Текущее время: Сб окт 03, 2026 18:24
СообщениеДобавлено: Вт май 21, 2013 12:50
DES-3528:admin# conf vlan v250 add untag 1-20
Success.
тут промазал и вместо 21 написал 20
DES-3528:admin# conf vlan v4000 add untag 20
Success.
чтоза?!?!
DES-3528:admin#sh vlan
Command: show vlan
VLAN Trunk State : Disabled
VLAN Trunk Member Ports :
VID : 1 VLAN Name : default
VLAN Type : Static Advertisement : Enabled
Member Ports : 25-28
Static Ports : 25-28
Current Tagged Ports :
Current Untagged Ports: 25-28
Static Tagged Ports :
Static Untagged Ports : 25-28
Forbidden Ports :
VID : 5 VLAN Name : v5
VLAN Type : Static Advertisement : Disabled
Current Tagged Ports : 25-28
Static Tagged Ports : 25-28
Forbidden Ports :
VID : 250 VLAN Name : v250
Member Ports : 1-20,25-28
Static Ports : 1-20,25-28
Current Untagged Ports: 1-20
Static Untagged Ports : 1-20
Forbidden Ports :
VID : 4000 VLAN Name : v4000
Member Ports : 20-21
Static Ports : 20-21
Current Untagged Ports: 20-21
Static Untagged Ports : 20-21
Forbidden Ports :
VID : 4001 VLAN Name : v4001
Member Ports : 22
Static Ports : 22
Current Untagged Ports: 22
Static Untagged Ports : 22
Forbidden Ports :
Total Static VLAN Entries: 5
Total GVRP VLAN Entries: 0
DES-3528:admin#
DES-3528:admin# show config current
# VLAN
enable pvid auto_assign
config vlan default delete 1-28
config vlan default add untagged 25-28
config vlan default advertisement enable
create vlan v5 tag 5
config vlan v5 add tagged 25-28 advertisement disable
create vlan v250 tag 250
config vlan v250 add tagged 25-28
config vlan v250 add untagged 1-20 advertisement disable
create vlan v4000 tag 4000
config vlan v4000 add untagged 20-21 advertisement disable
create vlan v4001 tag 4001
config vlan v4001 add untagged 22 advertisement disable
disable gvrp
config gvrp nni_bpdu_addr dot1d
disable asymmetric_vlan
disable vlan_trunk
config port_vlan 1-19 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 250
config port_vlan 20-21 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 4000
config port_vlan 22 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 4001
config port_vlan 23-28 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 1
assymetric_vlan выключен же
это нормальное поведение, или глюк?
Последний раз редактировалось Giga-Byte Вт май 21, 2013 20:55, всего редактировалось 1 раз.
 Заголовок сообщения: Re: DES-3528 v3.00.B027 vlan untag port ГЛЮК?
СообщениеДобавлено: Вт май 21, 2013 13:03
В порт можно подать 2 влана антэгом, будет работать тот, который прописан config port_vlan pvid
СообщениеДобавлено: Вт май 21, 2013 13:15
а толку добавлять? работать всё равно будет только один
СообщениеДобавлено: Вт май 21, 2013 14:02
подскажите ещё что значит
СообщениеДобавлено: Вт май 21, 2013 15:33
Добавление порта в несколько vlan необходимо для работы некоторых функций коммутатора, таких как guest vlan, mac based vlan и т.п.
Команда enable pvid auto_assign включает автоматическое назначение pvid порту в зависимости от настроенного vlan.
СообщениеДобавлено: Вт май 21, 2013 20:53
Артём, спасибо!
Есть смысл выключить pvid auto-assign, если мне надо жестко порт в конкретный влан пустить?
СообщениеДобавлено: Ср май 22, 2013 10:35
Да, лучше включить чтобы избежать возможных ошибок при настройке.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 116
