Текущее время: Пн авг 24, 2026 21:49
 Заголовок сообщения: des-3526 cable diagnostic
СообщениеДобавлено: Ср май 23, 2012 08:52
Добрый день! Столкнулся с проблемой, - при выполнении команды cable_diag ports all получаю вывод:
Port Type Link Status Test Result Cable Length (M)
1 FE Link Up The PHY can't support Cable Diagnostic
2 FE Link Down The PHY can't support Cable Diagnostic
3 FE Link Up The PHY can't support Cable Diagnostic
4 FE Link Down The PHY can't support Cable Diagnostic
5 FE Link Up The PHY can't support Cable Diagnostic
6 FE Link Down The PHY can't support Cable Diagnostic
7 FE Link Down The PHY can't support Cable Diagnostic
8 FE Link Up The PHY can't support Cable Diagnostic
9 FE Link Up The PHY can't support Cable Diagnostic
10 FE Link Down The PHY can't support Cable Diagnostic
11 FE Link Down The PHY can't support Cable Diagnostic
12 FE Link Down The PHY can't support Cable Diagnostic
13 FE Link Down The PHY can't support Cable Diagnostic
14 FE Link Down The PHY can't support Cable Diagnostic
15 FE Link Down The PHY can't support Cable Diagnostic
16 FE Link Down The PHY can't support Cable Diagnostic
17 FE Link Down The PHY can't support Cable Diagnostic
18 FE Link Down The PHY can't support Cable Diagnostic
19 FE Link Down The PHY can't support Cable Diagnostic
20 FE Link Down The PHY can't support Cable Diagnostic
21 FE Link Down The PHY can't support Cable Diagnostic
22 FE Link Down The PHY can't support Cable Diagnostic
23 FE Link Down The PHY can't support Cable Diagnostic
24 FE Link Down The PHY can't support Cable Diagnostic
25 GE Link Up The PHY can't support Cable Diagnostic
26 GE Link Down The PHY can't support Cable Diagnostic
С чем это связано? данные коммутатора приведены ниже.
Device Type : DES-3526 Fast-Ethernet Switch
Combo Port Type : 1000Base-T + 1000Base-T
MAC Address : 00-0F-3D-CB-1F-8D
IP Address : 10.90.90.90 (Manual)
VLAN Name : default
Subnet Mask : 255.255.255.0
Default Gateway :
Boot PROM Version : Build 5.00.009
Firmware Version : Build 5.01.B60
Hardware Version : 1A1
Serial Number :
Power Status : Main - Normal, Redundant - Not Present
System Name :
System Location :
System Contact :
Spanning Tree : Disabled
GVRP : Disabled
IGMP Snooping : Disabled
TELNET : Enabled (TCP 23)
SSH : Disabled
WEB : Enabled (TCP 80)
RMON : Enabled
Asymmetric VLAN : Disabled
Password Encryption Status : Enabled
Последний раз редактировалось iDimasik Ср май 23, 2012 13:49, всего редактировалось 1 раз.
 Заголовок сообщения: Re: des-3526 cable diagnostic
СообщениеДобавлено: Ср май 23, 2012 09:14
А cable_diag ports 1-24 работает корректно?
DES-1228/ME, DES-3028, DES-3200-XX, DES-3526, DES-3528, DGS-3100-24TG, DGS-3120-24SC, DGS-3627G, DGS-3620-28SC
СообщениеДобавлено: Ср май 23, 2012 09:29
не работает, как угодно oтдельно по портам или 1-24 вывод одинаков: Link Up The PHY can't support Cable Diagnostic
СообщениеДобавлено: Ср май 23, 2012 09:42
Попробуйте сначала обновить прошивку.
СообщениеДобавлено: Ср май 23, 2012 10:27
У нас в сети несколько тысяч 3526 все работают на 5.01.B6, и на всех работает диагностика, так как данная прошивка поддерживает диагностику, новее прошивку нет желания использовать. Перепрошил свич этой же прошивкой эффект тот же - не работает диагностика.
СообщениеДобавлено: Ср май 23, 2012 13:29
Может свитч просто физически диагностику не поддерживает, всё-таки хардварная версия 1A1?
СообщениеДобавлено: Ср май 23, 2012 13:45
Гадание не подходит, нужен обоснованный ответ. Либо в сервисный центр.
СообщениеДобавлено: Ср май 23, 2012 14:56
На аппаратной версии A1 коммутатора DES-3526 Cable Diag не поддерживался.
СообщениеДобавлено: Чт май 24, 2012 15:49
Проверил на остальных коммутаторах той же аппаратной ревизии 1A1 и с той же прошивкой - Cable Diag работает, в сервисный центр?
СообщениеДобавлено: Чт май 24, 2012 16:13
На аппаратной версии A1 официальной поддержки данного функционала не было. Вы можете уточнить этот вопрос в сервисном центре и при наличии технической возможности это могут сделать, но на платной основе.
СообщениеДобавлено: Чт май 24, 2012 16:45
Подскажите где можно посмотреть в каких ревизиях какие функции заявлены официально?
СообщениеДобавлено: Чт май 24, 2012 16:50
Отдельного документа нет, просто это очень старая аппаратная версия, на которой Cable Diag еще не поддерживался.
