Текущее время: Чт окт 01, 2026 07:20
 Заголовок сообщения: DES-3200-26 Rev.C1 4.33B007
СообщениеДобавлено: Ср ноя 21, 2012 22:40
Не работает dhcp_local_relay.
Схема сети:
порты 1-24 - акцесные для пользователей
порт 25 SFP - аплинк на DHCP сервер
Конфиг такой:
# DHCP_LOCAL_RELAY
enable dhcp_local_relay
config dhcp_local_relay option_82 remote_id default
config dhcp_local_relay option_82 circuit_id default
config dhcp_local_relay vlan Access state enable
config dhcp_local_relay option_82 ports 1-24 policy replace
config dhcp_local_relay option_82 ports 25-26 policy keep
enable pvid auto_assign
config vlan default delete 1-26
config vlan default advertisement enable
create vlan Access tag 123
config vlan Access add tagged 25-26
config vlan Access add untagged 1-24 advertisement enable
disable qinq
disable gvrp
config gvrp nni_bpdu_addr dot1d
disable vlan_trunk
config vlan_trunk ports 25-26 state enable
# ADDRBIND
config address_binding dhcp_snoop max_entry ports 1 limit no_limit
config address_binding dhcp_snoop max_entry ports 2 limit no_limit
config address_binding dhcp_snoop max_entry ports 3 limit no_limit
config address_binding dhcp_snoop max_entry ports 4 limit no_limit
config address_binding dhcp_snoop max_entry ports 5 limit no_limit
config address_binding dhcp_snoop max_entry ports 6 limit no_limit
config address_binding dhcp_snoop max_entry ports 7 limit no_limit
config address_binding dhcp_snoop max_entry ports 8 limit no_limit
config address_binding dhcp_snoop max_entry ports 9 limit no_limit
config address_binding dhcp_snoop max_entry ports 10 limit no_limit
config address_binding dhcp_snoop max_entry ports 11 limit no_limit
config address_binding dhcp_snoop max_entry ports 12 limit no_limit
config address_binding dhcp_snoop max_entry ports 13 limit no_limit
config address_binding dhcp_snoop max_entry ports 14 limit no_limit
config address_binding dhcp_snoop max_entry ports 15 limit no_limit
config address_binding dhcp_snoop max_entry ports 16 limit no_limit
config address_binding dhcp_snoop max_entry ports 17 limit no_limit
config address_binding dhcp_snoop max_entry ports 18 limit no_limit
config address_binding dhcp_snoop max_entry ports 19 limit no_limit
config address_binding dhcp_snoop max_entry ports 20 limit no_limit
config address_binding dhcp_snoop max_entry ports 21 limit no_limit
config address_binding dhcp_snoop max_entry ports 22 limit no_limit
config address_binding dhcp_snoop max_entry ports 23 limit no_limit
config address_binding dhcp_snoop max_entry ports 24 limit no_limit
config address_binding dhcp_snoop max_entry ports 25 limit no_limit
config address_binding dhcp_snoop max_entry ports 26 limit no_limit
config address_binding ip_mac ports 1-24 protocol ipv4
config address_binding ip_mac ports 1-24 allow_zeroip enable
enable address_binding dhcp_snoop
enable address_binding trap_log
disable address_binding dhcp_snoop ipv6
disable address_binding nd_snoop
config address_binding dhcp_snoop max_entry ports 1-26 limit no_limit ipv6
config address_binding nd_snoop ports 1-26 max_entry no_limit
С точно такой же настройкой параллельно трудятся несколько десятков DES-3526 на прошивке 6.20B017 и там проблем нет.
Можно ли починить?
 Заголовок сообщения: Re: DES-3200-26 Rev.C1 4.33B007
СообщениеДобавлено: Чт ноя 22, 2012 10:47
dhcp_relay выключен?
config vlan_trunk ports 25-26 state enable - лишняя настройка.
и добавьте
config address_binding ip_mac ports 1-24 forward_dhcppkt enable
СообщениеДобавлено: Чт ноя 22, 2012 11:26
и добавьте
dhcp_relay выключен:
DHCP/BOOTP Relay Status : Disabled
сделал config vlan_trunk ports 25-26 state disable
а вот с config address_binding ip_mac ports 1-24 forward_dhcppkt enable интересная ситуация, похоже свич отрабатывает это как дефолт и не отображает forward_dhcppkt в конфиге. (Обратите внимание на строки где allow_zeroip).
Вот если сделать config address_binding ip_mac ports 1-24 forward_dhcppkt disable, то тогда это в конфиге отображается.
Если следовать этой логике то может надо сделать config address_binding ip_mac ports 25-26 forward_dhcppkt disable ?
И еще, с сервера прилетает на ПК в акцесном порту IP. А в логе свича по sh add ip all пусто. IPMB тоже получается не срабатывает?
И еще, debug в консоль или телнет сессию не работает. Не отображает ничего.
Проблема актуальна.
PS: если сделать enable nd_snooping то в sh add nd b видно мак, а в dhcp snoop нет.
Если отключить как dhcp snoop так и nd snoop. Все равно релей не работает. Что то не так вставляется или обрабатывается по Option 82... Так это по крайней мере выглядит на моей стороне.
СообщениеДобавлено: Пт ноя 23, 2012 01:19
и добавьте
Проблема актуальна.
Все заработало. Проблема была на стороне провайдера DHCP. Сорри за беспокойство. Остались следующие вопросы:
1. Не работает дебаг ни в консоль ни в телнет
2. Где взять обновленный CLI manual
3. Какое значение forward_dhcppkt выставить для акцессных портов и какое для аплинковых.
Заранее спасибо!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 85
