbps FULL duplex
27055 2013-08-31 02:22:40 INFO(6) Port 3 link down
27054 2013-08-31 02:22:40 INFO(6) Port 2 link up, 100Mbps FULL duplex
27053 2013-08-31 02:22:40 INFO(6) Port 2 link down
27052 2013-08-31 02:22:40 INFO(6) Port 1 link up, 100Mbps FULL duplex
27051 2013-08-31 02:22:40 INFO(6) Port 1 link down
27050 2013-08-31 02:22:34 INFO(6) Port 19 link up, 100Mbps FULL duplex
27049 2013-08-31 02:22:34 INFO(6) Port 19 link down
27048 2013-08-31 02:22:34 INFO(6) Port 18 link up, 100Mbps FULL duplex
27047 2013-08-31 02:22:34 INFO(6) Port 18 link down
27046 2013-08-31 02:22:34 INFO(6) Port 17 link up, 100Mbps FULL duplex
27045 2013-08-31 02:22:34 INFO(6) Port 17 link down
27044 2013-08-31 02:22:34 INFO(6) Port 16 link up, 100Mbps FULL duplex
27043 2013-08-31 02:22:34 INFO(6) Port 16 link down
27042 2013-08-31 02:22:34 INFO(6) Port 15 link up, 100Mbps FULL duplex
27041 2013-08-31 02:22:34 INFO(6) Port 15 link down
27040 2013-08-31 02:22:34 INFO(6) Port 14 link up, 100Mbps FULL duplex
27039 2013-08-31 02:22:34 INFO(6) Port 14 link down
27038 2013-08-31 02:22:34 INFO(6) Port 13 link up, 100Mbps FULL duplex
27037 2013-08-31 02:22:34 INFO(6) Port 13 link down
27036 2013-08-31 02:22:34 INFO(6) Port 12 link up, 100Mbps FULL duplex
27035 2013-08-31 02:22:34 INFO(6) Port 12 link down
27034 2013-08-31 02:22:34 INFO(6) Port 11 link up, 100Mbps FULL duplex
27033 2013-08-31 02:22:34 INFO(6) Port 11 link down
27032 2013-08-31 02:22:34 INFO(6) Port 10 link up, 100Mbps FULL duplex
27031 2013-08-31 02:22:34 INFO(6) Port 10 link down
27030 2013-08-31 02:22:34 INFO(6) Port 9 link up, 100Mbps FULL duplex
27029 2013-08-31 02:22:34 INFO(6) Port 9 link down
27028 2013-08-31 02:22:34 INFO(6) Port 8 link up, 100Mbps FULL duplex
27027 2013-08-31 02:22:34 INFO(6) Port 8 link down
27026 2013-08-31 02:22:34 INFO(6) Port 7 link up, 100Mbps FULL duplex
27025 2013-08-31 02:22:34 INFO(6) Port 7 link down
27024 2013-08-31 02:22:34 INFO(6) Port 6 link up, 100Mbps FULL duplex
27023 2013-08-31 02:22:34 INFO(6) Port 6 link down
27022 2013-08-31 02:22:34 INFO(6) Port 5 link up, 100Mbps FULL duplex
27021 2013-08-31 02:22:34 INFO(6) Port 5 link down
27020 2013-08-31 02:22:34 INFO(6) Port 4 link up, 100Mbps FULL duplex
27019 2013-08-31 02:22:34 INFO(6) Port 4 link down
27018 2013-08-31 02:22:34 INFO(6) Port 3 link up, 100Mbps FULL duplex
27017 2013-08-31 02:22:34 INFO(6) Port 3 link down
27016 2013-08-31 02:22:34 INFO(6) Port 2 link up, 100Mbps FULL duplex
27015 2013-08-31 02:22:34 INFO(6) Port 2 link down
27014 2013-08-31 02:22:34 INFO(6) Port 1 link up, 100Mbps FULL duplex
И так не прекращаясь, если ставить жесткую 100 линк стабильный но дропы ростут с гониометрической прогрессией :( Жалобы от абонентов поступают о низкой скорости. Помогите советом где касяк(.
СообщениеДобавлено: Пн сен 02, 2013 02:27
Нестабильное/недостаточное питание на коммутатор? За УПСом аналогичное поведение? Если юзать только часть портов - они так же мигают? Вас грозой не било? Аналогично и с другой(абонентской) стороны. Кроме того - рефлектометром затухания меряли? Вдруг пайка криворукая или конкуренты вам связку линков "кирпичом придавили"..
На коротком линке не проверяли? Так же "мигает" или дропы растут?
Замена коммутатора на аналогичный приводит к той же ситуации?
Нюансов много..
AB-Style: Выходных дней два в году - Новый Год и Апокалипсис. Да и то что-то с Апокалипсисом не везёт...
D-Link User: DES-3526/3550, DES-3528, DES-3018, DES-3200-XX, DGS-3612/3627G, DCS-9x0, DCS-3220, DVG-5112S, DPH-400S + разные роутеры и медиаконвертеры
СообщениеДобавлено: Вт сен 03, 2013 15:04
Столкнулся с такой же проблемой. Она наблюдается только с коммутатором C ревизии. Смена прошивки на более старую проблему не решает. На другом аналогичном коммутаторе проблема остается. По факту проблем с линками нет.
СообщениеДобавлено: Чт сен 05, 2013 23:30
Подтверждаю устал от вашей кривой С1 то одно то другое. То мультикаст не льет то порты кладет. Так каждые 5 секунд. В предидущих ревизиях F свитчей все ок проверенно, там модули и конвертеры работают как надо и мультикаст как надо работает . Исправляйте свои глюки сами, не надо про питание писать, мы покупаем за немалые деньги и сами его допиливать должны ? Свитч только поставил из магазина стоит в стойке с заземлением и прочей лабудой типа упса. 3 аналогичных с предидущей ревизией живут отлично.
Кладет порты и все тут прошу помощи срочно.
3200-28F
Firmware Version Build 4.35.B017
Hardware Version C1
12218 2000-01-01 02:21:43 INFO(6) Port 11 link up, 100Mbps FULL duplex
12217 2000-01-01 02:21:43 INFO(6) Port 11 link down
12216 2000-01-01 02:21:42 INFO(6) Port 9 link up, 100Mbps FULL duplex
12215 2000-01-01 02:21:42 INFO(6) Port 9 link down
12214 2000-01-01 02:21:37 INFO(6) Port 11 link up, 100Mbps FULL duplex
12190 2000-01-01 02:21:06 INFO(6) Port 11 link up, 100Mbps FULL duplex
12189 2000-01-01 02:21:06 INFO(6) Port 11 link down
12188 2000-01-01 02:21:06 INFO(6) Port 9 link up, 100Mbps FULL duplex
12187 2000-01-01 02:21:06 INFO(6) Port 9 link down
12186 2000-01-01 02:21:01 INFO(6) Port 11 link up, 100Mbps FULL duplex
11618 2000-01-01 02:08:42 INFO(6) Port 11 link up, 100Mbps FULL duplex
11617 2000-01-01 02:08:42 INFO(6) Port 11 link down
11616 2000-01-01 02:08:42 INFO(6) Port 9 link up, 100Mbps FULL duplex
11615 2000-01-01 02:08:42 INFO(6) Port 9 link down
11614 2000-01-01 02:08:37 INFO(6) Port 11 link up, 100Mbps FULL duplex
СообщениеДобавлено: Пт сен 06, 2013 03:45
А вы пробовали поменять оптические шнуры и поставить более мощные модули? Мы также используем 3200-28f всех ревизий и такие проблемы были на всех ревизиях. У таких портов обычно оптический бюджет на грани - вот они и флапают.
СообщениеДобавлено: Пт сен 06, 2013 08:03
Жилой дом переменной этажности длина до абонов 50-100 метров волокна до 1го 60 до 2го 30 модули 3 км пробывал в пред. ревизии полет нормальный в этой ненормальный. Не уверен что есть смысл использовать 20 ки слишком большой бюджет энергетического сигнала будет.
СообщениеДобавлено: Пт сен 06, 2013 08:32
viewtopic.php?f=2&t=162070
СообщениеДобавлено: Чт сен 26, 2013 13:50
У меня на 28F C1 случилось такое: вдруг стал флапать один порт с большой скоростью, лог мгновенно забит, 100% CPU, лагает даже SNMP, вход телнетом и отключение порта заняли несколько минут (!).
На других портах всё продолжало работать без проблем.
После включения порта на нём всё заработало как ни в чём ни бывало.
4.35.B011, все порты включены на 100_full, sfp гигабитные Opticin (Вимком), со стороны клиентов конвертеры Rubytech.
Сейчас этот форум просматривают: Baidu [Spider], Google [Bot] и гости: 19
