Текущее время: Вт окт 13, 2026 00:59
Начать новую тему Ответить на тему  [ Сообщений: 51 ]  На страницу 1, 2, 3, 4  След.
СообщениеДобавлено: Ср ноя 23, 2011 15:23
Собственно, к клиента стоит роутер dlink dir-300 и компьютера, на этих настройках работает нормально ряд других свичей, но вот какие-то траблы полезли с этим клиентом.
Свич DES-3200-10
^M
config address_binding ip_mac ports 1 state enable strict allow_zeroip enable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 1 limit 5^M
config address_binding ip_mac ports 2 state enable strict allow_zeroip enable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 2 limit 5^M
config address_binding ip_mac ports 3 state enable strict allow_zeroip enable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 3 limit 5^M
config address_binding ip_mac ports 4 state enable strict allow_zeroip enable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 4 limit 5^M
config address_binding ip_mac ports 5 state enable strict allow_zeroip enable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 5 limit 5^M
config address_binding ip_mac ports 6 state enable strict allow_zeroip enable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 6 limit 5^M
config address_binding ip_mac ports 7 state enable strict allow_zeroip enable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 7 limit 5^M
config address_binding ip_mac ports 8 state enable strict allow_zeroip enable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 8 limit 5^M
config address_binding ip_mac ports 9 state disable allow_zeroip disable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 9 limit 5^M
config address_binding ip_mac ports 10 state disable allow_zeroip disable forward_dhcppkt enable mode arp stop_learning_threshold 500^M
config address_binding dhcp_snoop max_entry ports 10 limit 5^M
enable address_binding dhcp_snoop^M
enable address_binding trap_log
^Mdisable address_binding arp_inspection^M
^M
enable dhcp_relay^M
config dhcp_relay hops 4 time 0 ^M
config dhcp_relay option_82 state enable^M
config dhcp_relay option_82 check disable^M
config dhcp_relay option_82 policy keep^M
config dhcp_relay option_82 remote_id default^M
config dhcp_relay add ipif System 192.168.240.1^M
^M
# DHCP_LOCAL_RELAY^M
^M
disable dhcp_local_relay^M
config dhcp_local_relay vlan vlanid 1024 state enable ^M
^M
# NDP^M
В логих валит с клиента:
Nov 23 10:58:09 192.168.240.24 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 192.168.0.103, MAC: 00-1D-7D-01-7E-D4, Port: 1)
Nov 23 11:01:09 192.168.240.24 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 192.168.0.103, MAC: 00-1D-7D-01-7E-D4, Port: 1)
Nov 23 11:02:09 192.168.240.24 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 192.168.0.103, MAC: 00-1D-7D-01-7E-D4, Port: 1)
Nov 23 14:04:02 192.168.240.24 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 169.254.186.214, MAC: C8-0A-A9-82-76-D4, Port: 1)
Клиент говорит что также включал шнурок в стационарник с Windows 7
Сеть обычная звезда, пока без кольца.
Отдельный управляющий vlan на все сетевое оборудование.
СообщениеДобавлено: Ср ноя 23, 2011 16:07
Это правильные IP адрес и MAC клиента?
Какая прошивка на роутере?
СообщениеДобавлено: Ср ноя 23, 2011 17:58
к сожалению добиться чего-то внятного от клиента пока не удалось.
да, все так как и есть, ничего не изменялось.
а что?
СообщениеДобавлено: Пт ноя 25, 2011 11:07
В общем по истечению недели вижу что работа связки ip port snoop binding проходит криво косо из-за кривости ряда клиентов.
есть мысль уйти просто на acl с привязкой ip+port чтобы избавиться от этого гемороя.
причина ряда проблема в клиентских ПК где сеть поднимается не во время загрузки ПК, а после и как итог, клиентский ПК начинает слать запросы до инициализации сети.
СообщениеДобавлено: Пт дек 02, 2011 09:38
Не факт, что геморрой покинет вас.
В нашей сети IP выдаются абонентам по DHCP на основании MAC-адреса. Порт 25 - аплинк, 1-24 порты абонентские. Имеем такую настройку:
disable address_binding dhcp_snoop
create address_binding ip_mac ipaddr 10.10.10.10 mac_address 00-01-54-0E-3E-45 ports 1
create address_binding ip_mac ipaddr 110.10.10.11 mac_address 00-24-78-84-78-0C ports 2
enable address_binding arp_inspection
config address_binding ip_mac ports 1-24 state enable strict allow_zeroip enable forward_dhcppkt enable
config address_binding ip_mac ports 1-24 mode acl stop_learning_threshold 500
config address_binding dhcp_snoop max_entry ports 1-26 limit 5
config address_binding ip_mac ports 25-26 state disable allow_zeroip enable forward_dhcppkt enable
config address_binding ip_mac ports 25-26 mode arp stop_learning_threshold 500
На свичах DES-3200-26 была прошивка Firmware: Build 1.33.B006. Всё работало нормально. Залили Firmware: Build 1.52.B009. После такого апгрейда некоторые абоненты продолжают работать нормально, но на некоторых вылез косяк - IP адрес абонент получает, соответственно в логах IP-MAC Binding не ругается, но порт трафик не пропускает. Восстанавливаем работоспособность таких абонентов удалением привязки IP-MAC и забиванием ее заново.
После перепрошивки на Firmware: Build 1.52.B009 секция ADDRBIND конфига стала выглядеть вот так:
В конфиге с Firmware: Build 1.52.B009 пропала строчка enable address_binding arp_inspection, т.к. такую команду свитч уже не понимает.
Помогите, плиз, подправить конфиг так, чтобы всё работало без проблем.
СообщениеДобавлено: Пт дек 02, 2011 11:01
Моя проблема в том что:
lease 192.168.21.17 {
  starts 5 2011/12/02 07:28:12;
  ends 5 2011/12/02 13:28:12;
  binding state active;
  next binding state free;
  hardware ethernet 00:30:67:54:1e:d1;
  uid "\001\0000gT\036\321";
  option agent.circuit-id 0:4:3:fd:0:7;
  option agent.remote-id 0:6:f0:7d:68:a3:9:ac;
  starts 5 2011/12/02 07:28:23;
  ends 5 2011/12/02 13:28:23;
И не пойму, какого это проиходит, почему клиент 2 раза, а то и больше присылает запрос на выдачу адреса и делается запись о выдаче лизы, и как вижу и понимаю предыдущая лиза еще работает. От сюда и возникает блокировка порта клиента, ведь лиза выдана, счетчик тикает, и тут клиент через 1сек или 10 минут присылает повторный запрос на выдачу лизы. Как это так? может у кого будут какие мысли? такая ситуация происходит примерно с половиной клиентов, а вторая половина работает абсолютно нормально.
СообщениеДобавлено: Сб фев 11, 2012 12:21
Имеем DES-3200-28 FW 1.60.B008. Включен IMPB + DHCP Snooping.
config address_binding ip_mac ports 1-28 mode acl stop_learning_threshold 500
config address_binding dhcp_snoop max_entry ports 1-24 limit 8
config address_binding dhcp_snoop max_entry ports 25-28 limit no_limit
В целом все хорошо, но, как обычно, не без странностей.
Такое впечатление, что функционал периодически блокирует некоторых абонентов, ничего при этом не сообщая в лог. Валидная связка при этом в памяти есть.
Выключил IMPB на порту такого абонента - он мгновенно запинговался, все ок. После этого заметил одну особенность: на маршрутизаторе в arp-таблице записи все абонентов живут свой срок, затем устаревают, обновляются заново и так по кругу, а у этого age почти всегда равен 0, иногда 1 или 2 минуты. Получается что абонент сам обновляет запись на маршрутизаторе, отсылая arp-пакеты, за которые коммутатор блокирует его, если включен IMPB? Нормальное ли это поведение и кто виноват? Послушать трафик абонента возможности нет - он очень далеко и подключен через транзитного оператора.
p.s. На стенде воспроизводил ситуацию с arp-флудом - действительно, коммутатор блокирует arp-флуд, но сеть при этом доступна. Т.е. воспроизвести целиком не удалось.
СообщениеДобавлено: Сб фев 11, 2012 18:34
Нет, все же все плохо. :twisted: IPMB необъяснимым образом блокирует трафик у некоторых абонентов.
Как написано выше:
...некоторые абоненты продолжают работать нормально, но на некоторых вылез косяк - IP адрес абонент получает, соответственно в логах IP-MAC Binding не ругается, но порт трафик не пропускает.
Выключаешь IMPB на порту - все начинает работать.
Чувствую, что придется отказываться от этого функционала. Нормально он работает только на стенде :|
СообщениеДобавлено: Сб фев 11, 2012 22:03
давно пора, acl на порт решает все.
СообщениеДобавлено: Вс фев 12, 2012 15:59
InventoR писал(а):
И не пойму, какого это проиходит, почему клиент 2 раза, а то и больше присылает запрос на выдачу адреса и делается запись о выдаче лизы, и как вижу и понимаю предыдущая лиза еще работает.Отсюда и возникает блокировка порта клиента, ведь лиза выдана, счетчик тикает, и тут клиент через 1сек или 10 минут присылает повторный запрос на выдачу лизы. Как это так? может у кого будут какие мысли? такая ситуация происходит примерно с половиной клиентов, а вторая половина работает абсолютно нормально.
Можно поподробнее прокомментировать выделенный кусок? В момент отправки запроса связка IP+MAC+Port временно удаляется с коммутатора и отсюда имеем кратковременный дроп пакетов от пользователя?
Мы выделяем на порт пул адресов, потому не хватит никаких ацл для блокировки левых arp и прочего. К тому же конфиг получится не унифицированным.
СообщениеДобавлено: Пн фев 13, 2012 15:29
up
СообщениеДобавлено: Вт фев 14, 2012 11:10
Ув. техподдержка, будут какие-нибудь комментарии, рекомендации, исправления прошивок может?
Функционал нужный, а использовать нельзя.
СообщениеДобавлено: Вт фев 14, 2012 11:22
xcme
У клиентов роутеры или компьютеры?
СообщениеДобавлено: Вт фев 14, 2012 11:59
Из тех что разбирали - у всех компьютеры с Windows 7 (у некоторых 6.1.7601 Сервис пак 1 сборка 7601, других не опрашивали). Уж не знаю ОС ли причастна или она просто сейчас самая популярная...
Симптомы тоже непонятны: блокируется трафик с порта то на 2-5 секунд, то на 20-30 секунд, то на иные промежутки времени. Валидная связка при этом есть. Мак в таблице коммутации и в arp-таблице маршрутизатора есть. Выключаешь IMPB - все начинает работать.
Последний раз редактировалось xcme Вт фев 14, 2012 12:23, всего редактировалось 1 раз.
СообщениеДобавлено: Вт фев 14, 2012 12:09
Проблемные клиенты не замечены во flood_fdb?
