Текущее время: Сб апр 04, 2026 23:12
СообщениеДобавлено: Пт сен 30, 2011 13:21
Добрый день проясните некоторые нюансы. Наш вышестояший провайдер подает мультикаст.
Есть Тестовая Схема №1 она рабочая, но остались лично у меня вопросы и после поиска не нашел ответа.
Схема №1
Конфиг DGS-3610
DGS-3610(2)#sh ru
Building configuration...
Current configuration : 2130 bytes
version v10.4(3) Release(117920)(Wed Jun 22 09:55:14 CST 2011 -ngcf62)
hostname DGS-3610(2)
no co-operate enable
aaa new-model
aaa authentication login root local
nfpp
vlan 1
vlan 100
vlan 200
vlan 450
name For_ISM
username root password 12345
username root privilege 15
no service password-encryption
ip ssh version 2
ip multicast-routing
archive
log config
logging enable
hidekeys
enable service ssh-server
gvrp enable
gvrp dynamic-vlan-creation enable
interface GigabitEthernet 0/1
interface GigabitEthernet 0/2
interface GigabitEthernet 0/3
interface GigabitEthernet 0/4
interface GigabitEthernet 0/5
interface GigabitEthernet 0/6
interface GigabitEthernet 0/7
interface GigabitEthernet 0/8
interface GigabitEthernet 0/9
interface GigabitEthernet 0/10
interface GigabitEthernet 0/11
interface GigabitEthernet 0/12
interface GigabitEthernet 0/13
switchport access vlan 200
interface GigabitEthernet 0/14
switchport access vlan 100
description Test_link_for_OSPF
interface GigabitEthernet 0/15
switchport mode trunk
interface GigabitEthernet 0/16
interface GigabitEthernet 0/17
interface GigabitEthernet 0/18
interface GigabitEthernet 0/19
switchport access vlan 450
interface GigabitEthernet 0/20
switchport trunk allowed vlan remove 2-449,451-4094
description PC_or_Switch
interface GigabitEthernet 0/21
interface GigabitEthernet 0/22
interface GigabitEthernet 0/23
interface GigabitEthernet 0/24
interface VLAN 1
no ip proxy-arp
ip address 172.28.15.242 255.255.255.0
interface VLAN 450
ip pim sparse-mode
no ip proxy-arp
router ospf 2222
router-id 172.28.15.242
log-adj-changes detail
network 172.28.15.0 0.0.0.255 area 0
line con 0
line vty 0 4
transport input ssh
privilege level 15
end
Тестовый DES-3200
# DES-3200-28 Configuration
# Firmware: Build 1.52.B006
# Copyright(C) 2010 D-Link Corporation. All rights reserved.
# BASIC
config serial_port baud_rate 9600 auto_logout 10_minutes
# ACCOUNT LIST
create account admin admin
123
123
# ACCOUNT END
# PASSWORD ENCRYPTION
disable password encryption
config terminal_line default
enable clipaging
disable command logging
enable password_recovery
# STORM
config traffic control_trap none
config traffic control 1-24 broadcast enable multicast enable unicast enable action drop threshold 64 countdown 0 time_interval 5
config traffic control 25-28 broadcast disable multicast disable unicast disable action drop threshold 64 countdown 0 time_interval 5
# LOOP_DETECT
enable loopdetect
config loopdetect recover_timer 0
config loopdetect interval 3
config loopdetect mode port-based
config loopdetect trap both
config loopdetect ports 1-24 state enabled
config loopdetect ports 25-28 state disabled
# QOS
config scheduling_mechanism strict
config scheduling 0 strict
config scheduling 0 weight 1
config scheduling 1 weight 2
config scheduling 2 weight 4
config scheduling 3 weight 8
config 802.1p user_priority 0 1
config 802.1p user_priority 1 0
config 802.1p user_priority 2 0
config 802.1p user_priority 3 1
config 802.1p user_priority 4 2
config 802.1p user_priority 5 2
config 802.1p user_priority 6 3
config 802.1p user_priority 7 3
config cos tos value 0 class 0
config cos tos value 1 class 0
config cos tos value 2 class 0
config cos tos value 3 class 0
config cos tos value 4 class 0
config cos tos value 5 class 0
config cos tos value 6 class 0
config cos tos value 7 class 0
config dscp_mapping dscp_value 0 class 0
config dscp_mapping dscp_value 1 class 0
config dscp_mapping dscp_value 2 class 0
config dscp_mapping dscp_value 3 class 0
config dscp_mapping dscp_value 4 class 0
config dscp_mapping dscp_value 5 class 0
config dscp_mapping dscp_value 6 class 0
config dscp_mapping dscp_value 7 class 0
config dscp_mapping dscp_value 8 class 0
config dscp_mapping dscp_value 9 class 0
config dscp_mapping dscp_value 10 class 0
config dscp_mapping dscp_value 11 class 0
config dscp_mapping dscp_value 12 class 0
config dscp_mapping dscp_value 13 class 0
config dscp_mapping dscp_value 14 class 0
config dscp_mapping dscp_value 15 class 0
config dscp_mapping dscp_value 16 class 0
config dscp_mapping dscp_value 17 class 0
config dscp_mapping dscp_value 18 class 0
config dscp_mapping dscp_value 19 class 0
config dscp_mapping dscp_value 20 class 0
config dscp_mapping dscp_value 21 class 0
config dscp_mapping dscp_value 22 class 0
config dscp_mapping dscp_value 23 class 0
config dscp_mapping dscp_value 24 class 0
config dscp_mapping dscp_value 25 class 0
config dscp_mapping dscp_value 26 class 0
config dscp_mapping dscp_value 27 class 0
config dscp_mapping dscp_value 28 class 0
config dscp_mapping dscp_value 29 class 0
config dscp_mapping dscp_value 30 class 0
config dscp_mapping dscp_value 31 class 0
config dscp_mapping dscp_value 32 class 0
config dscp_mapping dscp_value 33 class 0
config dscp_mapping dscp_value 34 class 0
config dscp_mapping dscp_value 35 class 0
config dscp_mapping dscp_value 36 class 0
config dscp_mapping dscp_value 37 class 0
config dscp_mapping dscp_value 38 class 0
config dscp_mapping dscp_value 39 class 0
config dscp_mapping dscp_value 40 class 0
config dscp_mapping dscp_value 41 class 0
config dscp_mapping dscp_value 42 class 0
config dscp_mapping dscp_value 43 class 0
config dscp_mapping dscp_value 44 class 0
config dscp_mapping dscp_value 45 class 0
config dscp_mapping dscp_value 46 class 0
config dscp_mapping dscp_value 47 class 0
config dscp_mapping dscp_value 48 class 0
config dscp_mapping dscp_value 49 class 0
config dscp_mapping dscp_value 50 class 0
config dscp_mapping dscp_value 51 class 0
config dscp_mapping dscp_value 52 class 0
config dscp_mapping dscp_value 53 class 0
config dscp_mapping dscp_value 54 class 0
config dscp_mapping dscp_value 55 class 0
config dscp_mapping dscp_value 56 class 0
config dscp_mapping dscp_value 57 class 0
config dscp_mapping dscp_value 58 class 0
config dscp_mapping dscp_value 59 class 0
config dscp_mapping dscp_value 60 class 0
config dscp_mapping dscp_value 61 class 0
config dscp_mapping dscp_value 62 class 0
config dscp_mapping dscp_value 63 class 0
config 802.1p default_priority 1-28 0
config cos mapping port 1-28 ethernet 802.1p
# MIRROR
disable mirror
config mirror port 1 delete source ports 1 both
# BANDWIDTH
config bandwidth_control 1-28 rx_rate no_limit tx_rate no_limit
config per_queue bandwidth_control ports 1-28 0 max_rate no_limit
config per_queue bandwidth_control ports 1-28 1 max_rate no_limit
config per_queue bandwidth_control ports 1-28 2 max_rate no_limit
config per_queue bandwidth_control ports 1-28 3 max_rate no_limit
# SYSLOG
enable syslog
create syslog host 1 ipaddress 172.28.100.7 severity all facility local0 udp_port 514 state enable
config log_save_timing time_interval 1
# TRAF-SEGMENTATION
config traffic_segmentation 1-28 forward_list 1-28
# PACKET_FROM_CPU
config mgmt_pkt_priority default
# SSL
disable ssl
enable ssl ciphersuite RSA_with_RC4_128_MD5
enable ssl ciphersuite RSA_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite DHE_DSS_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite RSA_EXPORT_with_RC4_40_MD5
config ssl cachetimeout 600
# PORT
enable jumbo_frame
config ports 1-24 speed 100_full flow_control disable state enable clear_description
config ports 1-28 learning enable
config ports 1-28 mdix auto
config ports 25-28 medium_type fiber speed auto flow_control disable state enable clear_description
config ports 25-28 medium_type fiber learning enable
config ports 25-28 speed auto flow_control disable state enable clear_description
# OAM
# DDM
config ddm trap disable
config ddm log enable
config ddm ports 25-28 state enable shutdown alarm
# TIME_RANGE
# GM
config sim candidate
disable sim
config sim dp_interval 30
config sim hold_time 100
# MANAGEMENT
create trusted_host network 172.20.254.0/24
enable snmp traps
enable snmp authenticate_traps
enable snmp linkchange_traps
config snmp linkchange_traps ports all enable
config snmp system_location OOO "MKC"
config snmp system_contact (901)5133302, 42464
disable rmon
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp view restricted all
delete snmp view CommunityView all
delete snmp group public
delete snmp group private
delete snmp group ReadGroup
delete snmp group WriteGroup
config snmp engineID 800000ab035cd9980e4610
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group initial v3 noauth_nopriv read_view restricted notify_view restricted
create snmp group rere v1 read_view CommunityView notify_view CommunityView
create snmp group rere v2c read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v1 read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v2c read_view CommunityView notify_view CommunityView
create snmp group WriteGroup v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group WriteGroup v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp community rere view CommunityView read_only
create snmp user initial initial
# VLAN
disable asymmetric_vlan
enable pvid auto_assign
config vlan default delete 1-28
config vlan default advertisement enable
config vlan default add untagged 1-28
disable qinq
disable gvrp
config qinq ports 1-28 role nni outer_tpid 0x88A8 trust_cvid disable vlan_translation disable
config gvrp 1-28 state disable ingress_checking enable acceptable_frame admit_all pvid 1
# PROTOCOL_VLAN
# 8021X
disable 802.1x
config 802.1x auth_protocol radius_eap
config radius parameter timeout 5 retransmit 2
config 802.1x capability ports 1-28 none
config 802.1x auth_parameter ports 1-28 direction both port_control auto quiet_period 60 tx_period 30 supp_timeout 30 server_timeout 30 max_req 2 reauth_period 3600 enable_reauth disable
# PORT_LOCK
disable port_security trap_log
config port_security ports 1-24 admin_state enable max_learning_addr 5 lock_address_mode DeleteOnTimeout
config port_security ports 25-28 admin_state disable max_learning_addr 1 lock_address_mode DeleteOnTimeout
# PPPOE
config pppoe circuit_id_insertion state disable
config pppoe circuit_id_insertion ports 1-28 state enable circuit_id ip
# MAC_ADDRESS_TABLE_NOTIFICATION
config mac_notification interval 1 historysize 1
disable mac_notification
config mac_notification ports 1-28 disable
# LACP
config lacp_ports 1-28 mode passive
config link_aggregation algorithm mac_source
# STP
config stp version rstp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu enable hellotime 2
config stp priority 32768 instance_id 0
config stp mst_config_id name 5C:D9:98:0E:46:10 revision_level 0
config stp ports 1-28 externalCost auto edge auto p2p auto state enable
config stp mst_ports 1-28 instance_id 0 internalCost auto priority 128
config stp ports 1-28 fbpdu enable
config stp ports 1-28 restricted_role false
config stp ports 1-28 restricted_tcn false
disable stp
# ERPS
config erps log disable
config erps trap disable
disable erps
# MULTI FILTER
config max_mcast_group ports 1-28 max_group 1024
# BPDU_TUNNEL
config bpdu_tunnel ports all type none
disable bpdu_tunnel
# BPDU_PROTECTION
config bpdu_protection ports 1-28 mode shutdown
# SAFEGUARD_ENGINE
config safeguard_engine state enable utilization rising 100 falling 80 trap_log enable mode fuzzy
# BANNER_PROMP
config command_prompt default
config greeting_message default
# SSH
config ssh algorithm 3DES enable
config ssh algorithm AES128 enable
config ssh algorithm AES192 enable
config ssh algorithm AES256 enable
config ssh algorithm arcfour enable
config ssh algorithm blowfish enable
config ssh algorithm cast128 enable
config ssh algorithm twofish128 enable
config ssh algorithm twofish192 enable
config ssh algorithm twofish256 enable
config ssh algorithm MD5 enable
config ssh algorithm SHA1 enable
config ssh algorithm RSA enable
config ssh algorithm DSA enable
config ssh authmode password enable
config ssh authmode publickey enable
config ssh authmode hostbased enable
config ssh server maxsession 8
config ssh server contimeout 120
config ssh server authfail 2
config ssh server rekey never
config ssh user admin authmode password
disable ssh
# SNOOP
enable igmp_snooping
config igmp_snooping data_driven_learning max_learned_entry 56
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan IPTV 450
config igmp_snooping multicast_vlan IPTV state enable
config igmp_snooping multicast_vlan IPTV add member_port 1-10
config igmp_snooping multicast_vlan IPTV add source_port 25
config igmp_snooping vlan_name default state disable fast_leave enable
config igmp_snooping data_driven_learning vlan_name default aged_out disable
config igmp_snooping querier all query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 3 state disable version 2
config igmp_snooping vlan_name IPTV fast_leave enable
config igmp_snooping data_driven_learning vlan_name IPTV aged_out disable
config igmp_snooping querier vlan_name IPTV query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp access_authentication ports 1-28 state disable
# FDB
config fdb aging_time 300
config multicast port_filtering_mode 1-28 filter_unregistered_groups
disable flood_fdb
config flood_fdb log disable trap disable
# VLAN_TRUNK
disable vlan_trunk
# SMTP
disable smtp
# ACL
disable cpu_interface_filtering
# SNTP
enable sntp
config time_zone operator + hour 4 min 0
config sntp primary 172.28.200.1 secondary 172.28.200.2 poll-interval 720
config dst disable
# DOS_PREVENTION
disable dos_prevention trap_log
config dos_prevention dos_type land_attack action drop state enable
config dos_prevention dos_type blat_attack action drop state enable
config dos_prevention dos_type smurf_attack action drop state enable
config dos_prevention dos_type tcp_null_scan action drop state enable
config dos_prevention dos_type tcp_xmascan action drop state enable
config dos_prevention dos_type tcp_synfin action drop state enable
config dos_prevention dos_type tcp_syn_srcport_less_1024 action drop state enable
# DHCP_SERVER_SCREENING
config filter dhcp_server ports 1-24 state enable
config filter dhcp_server ports 25-28 state disable
config filter dhcp_server illegal_server_log_suppress_duration 5min
config filter dhcp_server trap enable
config filter dhcp_server log enable
# ADDRBIND
config address_binding ip_mac ports 1-28 state disable allow_zeroip disable forward_dhcppkt enable
config address_binding ip_mac ports 1-28 mode arp stop_learning_threshold 500
config address_binding dhcp_snoop max_entry ports 1-28 limit 5
disable address_binding dhcp_snoop
disable address_binding trap_log
# ARPSPOOF
# CFM
# IP
config ipif System vlan default ipaddress 172.28.15.124/24 state enable
config ipif System dhcp_option12 state disable
enable telnet 23
enable web 80
disable autoconfig
config autoconfig timeout 50
# MBA
disable mac_based_access_control
disable authorization attributes
config mac_based_access_control authorization attributes radius enable
config mac_based_access_control authorization attributes local enable
config mac_based_access_control trap state enable
config mac_based_access_control log state enable
config mac_based_access_control ports 1-28 state disable
config mac_based_access_control ports 1-28 mode host_based
config mac_based_access_control method local
config mac_based_access_control auth_failover disable
config mac_based_access_control password default
config mac_based_access_control max_users 128
# LLDP
disable lldp
config lldp message_tx_interval 30
config lldp tx_delay 2
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp ports 1-28 notification disable
config lldp ports 1-28 admin_status tx_and_rx
# MLDSNP
# ARP
config arp_aging time 20
config gratuitous_arp send ipif_status_up enable
config gratuitous_arp send dup_ip_detected enable
config gratuitous_arp learning enable
enable gratuitous_arp ipif System trap
enable gratuitous_arp ipif System log
config gratuitous_arp send periodically ipif System interval 10
# AAA
config authen_login default method local
config authen_enable default method local_enable
config authen application console login default
config authen application console enable default
config authen application telnet login default
config authen application telnet enable default
config authen application ssh login default
config authen application ssh enable default
config authen application http login default
config authen application http enable default
config authen parameter response_timeout 30
config authen parameter attempt 3
disable authen_policy
config admin local_enable
# DHCP_RELAY
disable dhcp_relay
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state disable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
config dhcp_relay option_82 circuit_id default
config dhcp_relay option_82 remote_id default
# DHCP_LOCAL_RELAY
disable dhcp_local_relay
config dhcp_local_relay option_82 circuit_id default
config dhcp_local_relay option_82 remote_id default
config dhcp_local_relay option_82 ports 1-28 policy keep
# NDP
# ROUTE
create iproute default 172.28.15.1 1
# End of configuration file for DES-3200-28
Каналы показывает прекрасно но не ясно
1) Что ставить в качестве DGS-3610(2)(config)#ip pim rp-address ??? Потом будет нижестоящий 3627G и там этот адрес надо будет прописать для функционирования PIM-SM.
2) Если нет ip адреса на интерфейсе влана 450 то вывод команд ничего не показывает но каналы работают. Как я понял это нормальное явление чтобы что то вывести нужен ip адрес на интерфейсе. Так?
Команды
    DGS-3610(2)#sh ip pim sparse-mode mroute
    DGS-3610(2)#sh ip pim sparse-mode neighbor
    DGS-3610(2)#sh ip pim sparse-mode interface
В это время DES-3200
    DES-3200-28:5#show igmp_snooping group vlan IPTV
    Command: show igmp_snooping group vlan IPTV
    Source/Group : NULL/224.0.0.2
    VLAN Name/VID : IPTV/450
    Reports : 0
    Member Ports :
    Router Ports : 25
    Up time : 3383
    Expire Time : 0
    Filter Mode : EXCLUDE
    Source/Group : NULL/239.1.1.1
    Reports : 7
    Member Ports : 25
    Router Ports : 25
    Up time : 116
    Expire Time : 251
    Source/Group : NULL/239.1.1.2
    Reports : 4
    Member Ports : 25
    Router Ports : 25
    Up time : 119
    Expire Time : 245
    Source/Group : NULL/239.1.1.6
    Reports : 7
    Member Ports : 25
    Router Ports : 25
    Up time : 83
    Expire Time : 243
    Source/Group : NULL/239.1.1.8
    Reports : 8
    Member Ports : 25
    Router Ports : 25
    Up time : 123
    Expire Time : 237
    Source/Group : NULL/239.1.1.9
    Reports : 4
    Member Ports : 25
    Router Ports : 25
    Up time : 123
    Expire Time : 240
    Source/Group : NULL/239.1.1.10
    Reports : 5
    Member Ports : 25
    Router Ports : 25
    Up time : 126
    Expire Time : 244
    и т.д.
    IGMP Snooping Global State : Enabled
    Multicast Router Only : Disabled
    Data Driven Learning Max Entries : 56
    VLAN Name : default
    Query Interval : 125
    Max Response Time : 10
    Robustness Value : 2
    Last Member Query Interval : 3
    Querier State : Disabled
    Querier Role : Non-Querier
    Querier IP : 0.0.0.0
    Querier Expiry Time : 0 secs
    State : Disabled
    Fast Leave : Enabled
    Version : 2
    Data Driven Learning Aged Out : Disabled
    VLAN Name : IPTV
    Last Member Query Interval : 1
    Querier IP : 100.1.12.1
    Querier Expiry Time : 1 secs
    State : Enabled
    Version : 2
3) Ставлю ип
DGS-3610(2)(config)#int vlan 450
DGS-3610(2)(config-if-VLAN 450)#ip add
DGS-3610(2)(config-if-VLAN 450)#ip address 172.29.29.1 255.255.255.0
И Вижу
    DGS-3610(2)#sh ip pim sparse-mode local-members
    PIM Local membership information
    VLAN 450:
    (*, 239.1.1.1) : Include
    (*, 239.1.1.2) : Include
    (*, 239.1.1.4) : Include
    (*, 239.1.1.5) : Include
    (*, 239.1.1.6) : Include
    (*, 239.1.1.8) : Include
    (*, 239.1.1.9) : Include
    (*, 239.1.1.10) : Include
    (*, 239.1.1.11) : Include
    (*, 239.1.1.14) : Include
    (*, 239.1.1.15) : Include
    (*, 239.1.1.16) : Include
    (*, 239.1.1.17) : Include
    (*, 239.1.1.30) : Include
    (*, 239.1.1.33) : Include
    (*, 239.1.1.50) : Include
    (*, 239.1.1.60) : Include
    (*, 239.1.1.85) : Include
    (*, 239.1.1.99) : Include
    (*, 239.1.1.100) : Include
    (*, 239.1.1.113) : Include
    (*, 239.1.1.126) : Include
    (*, 239.1.1.140) : Include
    (*, 239.1.1.182) : Include
    Address Interface VIFindex Ver/Mode Nbr-Count DR-Prior DR
    172.29.29.1 VLAN 450 1 v2/S 1 1 172.29.29.1
    Neighbor Interface Uptime/Expires Ver DR
    Address Priority/Mode
    100.1.12.1 VLAN 450 00:01:19/00:01:25 v2 1 /
Но показывать из за присвоения ip влану перестает все. Почему? Надо дополнительно конфигурировать DES-3200? Пожалуйста поясните.
СообщениеДобавлено: Пт сен 30, 2011 14:04
У Вас в такой схеме PIM вообще не используется. Посмотрите теорию тут: http://www.dlink.ru/ru/faq/58/267.html
СообщениеДобавлено: Пн окт 03, 2011 15:27
А нельзя ли подобный мануал сделать для DGS-3610 ???
СообщениеДобавлено: Вт окт 04, 2011 02:39
Плюсую. Нужен мануальчик для 3610
2008-2015г. компания Экстрим Интернет. Технический директор/Главный системный администратор.
2015-по н.в. компания "Подряд". Инженер сети ШПД
СообщениеДобавлено: Вт окт 04, 2011 13:46
Прочел документацию. Конечная схема будет такая.
План в общих чертах.Поправьте если имеете замечания.
Первое что делая включаю ip multicast-routing на всex 3610.
Второе на нужном мне влан интерфейсе делаю ip pim sparse mode.
Затем надо назначить указать RP address на DGS-3610 №1 - это будет любой ип любого влан интерфейса при условии что на влан интерфейсе включен ip pim sparse mode. На верхнем 3610 ничего не надо указавыть как я понял.
Потом глобально включить PIM на стеке из DGS-3627G и включить нужные интерфейсы мне интерфейсы. Далее на стеке создать влан который будет использоваться для ISM. Настраиваю ISM на офисном 3526 и проверяю.
У меня куча вопросов пытаюсь сам разобраться но вот что хочу спросить сейчас.
Вопрос № 1 Исходя из документации понял чтобы PIM партнеры были видны то необходимо присваивать вланам ип адреса и интерфесы должны пинговаться. Иначе работать не будет. Как будет лучше создать новые вланы новые сети или лучше не городить а использовать те интерфейсы которые имееются, чтобы по ним шел поток?
Вопрос № 2 У нас в сети работает GVRP везде прокидываем юзерские вланы через транзитное оборудование. И вот вопрос.
1) Если мультикастовый влан прокидывается через GVRP
    VID : 450 VLAN Name :
    VLAN TYPE : dynamic Advertisement : Enabled
    Member ports : 26
    Static ports :
    Current Tagged ports : 26
    Current Untagged ports :
    Static Tagged ports :
    Static Untagged ports :
    Forbidden ports :
То отконфигурировать его как ISM VLAN не удасться. Если он динамически создается то
DES-3526:admin#create igmp_snooping multicast_vlan IPTV 450
Command: create igmp_snooping multicast_vlan IPTV 450
The VLAN has already existed in VLAN module.
Fail!
Вывод не надо его через GVRP никоим образом прокидывать скажем так advertismen disable на выщестоящем железе. Верно мыслю?
Прокомментируйте, будем полезно многим.
СообщениеДобавлено: Чт окт 06, 2011 12:36
Помогите пожалуйста. Читал форум и теорию но никак не не пойму в чем дело. Сегодня вышестоящий провайдер дал настройки для мультикаста. Линк приходит в DGS-3610 (19 порт). Коммутатор DES-3526 в (20 порт). Вот конфиг 3610
DGS-3610(2)#sh ru
Current configuration : 2438 bytes
aaa new-model
nfpp
vlan 1
vlan 100
vlan 200
vlan 444
vlan 666
username root password XXXX
ip ssh version 2
archive
log config
logging enable
hidekeys
gvrp enable
switchport access vlan 666
description Source_Of_Multicast
switchport trunk allowed vlan remove 2-443,445-4094
interface VLAN 1
no ip proxy-arp
interface VLAN 444
ip pim sparse-mode
no ip proxy-arp
ip address 172.31.31.1 255.255.255.0
interface VLAN 666
ip pim sparse-mode
no ip proxy-arp
ip address 10.254.254.8 255.255.255.0
description Source_Of_Multicast-(PIM-SM)
ip pim rp-address 10.254.255.254
router ospf 2222
ip route 10.254.255.254 255.255.255.255 10.254.254.254
ip igmp snooping ivgl
line con 0
line vty 0 4
transport input ssh
privilege level 15
end
Вот sh ip igmp groups
DGS-3610(2)#sh ip igmp groups
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter
239.1.1.1 VLAN 666 00:18:06 00:03:54 10.11.12.143
239.1.1.4 VLAN 666 00:18:05 00:03:45 10.254.254.6
239.1.1.6 VLAN 666 00:18:10 00:04:04 10.254.254.7
239.1.1.8 VLAN 666 00:01:45 00:04:18 10.254.254.7
239.1.1.9 VLAN 666 00:01:40 00:04:19 10.254.254.6
239.1.1.10 VLAN 666 00:01:35 00:03:43 10.11.21.23
239.1.1.11 VLAN 666 00:01:49 00:04:17 10.254.254.6
239.1.1.13 VLAN 666 00:01:35 00:04:18 10.254.254.7
239.1.1.24 VLAN 666 00:04:16 00:04:19 10.11.12.143
239.1.1.27 VLAN 666 00:00:05 00:04:19 10.254.254.7
239.1.1.35 VLAN 666 00:00:01 00:04:19 10.254.254.7
239.1.1.52 VLAN 666 00:01:36 00:02:50 10.254.254.6
239.1.1.53 VLAN 666 00:01:06 00:03:14 10.254.254.7
239.1.1.55 VLAN 666 00:00:04 00:04:18 10.254.254.7
239.1.1.60 VLAN 666 00:18:01 00:03:47 10.11.31.54
239.1.1.65 VLAN 666 00:01:19 00:03:20 10.254.254.7
239.1.1.90 VLAN 666 00:01:57 00:04:16 10.254.254.6
239.1.1.100 VLAN 666 00:00:13 00:04:06 10.11.12.143
239.1.1.111 VLAN 666 00:00:06 00:00:01 10.254.254.6
239.1.1.121 VLAN 666 00:00:05 00:00:01 10.254.254.7
239.1.1.162 VLAN 666 00:01:37 00:02:47 10.254.254.6
239.1.1.170 VLAN 666 00:01:23 00:02:56 10.254.254.7
239.1.1.171 VLAN 666 00:01:17 00:03:05 10.254.254.7
239.1.1.178 VLAN 666 00:01:10 00:03:10 10.254.254.6
239.1.1.179 VLAN 666 00:01:03 00:03:16 10.254.254.6
239.1.1.180 VLAN 666 00:01:30 00:02:53 10.254.254.7
Вот sh ip igmp interface
DGS-3610(2)#sh ip igmp interface
Interface VLAN 666 (Index 4762)
IGMP Active, Non-Querier, Version 2 (default)
Internet address is 10.254.254.8
IGMP interface has 36 group-record states
IGMP interface has 0 static-group records
IGMP activity: 3125 joins, 11 leaves
IGMP querying router is 10.254.254.2
IGMP query interval is 125 seconds
IGMP querier timeout is 255 seconds
IGMP max query response time is 10 seconds
Last member query response interval is 10
Last member query count is 2
Group Membership interval is 260 seconds
Robustness Variable is 2
Interface VLAN 444 (Index 4540)
IGMP Enabled, Active, Querier, Version 2 (default)
Internet address is 172.31.31.1
IGMP interface has 0 group-record states
IGMP activity: 0 joins, 0 leaves
Вот sh ip igmp snooping
DGS-3610(2)#sh ip igmp snooping
IGMP Snooping running mode: IVGL
Source port check: Disable
Source ip check: Disable
IGMP Fast-Leave: Disable
IGMP Report suppress: Disable
IGMP Globle Querier: Disable
IGMP Preview: Disable
IGMP Tunnel: Disable
IGMP Preview group aging time : 60(Seconds)
Dynamic Mroute Aging Time : 300(Seconds)
vlan 1
IGMP Snooping state: Enable
Multicast router learning mode: pim-dvmrp
IGMP Fast-Leave: Disabled
IGMP VLAN querier: Disable
vlan 200
vlan 100
vlan 2
vlan 300
vlan 301
vlan 302
vlan 303
vlan 304
vlan 305
vlan 306
vlan 307
vlan 308
vlan 309
vlan 310
vlan 910
vlan 666
vlan 444
Вот sh ip igmp snooping mrouter
DGS-3610(2)#sh ip igmp snooping mrouter
Multicast Switching Mroute Port
D: DYNAMIC
S: STATIC
(*, *, 1):
VLAN(1) 1 MROUTES:
GigabitEthernet 0/15(D)
(*, *, 666):
VLAN(666) 3 MROUTES:
GigabitEthernet 0/19(D)
ROUTER(D)
(*, *, 444):
VLAN(444) 1 MROUTES:
ROUTER(D)
Вот sh ip pim sparse-mode neighbor
DGS-3610(2)(config-router)#sh ip pim sparse-mode neighbor
10.254.254.2 VLAN 666 00:25:35/00:01:15 v2 1 /
10.254.254.254 VLAN 666 00:25:35/00:01:45 v2 1 / DR
Вот sh ip pim sparse-mode interface
172.31.31.1 VLAN 444 2 v2/S 0 1 172.31.31.1
10.254.254.8 VLAN 666 1 v2/S 2 1 10.254.254.254
Вот sh ip pim sparse-mode nexthop
DGS-3610(2)#sh ip pim sparse-mode nexthop
Flags: N = New, R = RP, S = Source, U = Unreachable
Destination Type Nexthop Nexthop Nexthop Metric Pref Refcnt
Num Addr Name
____________________________________________________________________________________________
10.254.255.254 .R.. 1 10.254.254.254 VLAN 666 0 1 32
Вот sh ip pim sparse-mode local-members
VLAN 444:
VLAN 666:
(*, 239.1.1.13) : Include
(*, 239.1.1.21) : Include
(*, 239.1.1.32) : Include
(*, 239.1.1.34) : Include
(*, 239.1.1.49) : Include
(*, 239.1.1.64) : Include
(*, 239.1.1.69) : Include
(*, 239.1.1.87) : Include
(*, 239.1.1.90) : Include
(*, 239.1.1.102) : Include
(*, 239.1.1.111) : Include
(*, 239.1.1.141) : Include
(*, 239.1.1.173) : Include
Вот sh ip pim sparse-mode mroute
IP Multicast Routing Table
(*,*,RP) Entries: 0
(*,G) Entries: 26
(S,G) Entries: 0
(S,G,rpt) Entries: 0
FCR Entries: 26
REG Entries: 0
(*, 239.1.1.1)
RP: 10.254.255.254
RPF nbr: 10.254.254.254
RPF idx: VLAN 666
Upstream State: NOT JOINED
00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
Local
0 . i . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Joined
0 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Asserted
FCR:
Source: 10.253.255.101
Outgoing
KAT timer running, 152 seconds remaining
Packet count 1
(*, 239.1.1.2)
RP: 10.254.255.254
RPF idx: VLAN 666
Local
Joined
Asserted
FCR:
Outgoing
KAT timer running, 205 seconds remaining
Packet count 1
(*, 239.1.1.4)
RP: 10.254.255.254
--More--
Вопрос почему у меня нет ни одной группы во влане 444 к которому подключен 3526. Где то я ошибся в настройках DGS-3610. Пожалуйста подскажите.
СообщениеДобавлено: Чт окт 06, 2011 13:04
Разобрался сам. Мой косяк забыл врубить глобально IGMP snooping на DES-3526. Заработался :|
СообщениеДобавлено: Пт окт 07, 2011 13:18
И так со многим разобрался уже. Возник вопрос про RP. Вышестоящий провайдер дал адрес rp. Прописал работает, потестил IPTV все прекрасно, потестил технологии ISM, или просто IGMP. Отрепитировал все четко.
Вопрос к спецам из D-link Вот верхний 3610, где RP 10.254.255.254 это дал провайдер. Там сделали маршрут к этой сетке и все работает.
ip pim rp-address 172.172.172.2
Я создал влан дал ему адрес 172.172.172.2 и прописал это адрес как RP.
Далее нижний 3610 создал такой же влан дал ему ip 172.172.172.1 и прописал RP ip pim rp-address 172.172.172.2. Ну естественно мультикаст роутинг и pim sparse mode на этот влан.
Эта схема жизнеспособна с этим RP на нижнем 3610 -? Будет работать?
СообщениеДобавлено: Вс окт 09, 2011 10:43
Посоветуйте пожалуйста другое тогда.
1) Как сделать чтобы моему аплинку не улетало от меня ничего лишнего (например 239.255.255.250). Этого достаточно?
ip access-list standard UPLINK_MCAST_GROUPS
 10 permit 239.1.1.0 0.0.0.255
 20 deny any
Вот что сейчас имеется на первом DGS-3610
DGS-3610(2)(config)#Building configuration...
Current configuration : 2878 bytes
aaa new-model
nfpp
vlan 1
vlan 100
vlan 200
vlan 666
vlan 777
vlan 888
ip ssh version 2
no ip domain-lookup
20 deny any
no ip source-route
archive
log config
logging enable
hidekeys
gvrp enable
switchport trunk allowed vlan remove 2-443,445-776,778-4094
interface VLAN 1
no ip proxy-arp
no ip unreachables
no ip redirects
interface VLAN 666
ip pim sparse-mode
no ip proxy-arp
no ip unreachables
no ip redirects
interface VLAN 777
ip pim sparse-mode
no ip proxy-arp
no ip unreachables
no ip redirects
ip address 172.32.32.1 255.255.255.0
description ISM_VLAN
interface VLAN 888
ip pim sparse-mode
no ip proxy-arp
no ip unreachables
no ip redirects
ip address 172.172.172.2 255.255.255.0
ip pim rp-address 10.254.255.254 UPLINK_MCAST_GROUPS
router ospf 2222
line con 0
line vty 0 4
transport input ssh
privilege level 15
end
2)Вопрос по настройке DGS-3610 №2. Как писал ранее провайдер сменил настройки и дал нам свой rp-address. Не понял такой момент. Реально ли такое - допустим я делаю еще один RP на 1 3610 ip pim rp-address 172.172.172.2 и туда заворачиваю (через ip mroute группу 239.1.1.0/24 ??). На другом 3610 указываю что ip pim rp-address 172.172.172.2. Будет работать?
3) Другой вариант настройки DGS-3610 №2 знаю что будет работать если указать ip pim rp-address аплинка.
Делаю маршрут на сеть
ip route 10.254.254.0 255.255.255.0 172.28.15.242
Пингую 10.254.254.8
Но не пингую с него хост 10.254.254.254. А с DGS-3610 №1 пинг идет. Да влан с ip интерфейсом из этой сети не создаю. Так как из сети 10.254.254.0/24 выделили нам 1 адрес. Как тут поступить?
С остальным что спрашивал ранее более менее разобрался. Спасибо!
СообщениеДобавлено: Пн окт 10, 2011 08:34
В логах обнаружил такое на 3610
    *Oct 9 20:47:29: %MC-6-HASH_CONFLICT: Failed to allocate multicast entry (source:0.0.0.0, group:228.235.216.37) due to hash conflict
    *Oct 9 20:50:45: %MC-6-HASH_CONFLICT: Failed to allocate multicast entry (source:0.0.0.0, group:234.95.52.66) due to hash conflict
    *Oct 9 20:54:58: %MC-6-HASH_CONFLICT: Failed to allocate multicast entry (source:0.0.0.0, group:234.95.52.66) due to hash conflict
    *Oct 9 20:56:49: %MC-6-HASH_CONFLICT: Failed to allocate multicast entry (source:0.0.0.0, group:234.95.52.66) due to hash conflict
    *Oct 9 21:01:48: %MC-6-HASH_CONFLICT: Failed to allocate multicast entry (source:0.0.0.0, group:234.95.52.66) due to hash conflict
    *Oct 9 21:02:14: %MC-6-HASH_CONFLICT: Failed to allocate multicast entry (source:0.0.0.0, group:238.76.188.186) due to hash conflict
    *Oct 9 21:28:50: %MC-6-HASH_CONFLICT: Failed to allocate multicast entry (source:0.0.0.0, group:239.255.255.250) due to hash conflict
В документации и в интернете не нашел разъяснения, как с этим боротся?
СообщениеДобавлено: Вт окт 11, 2011 09:42
найти того кто флудит с сорса 0.0.0.0 мультикаст? wireshark?
СообщениеДобавлено: Вт окт 11, 2011 13:08
И так я наконец-то все настроил как хотел. Имею рабочую схему DGS-3610(PIM-SM)-DGS-3610(IGMP)-DGS-3627G(IGMP)-DES3526(ISM VLAN). Могу поделится кому надо.
Максим а можно ли как то ACL порезать на 3610(это ядро сети) всю эту гадость с учетом что у меня работает OSPF и группа каналов 239.1.1.0/24. Как грамотно поступить? Хотелось бы с примером.
Wiresharkoм пока не нашел ничего. Эта запись в логах вообще что означает? На доступе filter unregistered groups на все порты.
Вот какую картину вижу sh ip igmp snooping statistics
DGS-3610(Main)(config)#sh ip igmp snooping statistics
Current number of Gda-table entries: 34
Configured Statistics database limit: 1024
Current number of IGMP Query packet received : 862933
Current number of IGMPv1/v2 Report packet received: 11739425
Current number of IGMPv3 Report packet received: 135864
Current number of Leave packet received: 98500
Current number of PIM packet received: 53047
Current number of DVMRP packet received: 0
GROUP Interface Last Last Last Report Leave
report time leave time reporter pkts pkts
239.255.255.250 VL1:Gi0/15 0d:0h:0m:0s ---- 172.28.9.193 56 0
239.255.255.250 VL1:Gi0/8 0d:0h:0m:14s ---- 172.28.13.42 10 0
239.255.255.250 VL1:Gi0/4 0d:0h:0m:12s ---- 172.20.251.97 30 0
239.255.255.250 VL1:Gi0/6 0d:0h:0m:5s ---- 172.28.6.35 97 0
239.255.255.250 VL1:Gi0/7 0d:0h:0m:9s ---- 172.28.3.204 131 0
239.255.255.250 VL1:Gi0/5 0d:0h:0m:2s ---- 172.28.1.80 216 0
239.255.255.250 VL1:Gi0/10 0d:0h:0m:8s ---- 172.28.6.153 688 0
239.255.255.250 VL1:Gi0/12 0d:0h:0m:2s ---- 172.28.10.212 763 0
239.255.255.250 VL1:Ag1 0d:0h:0m:0s 0d:0h:0m:8s 172.28.6.249 3178538 8140
239.192.152.143 VL1:Gi0/15 0d:0h:0m:4s ---- 172.28.9.75 246 0
239.192.152.143 VL1:Gi0/8 0d:0h:0m:0s ---- 172.28.13.42 54 0
239.192.152.143 VL1:Gi0/6 0d:0h:0m:5s ---- 172.28.13.84 87 0
239.192.152.143 VL1:Gi0/12 0d:0h:0m:6s ---- 172.28.6.21 185 0
239.192.152.143 VL1:Gi0/10 0d:0h:0m:0s ---- 172.28.5.72 283 0
239.192.152.143 VL1:Gi0/7 0d:0h:0m:15s ---- 172.28.9.129 454 0
239.192.152.143 VL1:Ag1 0d:0h:0m:0s 0d:0h:5m:28s 172.28.5.72 1289507 2707
239.1.2.2 VL1:Ag1 0d:0h:0m:6s ---- 172.28.11.58 1962 0
239.255.255.254 VL1:Ag1 0d:0h:0m:2s ---- 172.28.8.223 2001 0
228.72.68.67 VL1:Ag1 0d:0h:0m:3s ---- 172.28.7.166 1669 0
239.254.1.2 VL1:Gi0/15 0d:0h:0m:8s ---- 172.28.11.166 210 0
239.254.1.2 VL1:Ag1 0d:0h:0m:4s ---- 172.28.7.166 1879 0
239.255.255.177 VL1:Ag1 0d:0h:0m:14s ---- 172.28.1.138 1210 0
224.0.2.47 VL1:Ag1 0d:0h:0m:4s ---- 172.28.8.223 1054 0
239.1.15.7 VL1:Ag1 0d:0h:0m:6s ---- 172.28.11.58 658 0
239.255.255.253 VL1:Gi0/10 0d:0h:0m:8s ---- 172.28.3.184 31 0
239.255.255.253 VL1:Ag1 0d:0h:0m:6s ---- 172.28.11.58 568 0
224.0.1.55 VL1:Ag1 0d:0h:0m:5s ---- 172.28.11.58 411 0
233.7.70.1 VL1:Ag1 0d:0h:0m:1s ---- 172.28.1.138 225 0
224.0.1.60 VL1:Ag1 0d:0h:0m:1s ---- 172.20.251.34 198 0
239.255.255.239 VL1:Ag1 0d:0h:0m:7s ---- 172.28.11.58 84 0
228.8.8.8 VL1:Ag1 0d:0h:0m:5s ---- 172.28.8.223 72 0
239.255.255.100 VL1:Ag1 0d:0h:0m:6s ---- 172.28.11.58 91 0
231.0.0.1 VL1:Ag1 0d:0h:0m:9s ---- 172.28.1.138 54 0
224.0.1.24 VL1:Ag1 0d:0h:0m:6s ---- 172.28.7.166 48 0
224.2.127.254 VL1:Ag1 0d:0h:0m:5s ---- 172.28.1.138 40 0
239.1.15.1 VL1:Ag1 0d:0h:0m:7s ---- 172.28.11.58 28 0
239.1.10.2 VL1:Ag1 0d:0h:0m:3s ---- 172.28.8.223 24 0
239.192.152.143 VL301:Gi0/2 0d:0h:0m:39s ---- 172.20.1.74 83 0
239.255.255.250 VL301:Gi0/2 0d:0h:0m:39s ---- 172.20.1.74 34 0
239.255.255.250 VL302:Gi0/3 0d:0h:1m:43s ---- 172.20.2.213 10 0
239.255.255.250 VL304:Gi0/9 0d:0h:1m:13s ---- 172.20.4.21 2 0
239.192.152.143 VL305:Ag1 0d:0h:1m:29s ---- 172.20.5.88 50 0
224.0.1.60 VL305:Ag1 0d:0h:1m:22s ---- 172.20.5.29 26 0
239.255.255.250 VL305:Ag1 0d:0h:1m:29s ---- 172.20.5.23 5 0
239.255.255.250 VL306:Ag1 0d:0h:0m:42s ---- 172.20.6.17 38 0
239.255.255.250 VL308:Ag1 0d:0h:4m:11s ---- 172.20.8.7 1 0
239.255.255.250 VL777:Ag1 0d:0h:0m:6s ---- 172.20.254.12 1138 0
224.0.1.127 VL777:Ag1 0d:0h:0m:0s ---- 172.20.254.12 1013 0
239.1.1.1 VL777:Ag1 0d:0h:0m:3s ---- 172.20.254.10 33 0
239.255.255.253 VL777:Ag1 0d:0h:0m:6s ---- 172.20.254.12 3 0
СообщениеДобавлено: Вт окт 11, 2011 15:00
Может просто порезать лишний мультик на доступе?
Вот пример для 3028/3200
delete cpu access_profile profile_id 1
delete cpu access_profile profile_id 2
delete cpu access_profile profile_id 3
create cpu access_profile profile_id 1 ip destination_ip_mask 255.255.255.0
config cpu access_profile profile_id 1 add access_id 1 ip destination_ip 224.12.1.0 port all permit
create cpu access_profile profile_id 2 ip destination_ip_mask 255.255.255.255
config cpu access_profile profile_id 2 add access_id 1 ip destination_ip 224.0.0.1 port all permit
config cpu access_profile profile_id 2 add access_id 2 ip destination_ip 224.0.0.2 port all permit
create cpu access_profile profile_id 3 ip destination_ip_mask 240.0.0.0
config cpu access_profile profile_id 3 add access_id 1 ip destination_ip 224.0.0.0 port all deny
enable cpu_interface_filtering
СообщениеДобавлено: Пт окт 14, 2011 08:45
ZeM писал(а):
И так я наконец-то все настроил как хотел. Имею рабочую схему DGS-3610(PIM-SM)-DGS-3610(IGMP)-DGS-3627G(IGMP)-DES3526(ISM VLAN). Могу поделится кому надо. Максим а можно ли как то ACL порезать на 3610(это ядро сети) всю эту гадость с учетом что у меня работает OSPF и группа каналов 239.1.1.0/24. Как грамотно поступить? Хотелось бы с примером.Wiresharkoм пока не нашел ничего. Эта запись в логах вообще что означает? На доступе filter unregistered groups на все порты.Вот какую картину вижу sh ip igmp snooping statistics
можно узреть часть кинфига 3610G (на схеме он обозначен как №2) в части настроек мультикаста. Я принимаю мультикаст от вышестоящего провайдера, но вот на кошках С3560G все враз завелось, а на 3610 никак не хочет и какая версия ПО на 3610G стоит.
