Текущее время: Чт окт 01, 2026 23:40
СообщениеДобавлено: Ср авг 31, 2011 11:17
Доброго времени суток.
Возникли трудности с настройкой IPTV.
Есть поток приходящий от аплинка по протоколу PIM-SM.
На входящем свиче (DGS3612G) настроено вроде как верно:
enable pim
config pim cbsr hash_masklen 30
config pim cbsr bootstrap_period 60
config pim register_suppression_time 60
config pim register_probe_time 5
config pim last_hop_spt_switchover never
config pim crp holdtime 150 priority 255
config pim crp wildcard_prefix_cnt 0
config pim ipif System state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif System priority -1
config pim ipif InNet state disable hello 30 jp_interval 60 mode dm dr_priority 1
config pim cbsr ipif InNet priority -1
config pim ipif iptv state enable hello 30 jp_interval 60 mode sm dr_priority 1
config pim cbsr ipif iptv priority -1
config pim ipif iplan state enable hello 30 jp_interval 60 mode sm dr_priority 50
config pim cbsr ipif iplan priority -1
create pim crp group 224.0.0.0/4 rp iplan
create pim static_rp group 224.0.0.0/4 rp 93.100.192.182
enable igmp_snooping
config igmp_snooping vlan default report_suppression disable
config igmp_snooping vlan default state enable fast_leave disable
config igmp_snooping querier vlan default query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan vlan10 report_suppression disable
config igmp_snooping vlan vlan10 state enable fast_leave disable
config igmp_snooping querier vlan vlan10 query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan vlan12 report_suppression disable
config igmp_snooping vlan vlan12 state enable fast_leave disable
config igmp_snooping querier vlan vlan12 query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan vlan13 report_suppression disable
config igmp_snooping vlan vlan13 state enable fast_leave disable
config igmp_snooping querier vlan vlan13 query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan vlan14 report_suppression disable
config igmp_snooping vlan vlan14 state enable fast_leave disable
config igmp_snooping querier vlan vlan14 query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan vlan_obit report_suppression disable
config igmp_snooping vlan vlan_obit state enable fast_leave disable
config igmp_snooping querier vlan vlan_obit query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan vstart report_suppression disable
config igmp_snooping vlan vstart state enable fast_leave disable
config igmp_snooping querier vlan vstart query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan ipvlan report_suppression disable
config igmp_snooping vlan ipvlan state enable fast_leave disable
config igmp_snooping querier vlan ipvlan query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp ipif System version 2 query_interval 125 max_response_time 10 robustness_variable 2 state enable
config igmp ipif System last_member_query_interval 1
config igmp check_subscriber_source_network ipif System enable
config igmp ipif InNet version 2 query_interval 125 max_response_time 10 robustness_variable 2 state enable
config igmp ipif InNet last_member_query_interval 1
config igmp check_subscriber_source_network ipif InNet enable
config igmp ipif iptv version 2 query_interval 125 max_response_time 10 robustness_variable 2 state enable
config igmp ipif iptv last_member_query_interval 1
config igmp check_subscriber_source_network ipif iptv enable
config igmp ipif iplan version 2 query_interval 125 max_response_time 10 robustness_variable 2 state enable
config igmp ipif iplan last_member_query_interval 1
config igmp check_subscriber_source_network ipif iplan enable
Если втыкаться vlc в iplan (внутреняя сеть) то поток играет.
Дальше в сети стоит еще один DGS3612G. С него хочу раздать в несколько абонентских vlan'ов с помощью igmp\pim но почему-то не получается.
config igmp_snooping vlan iplan report_suppression disable
config igmp_snooping vlan iplan state enable fast_leave disable
config igmp_snooping querier vlan iplan query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp ipif ipkras version 2 query_interval 125 max_response_time 10 robustness_variable 2 state enable
config igmp ipif ipkras last_member_query_interval 1
config igmp check_subscriber_source_network ipif ipkras enable
create igmp static_group ipif iplan group 239.195.0.4
enable pim
config pim crp holdtime 150 priority 192
config pim ipif System state disable hello 30 jp_interval 60 mode sm dr_priority 1
config pim ipif iplan state enable hello 30 jp_interval 60 mode sm dr_priority 20
config pim ipif ipkras state enable hello 30 jp_interval 60 mode sm dr_priority 1
config pim cbsr ipif ipkras priority -1
Группы на коммутаторе начинают появляться но только на интерфейсе с которого запрашиваю.
#show igmp group
Command: show igmp group
Interface     Multicast Group  Last Reporter    IP Querier       IP Expire
ipkras        224.0.1.60       10.0.15.106      SELF             253
ipkras        239.192.152.143  10.0.13.163      SELF             257
ipkras        239.195.0.3      10.0.13.201      SELF             259
ipkras        239.255.219.45   10.0.14.115      SELF             254
ipkras        239.255.255.250  10.0.15.142      SELF             256
 Total Entries: 5
239.195.0.3 - группа которую я пробую запросить.
Входящий свич:
Device Type       : DGS-3612G Gigabit Ethernet Switch
MAC Address       : 00-1E-58-D9-4E-00
Boot PROM Version : Build 1.10-B09
Firmware Version  : Build 2.81.B03
Hardware Version  : A1
Serial Number     : P1J5186000073
Второй:
MAC Address       : 00-1E-58-DC-E4-00
Firmware Version  : Build 2.82.B20
Serial Number     : P1J5187000007
На что стоит обратить внимание чтобы заставить данную схему работать.
СообщениеДобавлено: Ср авг 31, 2011 15:29
Посмотрите, пожалуйста, вот эту документацию, в ней похожий пример рассмотрен: ftp://ftp.dlink.ru/pub/Trainings/D-Link_switches_and_multicast.zip
Сейчас этот форум просматривают: Google [Bot] и гости: 86
