Текущее время: Сб окт 03, 2026 01:12
 Заголовок сообщения: Проблема с DGS-3627G
СообщениеДобавлено: Пн сен 12, 2011 12:51
Boot Procedure 1.10-B09
MAC Address : 00-22-B0-26-E3-00
H/W Version : A1
DGS-3627G Gigabit Ethernet Switch
Command Line Interface
Firmware: Build 2.84.B10
Copyright(C) 2010 D-Link Corporation. All rights reserved.
UserName:soc_miim_write: timeout (id=0x80 addr=0x1F data=0x0000)
Port ge0: Failed to recover link status: Operation timed out
_soc_xgs3_mem_dma: failed(NAK)
soc_l2x_thread: DMA failed: Operation failed
soc_counter_thread: DMA did not finish buf32=10000010
soc_counter_thread: unit = 0 DMA Error
soc_miim_write: timeout (id=0x81 addr=0x1F data=0x0000)
Port ge1: Failed to recover link status: Operation timed out
soc_miim_write: e2: Failed to recover link status: Operation timed out
soc_miim_write: timeout ed out
soc_miim_write: timeout (id=0x84 addr=0x1F data=0x0000)
Port ge4: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x85 addr=0x1F data=0x0000)
Port ge5: Failed to recover link status: Operation timed out
soc_miim_write: peration timed out
soc_miim_write: timeout (id=0x87 addr=0x1F data=0x0000)
Port ge7: Failed to recover link status: Operation timed out
_soc_xgs3_mem_dmEsoc_l2x_thread: DMA failed: Operation failed
soc_miim_write: timeout (id=0x88 addr=0x1F data=0x0000)
Port ge8: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x89 addr=0x1F data=0x0000)
Port ge9: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x8A addr=0x1F data=0x0000)
Port ge10: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x8B addr=0x1F data=0x0000)
Port ge11: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x8C addr=0x1F data=0x0000)
Port ge12: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x8D addr=0x1F data=0x0000)
Port ge13: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x8E addr=0x1F data=0x0000)
Port ge14: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x8F addr=0x1F data=0x0000)
Port ge15: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x90 addr=0x1F data=0x0000)
Port ge16: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x91 addr=0x1F data=0x0000)
Port ge17: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x92 addr=0x1F data=0x0000)
Port ge18: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x93 addr=0x1F data=0x0000)
Port ge19: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x15 addr=0x1C data=0x7C00)
Port ge20: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x16 addr=0x1C data=0x7C00)
Port ge21: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x17 addr=0x1C data=0x7C00)
Port ge22: Failed to recover link status: Operation timed out
soc_l2x_thread: Too many errors
soc_miim_write: timeout (id=0x18 addr=0x1C data=0x7C00)
Port ge23: Failed to recover link status: Operation timed out
Port xe0: Failed to recover link status: Operation timed out
Port xe1: Failed to recover link status: Operation timed out
Port xe2: Failed to recover link status: Operation timed out
Port hg0: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x82 addr=0x1F data=0x0000)
Port ge2: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x83 addr=0x1F data=0x0000)
Port ge3: Failed to recover link status: Operation timed out
soc_miim_write: timeout (id=0x86 addr=0x1F data=0x0000)
Port ge6: Failed to recover link status: Operation timed out
soc_counter_thread: Too many errors
soc_counter_thread: Operation failed; exiting
Подскажите с этим что-то можно сделать ???
 Заголовок сообщения: Re: Проблема с DGS-3627G
СообщениеДобавлено: Пн сен 12, 2011 12:53
Попробуйте зайти в бут меню (Shift+3 сразу после включения питания) и залить заново прошивку. Если не поможет, то только в сервис.
СообщениеДобавлено: Пн сен 12, 2011 13:06
бут меню не загружается. Я это пробовал еще перед обращением на форум.
СообщениеДобавлено: Пн сен 12, 2011 14:15
Значит в сервис.
