Текущее время: Вт авг 18, 2026 17:30
 Заголовок сообщения: snmp save dgs-3100
СообщениеДобавлено: Чт дек 06, 2012 12:10
Странное поведение dgs-3100 при сохранении по snmp:
snmpset -v2c -cprivate 10.90.90.34 1.3.6.1.4.1.171.10.94.89.89.87.2.1.3.1 i 1 1.3.6.1.4.1.171.10.94.89.89.87.2.1.4.1 a 10.90.90.34 1.3.6.1.4.1.171.10.94.89.89.87.2.1.5.1 i 1 1.3.6.1.4.1.171.10.94.89.89.87.2.1.6.1 s runningConfig 1.3.6.1.4.1.171.10.94.89.89.87.2.1.7.1 i 2 1.3.6.1.4.1.171.10.94.89.89.87.2.1.8.1 i 1 1.3.6.1.4.1.171.10.94.89.89.87.2.1.9.1 a 10.90.90.34 1.3.6.1.4.1.171.10.94.89.89.87.2.1.10.1 i 1 1.3.6.1.4.1.171.10.94.89.89.87.2.1.11.1 s startupConfig 1.3.6.1.4.1.171.10.94.89.89.87.2.1.12.1 i 3 1.3.6.1.4.1.171.10.94.89.89.87.2.1.17.1 i 4
в логах 5 раз сохраняет:
Dec  6 15:00:17 10.90.90.34 %COPY-I-FILECPY: Files Copy - source URL running-config destination URL flash://startup-config
Dec  6 15:00:22 10.90.90.34 %COPY-N-TRAP: The copy operation was completed successfully
Dec  6 15:00:22 10.90.90.34 %COPY-I-FILECPY: Files Copy - source URL running-config destination URL flash://startup-config
Dec  6 15:00:27 10.90.90.34 %COPY-N-TRAP: The copy operation was completed successfully
Dec  6 15:00:27 10.90.90.34 %COPY-I-FILECPY: Files Copy - source URL running-config destination URL flash://startup-config
Dec  6 15:00:31 10.90.90.34 %COPY-N-TRAP: The copy operation was completed successfully
Dec  6 15:00:32 10.90.90.34 %COPY-I-FILECPY: Files Copy - source URL running-config destination URL flash://startup-config
Dec  6 15:00:36 10.90.90.34 %COPY-N-TRAP: The copy operation was completed successfully
Dec  6 15:00:36 10.90.90.34 %COPY-I-FILECPY: Files Copy - source URL running-config destination URL flash://startup-config
если сохраняю через web или telnet, то все в порядке, в логах одна строчка:
Dec  6 15:08:09 192.168.0.34 %COPY-I-FILECPY: Files Copy - source URL running-config destination URL flash://startup-config
Dec  6 15:08:14 192.168.0.34 %COPY-N-TRAP: The copy operation was completed successfully
DGS-3627G
DGS-3120, DGS-3120-24SC
DGS-3100
DGS-1210-28/ME, DGS-1210-10P
History: DAS-3216/48, DWL-7700AP, DGS-1248T, DES-3526, DES-3028...
 Заголовок сообщения: Re: snmp save dgs-3100
СообщениеДобавлено: Чт дек 06, 2012 14:04
Используйте параметр "-r 0" для snmpset.
СообщениеДобавлено: Чт дек 06, 2012 14:19
Причина в том, что коммутатор посылает ответ с задержкой, а snmpset считает, что пакет потерялся и повторяет его.
СообщениеДобавлено: Чт дек 06, 2012 15:45
Да, поэтому можно еще таймаут для snmpset увеличить (параметр "-t")
СообщениеДобавлено: Чт дек 06, 2012 17:36
спасибо!
а отзывчивость не повысить?
а то если коммутаторы в стэке (2юнита), то приходится ждать 12сек, если одиночный, то 6сек.
DGS-3627G
DGS-3100
СообщениеДобавлено: Пт дек 07, 2012 12:03
Нет, на коммутаторе это нельзя настроить.
