Текущее время: Чт окт 01, 2026 11:30
 Заголовок сообщения: Проблема с lldp на DES-3028
СообщениеДобавлено: Вт авг 17, 2010 16:53
У меня корректно работает lldp на 3026 и на 3010, на 3028 - нет.
Вот пример подключенных друг к другу DES3028 и DES3026:
DES3026(Firmware: 4.30.B21)
Конфиг:
# LLDP
enable lldp
config lldp message_tx_interval 30
config lldp tx_delay 2
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp ports 1 notification enable
config lldp ports 1 admin_status tx_and_rx
config lldp ports 2 notification enable
config lldp ports 2 admin_status tx_and_rx
config lldp ports 3 notification enable
config lldp ports 3 admin_status tx_and_rx
config lldp ports 4 notification enable
config lldp ports 4 admin_status tx_and_rx
config lldp ports 5 notification enable
config lldp ports 5 admin_status tx_and_rx
config lldp ports 6 notification enable
config lldp ports 6 admin_status tx_and_rx
config lldp ports 7 notification enable
config lldp ports 7 admin_status tx_and_rx
config lldp ports 8 notification enable
config lldp ports 8 admin_status tx_and_rx
config lldp ports 9 notification enable
config lldp ports 9 admin_status tx_and_rx
config lldp ports 10 notification enable
config lldp ports 10 admin_status tx_and_rx
config lldp ports 11 notification enable
config lldp ports 11 admin_status tx_and_rx
config lldp ports 12 notification enable
config lldp ports 12 admin_status tx_and_rx
config lldp ports 13 notification enable
config lldp ports 13 admin_status tx_and_rx
config lldp ports 14 notification enable
config lldp ports 14 admin_status tx_and_rx
config lldp ports 15 notification enable
config lldp ports 15 admin_status tx_and_rx
config lldp ports 16 notification enable
config lldp ports 16 admin_status tx_and_rx
config lldp ports 17 notification enable
config lldp ports 17 admin_status tx_and_rx
config lldp ports 18 notification enable
config lldp ports 18 admin_status tx_and_rx
config lldp ports 19 notification enable
config lldp ports 19 admin_status tx_and_rx
config lldp ports 20 notification enable
config lldp ports 20 admin_status tx_and_rx
config lldp ports 21 notification enable
config lldp ports 21 admin_status tx_and_rx
config lldp ports 22 notification enable
config lldp ports 22 admin_status tx_and_rx
config lldp ports 23 notification enable
config lldp ports 23 admin_status tx_and_rx
config lldp ports 24 notification enable
config lldp ports 24 admin_status tx_and_rx
config lldp ports 25 notification enable
config lldp ports 25 admin_status tx_and_rx
config lldp ports 26 notification enable
config lldp ports 26 admin_status tx_and_rx
config lldp ports 1 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 2 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 3 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 4 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 5 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 6 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 7 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 8 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 9 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 10 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 11 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 12 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 13 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 14 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 15 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 16 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 17 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 18 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 19 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 20 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 21 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 22 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 23 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 24 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 25 mgt_addr ipv4 172.xx.xx.xx enable
config lldp ports 26 mgt_addr ipv4 172.xx.xx.xx enable
Вывод show lldp statistics
Last Change Time : 293641850
Number of Table Insert : 2
Number of Table Delete : 0
Number of Table Drop : 0
Number of Table Ageout : 0
Вывод show lldp remote_ports
// Аплинк на 3028
Port ID : 1
Remote Entities Count : 1
Entity 1
Chassis ID Subtype : MAC Address
Chassis ID : 00-21-91-91-CD-38
Port ID Subtype : Local
Port ID : 1/10
Port Description :
System Name :
System Description :
System Capabilities :
Management Address Count : 1
Port PVID : 0
PPVID Entries Count : 0
VLAN Name Entries Count : 0
Protocol ID Entries Count : 0
MAC/PHY Configuration/Status : (None)
Power Via MDI : (None)
Link Aggregation : (None)
Maximum Frame Size : 0
Unknown TLVs Count : 0
******************Многобукв**************************
//Даунлинк на еще один свитч(3026)
Port ID : 19
Entity 1
Chassis ID : 00-1C-F0-11-24-1A
Port ID : 1
Port Description :
System Name :
Port PVID : 0
**********************Многобукв******************************
DES3028(Firmware 2.53.B04 )
Конфиг:
# LLDP
enable lldp
config lldp ports 1-28 notification enable
config lldp ports 1-28 admin_status tx_and_rx
config lldp ports 1-28 mgt_addr ipv4 172.yy.yy.yy enable
Last Change Time : 276
Number of Table Insert : 0
Remote Entities Count : 0
Итого выходит что DES-3028 информацию о себе отдает а DES-3026 ее получает, но не наоборот.Что делать?(с)
 Заголовок сообщения: Re: Проблема с lldp на DES-3028
СообщениеДобавлено: Ср авг 18, 2010 14:46
Пришлите мне, пожалуйста, на почту полные конфигурационные файлы DES-3026 и DES-3028 с указанием портов подключения их между собой.
СообщениеДобавлено: Ср авг 18, 2010 17:21
На DES-3028 Вам нужно сделать:
config vlan default add untagged 10
СообщениеДобавлено: Чт авг 19, 2010 09:21
Да, спасибо - заработало. Выходит что для корректной работы lldp на порту должен быть default vlan. Я вижу что на 3026 и 3010G все работает и без него, это бага или фича DES3028?
СообщениеДобавлено: Чт авг 19, 2010 10:04
Рад слышать, что заработало! Это скорее особенность DES-3028: нужно либо отключить ingress_checking, что менее желательно, либо использовать предложенный мной ранее вариант.
СообщениеДобавлено: Чт окт 25, 2012 10:18
вот у меня та же проблема DES-3028 не видит по lldp DES-3026
DES-3028
Boot PROM Version : Build 1.00-B04
Firmware Version : Build 2.90.B10
config gvrp 25-28 state disable ingress_checking disable acceptable_frame admit_all pvid 1
enable lldp
config lldp ports 1-28 notification disable
config lldp ports 1-24 admin_status rx_only
config lldp ports 25-28 admin_status tx_and_rx
config lldp ports 25-28 basic_tlvs port_description system_name system_description system_capabilities enable
config lldp ports 25-28 mgt_addr ipv4 10.10.0.47 enable
DES-3026
Boot PROM Version : Build 1.01.009
Firmware Version : Build 4.30.B12
enable lldp
config lldp ports 1-26 notification disable
config lldp ports 3-24 admin_status rx_only
config lldp ports 1-2,25-26 admin_status tx_and_rx
config lldp ports 1-2,25-26 mgt_addr ipv4 10.10.0.14 enable
СообщениеДобавлено: Чт окт 25, 2012 10:29
В первую очередь нужно обновить прошивки на обоих коммутаторах до актуальных версий.
СообщениеДобавлено: Чт окт 25, 2012 12:16
так это на и коммутаторах с последними прошивками
СообщениеДобавлено: Чт окт 25, 2012 12:58
На стенде такого не наблюдается. Вывод с DES-3028:
Port ID : 25
Entity 1
Chassis Id Subtype : MAC Address
Chassis Id : 00-1B-11-0F-3D-71
Port Id Subtype : Local
Port ID : 9
Port Description :
System Name :
Management Address Count : 0
Port PVID : 0
Сейчас этот форум просматривают: Google [Bot], LordFeSS и гости: 82
cron
